1 | ;----------------------------------------------------------------------
2 | ; Title : myAVR Beispiel "Signalton mit Timer0" für den ATmega8
3 | ;----------------------------------------------------------------------
4 | ; Funktion : Ausgabe des Kammertion A
5 | ; Schaltung : PORTB.0=Summer, PORTB.1=LED-Rot
6 | ;----------------------------------------------------------------------
7 | ; Prozessor : ATmega8
8 | ; Takt : 3,6864 MHz
9 | ; Sprache : Assembler
10 | ; Datum : 09.11.2007
11 | ; Version : 1.0
12 | ; Autor : Renaldo Badke
13 | ; Programmer :
14 | ; Port :
15 | ;----------------------------------------------------------------------
16 | .equ F_CPU, 1000000
17 | .include "avr.h"
18 | ;-----------------------------------------------------------------------
19 | ;Reset and Interruptvectoren ;VNr. Beschreibung
20 | begin:
21 | rjmp main ; 1 POWER ON RESET
22 | reti ; 2 Int0-Interrupt
23 | reti ; 3 Int1-Interrupt
24 | reti ; 4 TC2 Compare Match
25 | reti ; 5 TC2 Overflow
26 | reti ; 6 TC1 Capture
27 | reti ; 7 TC1 Compare Match A
28 | reti ; 8 TC1 Compare Match B
29 | reti ; 9 TC1 Overflow
30 | rjmp onTC0 ;10 TC0 Overflow
31 | reti ;11 SPI, STC Serial Transfer Complete
32 | reti ;12 UART Rx Complete
33 | reti ;13 UART Data Register Empty
34 | reti ;14 UART Tx Complete
35 | reti ;15 ADC Conversion Complete
36 | reti ;16 EEPROM Ready
37 | reti ;17 Analog Comperator
38 | reti ;18 TWI (I²C) Serial Interface
39 | reti ;19 Strore Program Memory Ready
40 | ;------------------------------------------------------------------------
41 | ;Start, Power ON, Reset
42 | main:
43 | ldi r16,lo8(RAMEND)
44 | out ioSPL,r16 ;Init Stackpointer LO
45 | ldi r16,hi8(RAMEND)
46 | out ioSPH,r16 ;Init Stackpointer HI
47 |
48 | sbi ioDDRB,0 ;OUT Summer
49 | sbi ioDDRB,1 ;OUT LED
50 | cbi ioDDRD,2 ;Taster als eingang
51 | sbi ioDDRC,0 ;Led
52 |
53 | ldi r16,0b0000101
54 | out ioTCCR0,r16 ;Timer0 setup 1/14 Sekunde 3686400/1024
55 | ldi r16,0b0000001
56 | out ioTIMSK,r16 ;Interrupt Timer0 bei overflow
57 |
58 | ldi r17,190 ;Timer0 Init
59 | out ioTCNT0,r17 ;ausgeben
60 | ldi r16,0 ;Ausgabewert LOW
61 | sei
62 | ;------------------------------------------------------------------------
63 | mainloop:
64 | wdr
65 | sbis ioPIND,2 ;Taster offen
66 | rjmp end
67 | cbi ioPORTC,0 ;Led aus
68 | rjmp raus
69 | end: sbi ioPORTC,0 ;Led an
70 | raus: rjmp mainloop
71 | ;------------------------------------------------------------------------
72 | onTC0:
73 | cli ;Interrupts sperren
74 | push r16
75 | push r17
76 | in r16,ioPORTB ;PORTB einlesen
77 | com r16 ;Einerkomplement, Bitweise Negation
78 | out ioPORTB,r16 ;PORTB umschalten (Signalwechsel)
79 | ldi r17,19 ;berechneter Reinit-Wert
80 | out ioTCNT0,r17 ;Timer Reinit
81 | pop r17
82 | pop r16
83 | sei ;Interrupt freigeben
84 | reti ;Rücksprung
85 | ;------------------------------------------------------------------------
