1 | #include <avr/io.h>
2 | #include <util/delay.h>
3 |
4 | #define WP (1<<PC5) // Write Protect disable @PC5
5 | #define HOLD (1<<PC4) // Stop serial communication disable @PC4
6 | #define CE (1<<PB2) // Chip Enable @PB2
7 | #define MOSI (1<<PB3) // Master Out Slave In @PB3
8 | #define MISO (1<<PB4) // Master In Slave Out @PB4
9 | #define SCK (1<<PB5) // Clock @PB5
10 |
11 | uint8_t data, status_register=0;
12 |
13 | void SPI_MasterInit(void)
14 | {
15 | DDRB = MOSI|SCK|CE; // Set MOSI, SCK, CE output
16 | SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1); // Enable SPI, Master, set clock rate fck/64
17 | }
18 | void SPI_MasterTransmit(uint8_t data)
19 | {
20 | SPDR = data; // Start transmission
21 | while(!(SPSR & (1<<SPIF))); // Wait for transmission complete
22 | }
23 |
24 | uint8_t SPI_SlaveReceive(void)
25 | {
26 | while(!(SPSR & (1<<SPIF))); // Wait for reception complete
27 | return SPDR; // Return SPI-Dataregister
28 | }
29 |
30 | int main(void)
31 | {
32 | DDRC |= WP | HOLD; // Set WP, HOLD output
33 | PORTC |= WP|HOLD; // Set WP, HOLD high
34 |
35 | while(1)
36 | {
37 | SPI_MasterInit(); // Init SPI Master
38 | PORTB &= ~CE; // CE = low (start communication)
39 | SPI_MasterTransmit(0x05); // Send command 0x05 (Read the status register)
40 | SPI_MasterTransmit(0x00); // Send one dummy byte
41 | status_register = SPI_SlaveReceive(); // Store the value of the status register
42 | PORTB |= CE; // CE = high (end of communication)
43 | status_register=0; // set the variable to 0
44 | _delay_us(10);
45 |
46 | PORTB &= ~CE; // CE = low (start communication)
47 | SPI_MasterTransmit(0x06); // Send command 0x06 (Set write enable WREN)
48 | PORTB |= CE; // CE = high (end of communication)
49 | _delay_us(10);
50 |
51 | PORTB &= ~CE; // CE = low (start communication)
52 | SPI_MasterTransmit(0x02); // Send command 0x02 (program one data byte)
53 | SPI_MasterTransmit(0x00); // Send 1. Addressbyte (MSB first)
54 | SPI_MasterTransmit(0x00); // Send 2. Addressbyte
55 | SPI_MasterTransmit(0x00); // Send 3. Addressbyte
56 | SPI_MasterTransmit(0xAA); // Send Databyte
57 | PORTB |= CE; // CE = high (end of communication)
58 | _delay_us(10);
59 |
60 | PORTB &= ~CE; // CE = low (start communication)
61 | SPI_MasterTransmit(0x04); // WRDI (write disable) Send command 0x04
62 | PORTB |= CE; // CE = high (end of communication)
63 | _delay_us(10);
64 |
65 | PORTB &= ~CE; // CE = low (start communication)
66 | SPI_MasterTransmit(0x03); // Send command 0x03 Read
67 | SPI_MasterTransmit(0x00); // Send 1. Addressbyte (MSB first)
68 | SPI_MasterTransmit(0x00); // Send 2. Addressbyte
69 | SPI_MasterTransmit(0x00); // Send 3. Addressbyte
70 | SPI_MasterTransmit(0x00); // Send Dummybyte
71 | PORTB |= CE; // CE = high (end of communication)
72 | data = SPI_SlaveReceive();
73 | data = 0;
74 | }
75 | }
