1 | type state_command is ( idle , start_mess, finish_mess);
2 | signal state, nextstatus : state_command;
3 |
4 | signal byte_count : INTEGER RANGE 0 TO 7:=0; -- Die zu empfangenden Bytes --
5 | signal bit_count : INTEGER RANGE 0 TO 10:=0; -- Bits zum Byte (1Start-8DATA-2Stopp)--
6 | signal trigger_count : INTEGER RANGE 0 TO 9:=0; -- trigger-Zähler um 10--
7 | signal time_count : INTEGER RANGE 0 TO 650:=0; -- Vorwert zum Frqeuzenteiler 38,4kHz--
8 | signal time_trigger_count : INTEGER RANGE 0 TO 117:=0; -- zeitliche trigger--
9 | signal value_count : INTEGER RANGE 0 TO 9:=0; -- temporäres super Byte.--
10 |
11 | signal synch_state : STD_LOGIC :='0';
12 | signal in_process : STD_LOGIC := '0'; -- Status im Process--
13 | signal start : STD_LOGIC := '0'; -- Status los gehts--
14 | signal check_bit : STD_LOGIC := '0'; -- Kontrolle des ersten bit vom Datenstrom
15 | signal finish : STD_LOGIC := '0'; -- Status Ende
16 | signal tmpValue : STD_LOGIC_VECTOR(71 downto 0):= (others => '0'); -- Bitstream.
17 | signal tmp_clk_out : STD_LOGIC := '0'; -- Clock für LaRousse
18 | signal CLK_LR_INIT : STD_LOGIC :='0';
19 | signal TMP_VAL_1 : STD_LOGIC_VECTOR(71 downto 0):= (others => '0');
20 |
21 | begin
22 |
23 | Clock_LR: Vorwzhl
24 | Port map (
25 | Clk => CLK,
26 | Rst => RESET,
27 | CTL_DOTO => CTL_TODO,
28 | ZClk => CLK_LR
29 | );
30 |
31 |
32 | Process (CLK, RESET)
33 | begin
34 |
35 | if (RESET ='1') then
36 | -- byte_count <= 0;
37 | -- bit_count <= 0;
38 | -- trigger_count <= 0;
39 | -- time_count <= 0;
40 | -- time_trigger_count <= 0;
41 | -- value_count <= 0;
42 | -- tmp_clk_out <= '0';
43 | -- in_process <= '0';
44 | -- finish <= '0';
45 | -- start <= '0';
46 | -- tmpValue <= (others => '0');
47 | -- tmp_clk_out <= '0';
48 | state <= idle;
49 | elsif (rising_edge(CLK)) then
50 | state <= nextstatus;
51 | end if;
52 | end Process;
53 |
54 | Process (CLK, DATA_IN)
55 | begin
56 |
57 | if (rising_edge(CLK)) then
58 |
59 | case state is
60 | when idle =>
61 | byte_count <= 0;
62 | bit_count <= 0;
63 | trigger_count <= 0;
64 | value_count <= 0;
65 | in_process <= '0';
66 | finish <= '0';
67 | start <= '0';
68 | tmpValue <= (others => '0');
69 | CTL_STATE <= "00";
70 |
71 | if (CTL_TODO = '1' and in_process = '0' and finish = '0') then
72 | in_process <= '1';
73 | nextstatus <= start_mess;
74 | end if;
75 |
76 |
77 | when start_mess =>
78 | CTL_STATE <= "10";--messung
79 | start <='1';
80 | if (in_process = '1' and start ='1' and finish = '0') then
81 | if (DATA_IN = '0') then
82 | check_bit <= '1';
83 | else
84 | nextstatus <= idle;
85 | end if;
86 | if (check_bit = '1') then
87 | trigger_count <= trigger_count+1;
88 | end if;
89 | if (trigger_count = 9) then
90 | if (bit_count > 0 and bit_count < 8) then
91 | tmpValue <= tmpValue(70 downto 0) & DATA_IN;
92 | bit_count <= bit_count +1;
93 | if (bit_count = 10) then
94 | TMP_VAL_1 <= tmpValue;
95 | trigger_count <= 0;
96 | bit_count <= 0;
97 | check_bit <= '0';
98 | finish <= '1';
99 | start <= '0';
100 | end if;
101 | else -- ERRORgen
102 | CTL_ERROR <= x"45";
103 |
104 | end if;
105 | end if;
106 | elsif (finish = '1' and start ='0') then
107 | nextstatus <= finish_mess;
108 |
109 | end if;
110 | when finish_mess =>
111 | WRITE_ENABLE <= '1';
112 | CTL_STATE <= "01";-- fertig
113 | nextstatus <= idle;
114 | end case;
115 | end if;
116 | end Process;
117 |
118 | TMP_VAL <= TMP_VAL_1;
119 |
120 | end Behavioral;
