1 | int main(void)
2 | {
3 | struct dma_channel_config config;
4 |
5 | pmic_init();
6 | board_init();
7 | sysclk_init();
8 | sleepmgr_init();
9 |
10 | // USART options.
11 | static usart_rs232_options_t USART_SERIAL_OPTIONS = {
12 | .baudrate = USART_SERIAL_EXAMPLE_BAUDRATE,
13 | .charlength = USART_SERIAL_CHAR_LENGTH,
14 | .paritytype = USART_SERIAL_PARITY,
15 | .stopbits = USART_SERIAL_STOP_BIT
16 | };
17 |
18 | // Initialize usart driver in RS232 mode
19 | usart_init_rs232(USART_SERIAL_EXAMPLE, &USART_SERIAL_OPTIONS);
20 |
21 | uint8_t tx_buf[] = "\nHello AVR world ! :";
22 | uint8_t tx_length = 20;
23 | uint8_t i = 0;
24 | for (i = 0; i < tx_length; i++) {
25 | usart_putchar(USART_SERIAL_EXAMPLE, tx_buf[i]);
26 | }
27 |
28 | dma_enable();
29 |
30 | dma_set_callback(DMA_CHANNEL, example_dma_transfer_done);
31 |
32 | /* Make sure config is all zeroed out so we don't get any stray bits */
33 | memset(&config, 0, sizeof(config));
34 |
35 | /*
36 | * This example will configure a DMA channel with the following
37 | * settings:
38 | * - CHANGED: High interrupt priority
39 | * - 1 byte burst length
40 | * - DMA_BUFFER_SIZE bytes for each transfer
41 | * - CHANGED: Reload source only (not destination) address at end of each transfer
42 | * - CHANGED: Increment only source (not destination) address during transfer
43 | * - Source address is set to \ref source
44 | * - Destination address is set to \ref destination
45 | */
46 | dma_channel_set_interrupt_level(&config, DMA_INT_LVL_HI);
47 | dma_channel_set_burst_length(&config, DMA_CH_BURSTLEN_1BYTE_gc);
48 | dma_channel_set_transfer_count(&config, DMA_BUFFER_SIZE);
49 | //dma_channel_set_single_shot(&config);
50 |
51 | dma_channel_set_src_reload_mode(&config,DMA_CH_SRCRELOAD_TRANSACTION_gc);
52 | dma_channel_set_dest_reload_mode(&config,DMA_CH_DESTRELOAD_NONE_gc);
53 | dma_channel_set_src_dir_mode(&config, DMA_CH_SRCDIR_INC_gc);
54 | dma_channel_set_dest_dir_mode(&config, DMA_CH_DESTDIR_FIXED_gc);
55 | dma_channel_set_source_address(&config, (uint16_t)(uintptr_t)source);
56 | //dma_channel_set_destination_address(&config, (uint16_t)(uintptr_t)destination);
57 | uint16_t uartc0_data_addr = 0x08A0; //USARTC0_DATA
58 | dma_channel_set_destination_address(&config, uartc0_data_addr);
59 | dma_channel_set_trigger_source(&config, DMA_CH_TRIGSRC_USARTC0_DRE_gc);
60 | //USARTC0.CTRLA |= USART_DREINTLVL0_bm;
61 |
62 | dma_channel_write_config(DMA_CHANNEL, &config);
63 |
64 | /* Use the configuration above by enabling the DMA channel in use. */
65 | dma_channel_enable(DMA_CHANNEL);
66 |
67 | cpu_irq_enable();
68 |
69 | while (true) {
70 | }
71 | }
