Hallo, guten Tag.
Ich bekomme es nicht hin, RS_Data in das speicher_ram zu packen.
Ich habe meine VHDL wieder verworfen, weil es keinen richtigen Anfang
gibt.
Wer kann da mal helfen?
Die RS232-Empfangsroutine funktioniert im Test weil die LED so blinken
wie die Daten vorhanden sind.
Danke.
Gruss
1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.NUMERIC_STD.ALL;
4 |
5 | entity ram_array is
6 | Generic ( Quarz_Taktfrequenz : integer := 50000000;
7 | Baudrate : integer := 9600
8 | );
9 | port(
10 | clk : in std_logic;
11 | RXD : in STD_LOGIC;
12 | );
13 | end ram_array;
14 |
15 | architecture Behavioral of ram_array is
16 |
17 | signal rxd_sr : std_logic_vector (3 downto 0) := "1111";
18 | signal rxsr : std_logic_vector (7 downto 0) := "00000000";
19 | signal rxbitcnt : integer range 0 to 9 := 9;
20 | signal rxcnt : integer range 0 to (Quarz_Taktfrequenz/Baudrate)-1;
21 | signal RX_Data : STD_LOGIC_VECTOR (7 downto 0);
22 | signal RX_Busy : STD_LOGIC;
23 |
24 | Type Ram128x8 is ARRAY (0 to 127) OF unsigned(7 downto 0);
25 | signal speicher_ram : Ram128x8;
26 |
27 | signal RamAddr: integer range 0 to 127 := 0;
28 |
29 | begin
30 |
31 | process(clk)
32 | begin
33 | .................
34 | .................
35 | end process;
36 |
37 | process(clk)
38 | begin
39 | if rising_edge(clk) then
40 | rxd_sr <= rxd_sr(rxd_sr'left-1 downto 0) & RXD;
41 | if (rxbitcnt<9) then
42 | if(rxcnt<(Quarz_Taktfrequenz/Baudrate)-1) then
43 | rxcnt <= rxcnt+1;
44 | else
45 | rxcnt <= 0;
46 | rxbitcnt <= rxbitcnt+1;
47 | rxsr <= rxd_sr(rxd_sr'left-1) & rxsr(rxsr'left downto 1);
48 | end if;
49 | else
50 | if (rxd_sr(3 downto 2) = "10") then
51 | rxcnt <= ((Quarz_Taktfrequenz/Baudrate)-1)/2;
52 | rxbitcnt <= 0;
53 | end if;
54 | end if;
55 | end if;
56 | end process;
57 |
58 | RX_Data <= rxsr;
59 | RX_Busy <= '1' when (rxbitcnt<9) else '0';
60 | end Behavioral;
