Moving Average zu langsam
Gast #3679861
Hallo Zusammen,
in meinem Design habe ich ein Moving Average Filter, das bisher so
aussieht:
library IEEE;
use IEEE.Std_Logic_1164.all;
use IEEE.Numeric_std.all;
use IEEE.math_real.log2;
use IEEE.math_real.ceil;
entity moving_average is
   generic (
      c_width          : integer := 14;               -- Bit width of input values
      c_average_depth   : integer := 4                 -- Amount of averaging
   port (
      CLK           : in  std_logic;
      RESET         : in  std_logic;
      DATA_IN       : in  std_logic_vector(c_width - 1 downto 0);               -- Data input
      VALID_IN      : in  std_logic;                              -- Data valid input
      DATA_OUT      : out std_logic_vector(c_width - 1 downto 0);               -- Data output
      DATA_OUT_LONG : out std_logic_vector(c_width + (integer(ceil(log2(real(c_average_depth))))) - 1 downto 0) -- Data output (not rounded to input with)
end moving_average;
24
architecture rtl of moving_average is
25
26
  constant c_count_width : integer := integer(ceil(log2(real(c_average_depth))));
27
  type   taverage_array is array (c_average_depth - 1 downto 0) of unsigned(c_width - 1 downto 0);
28
    signal s_average_array : taverage_array   := (others => (others => '0'));
29
  signal s_add_reg : unsigned(c_width + c_count_width - 1 downto 0) := (others => '0');
30
31
begin
32
33
  pfifo : process (CLK) is
34
    variable i : integer range 0 to c_average_depth - 1 := 0;
35
  begin
36
    if rising_edge (CLK) then
37
      if RESET = '1' then
38
        s_average_array <= (others => (others => '0'));
39
      else
40
        if VALID_IN = '1' then
41
          s_average_array(0) <= unsigned(DATA_IN);
42
          for i in 0 to c_average_depth - 2 loop
43
            s_average_array(i+1) <= s_average_array(i);
44
          end loop;
45
        end if;
46
      end if;
47
    end if;
48
  end process pfifo;
49
50
  padd : process (s_average_array)
51
    variable v_add_reg_temp : unsigned(c_width + c_count_width - 1 downto 0) := (others => '0');
52
  begin
53
    v_add_reg_temp := (others => '0');
54
    for i in 0 to c_average_depth - 1 loop
55
      v_add_reg_temp := v_add_reg_temp + s_average_array(i);
56
    end loop;
57
    s_add_reg <= v_add_reg_temp;
58
  end process padd;
59
60
   DATA_OUT      <= std_logic_vector(s_add_reg(c_width + c_count_width - 1 downto c_count_width));
61
   DATA_OUT_LONG <= std_logic_vector(s_add_reg);
62
63
end rtl;
Wird hier z.B. der gleitende Mittelwert über 4-8 Werte gebildet,
funktioniert die Sache super. Nun muss ich aber über 64 Werte mitteln.
Da aus einem anderen Porzess getaktet auf "DATA_OUT" zugegriffen wird,
ist das Design viel zu langsam - etwa 13MHz auf einem Spartan 3e (es
müsste mindestens 25 schaffen). Eine Möglichkeit wäre, nicht den jeweils
ersten Wert von der Summe abzuziehen, sondern den Mittelwert. Gibt es
einen Weg das Design schneller zu machen, ohne auf diesen Trick zurück
zu greifen?
Danke und viele Grüße
Achim
#3679884
einen etwas anderen Ansatz: du musst ja nicht jedesmal die komplette
Summe berechnen, sondern nur den neuen Wert dazu addieren und den n't
letzten Wert abziehen, du musst ja eh alle Werte speichern
pseudocode:
summe += neu
summe -= alt(n)
for (k=1;k<=n;k++)
  alt(k-1) = alt(k)
alt(0) = neu
mittelwert = summe / n
finde leider den Link zu dem Beispiel gerade nicht
Moderator (Firma: Titel) Persönliche Seite #3680083
Achim schrieb:
> könnte man xst eigentlich dazu bringen, dass Shift Register in ein BRAM
> zu packen?
Ja. Dazu müsstest du nur die Beschreibung so ändern, dass die Synthese
ein BRAM erkennt. Siehe dort:
http://www.lothar-miller.de/s9y/archives/20-RAM.html
Und im XST Users Guide...
Eine ressourcensparende Alternative wäre auch, ein PT1 Glied
nachzubilden. Das ist dann ein Zweizeiler wie im
Beitrag "Re: CPLD-Problem: moving average"
Gast #3680867
Achim schrieb:
> Was mir grade noch einfällt: könnte man xst eigentlich dazu bringen,
> dass Shift Register in ein BRAM zu packen?
Nimm den reset raus:
      if RESET = '1' then
      else
Dein Ziel sollte allerdings kein mapping auf BRAM sondern auf
Distributed RAM liegen, eigentlich auf SRL16. Gegenfalls kannst du ja
ein FIFO per coregen generieren und einbauen, da hat es die Synthese
einfacher.
MfG,
Gast #3680965
>> zu packen?
Oder noch einfacher:
Einen Haken bei XST Setting "pack slice logic into unused BRAM" setzen.
Gast #3681200
VHDL-Fredi schrieb im Beitrag #3680965:
>>> zu packen?
Ein Shift register ist keine logic, das funktioniert also nicht.
Diese Funktion map nur Logic also was sich als LUT beschreiben läßt in
einen (read-only) memory. Die logische Funktion wird bei FPGA start in
den ROM "geschrieben". Ob '+' so ohne weiteres zu einer LUT umgewandelt
wird, bezweifle ich. Gegegebenfalls müsste man die Addition als logische
Funktion hinschreiben. Vorher mal abschätzen wie groß die LUT wird.
MfG,
