Hello, I am having some problems to read the '0' logic values from the DIP Swithches with an ALTERA Cyclone IV FPGA. I always read '1' logic whatever position is configured in the switches DIP Switches are connected in this way, When they are ON, both sides of the SW are connected to VDD throughr a resistor. Therefore the FPGA read "VDD". And when they are OFF, the pin of the FPGA is open circuit. I mean there is not any connection to ground through the SW. Simply, the DIP SW open the circuit and leave the FPGA pin without any connection...I measured in the pon of the FPGA and I got 20mV. In theory this should be read like a '0' logic, right? What could be the problem? Is there any special constraint that I have to add to my pin assgnments file? Note: I've also tried to connect manually the PIN of the FPGA to GND and then the FPGA read '0'. Thanks a lot!
You need to add a pulldown resistor externally or internallly.
Hi! thank you very much for your But In Altera FPGAs it is impossible to set up programmable pull DOWN resistors. right? thanks
Hi I am using a custom board designed by one of the engineers of my company. We are using this model of Cyclone IV: EP4CE15F23C7N. I think that it is no possible to set up internal pull down resistors... Thanks
Enrique schrieb: > Hi > > I am using a custom board designed by one of the engineers of my > company. We are using this model of Cyclone IV: EP4CE15F23C7N. I think > that it is no possible to set up internal pull down resistors... > Then you should call for a flocking, not below 100 hits. This > DIP Switches are connected in this way, When they are ON, both sides of > the SW are connected to VDD throughr a resistor. Therefore the FPGA read > "VDD". is not how you connect a DIP Switch. Since the Cyclone IV indeed has no pulldown capability, you need to add an external resistor.
> I think > that it is no possible to set up internal pull down resistors... You are right. There is no such option. You may switch one pin to 'out' and '0'. Then You have to switch this permanent on. Then You will be able to read '0' from the other switches. Is Your coworker chinese? The same mistake was made on a Cyclone evalboard from China... I used SMD resistors and a piece of wire for a external pull down.
hi thanks for your quick answer. I was thinking about another smarter solution. All the possible solutions given need to modifz the HW. So then I would like to do something which not requires a big modifiation with a lot of resistances and wires... This is the current connection between the FPGA and the DiP SW: | _3.3v | | | _|_ | | | | |__| | | | / | FPGA ___|___/ _________| | | | Then I could remove the 3.3V, tie to ground this and place a 0ohm resistance. Therefore, using the internal weak pull-up resistance of the FPGA I will have the DIP SW working in the way that I want... _0v | | 3.3v | _|_ _|_ | | | Ohm weak | | | |__| pull-up |_| | | | | / | _ |_FPGA_|____/ _________| | | | But I am afraid about one issue. Maybe the internal weak pull-up resistance of the FPGA is too weak and it is not able to put a logic ¨1¨ when the SW is closed.. What do you think?> Thanks
Enrique schrieb im Beitrag #3687085: > hi thanks for your quick answer. > > > Then could I remove the 3.3V, tie to ground this and place a 0ohm > resistance. Then using the internal weak pull-up resistance of the FPGA > I will have the DIP SW working in the way that I want... > > _0v > | | > 3.3v | _|_ > _|_ | | | Ohm > weak | | | |__| > pull-up |_| | | > | | / | > _ |_FPGA_|____/ _________| > | > | > | > > But I am afraid about one issue, Maybe the internal weak pull-up > resistance of the FPGA is too weak and it is not able to put a logic ¨1¨ > when the SW is closed.. > > What do you think? > This is fine, as it resembles the usual way to do this. Switch to GND and pullup to VCC. But make sure that in a respin of the board an external resitor is added for better noise margin. (There will be a respin, as you will probably find more bugs) Be aware, for switch closed you will read a 0, for switch open you will read a 1! This is inverted from the original intention.
it works!!!! Nices solution this!!! Thanks for ur ideas!!!
