1 | #include <avr/io.h>
2 | #include <util/delay.h>
3 | #include <avr/interrupt.h>
4 | #include <stdlib.h>
5 | #include <avr/sleep.h>
6 |
7 | void SPI_MasterInit(void)
8 | {
9 | DDRB |= (1<<DDB5) | (1<<DDB7); //MOSI und SCKL als Ausgang setzen
10 | SPCR = (1<<SPE) | (1<<DORD) | (1<<MSTR) | (1<<CPOL) | (1<<CPHA) | (1<<SPR1) | (1<<SPR0); //aktiviere SPI als Master mit 125kHz
11 | PORTB &= ~(1<<PB0); //LCD resetten
12 | _delay_ms(10);
13 | PORTB |= (1<<PB0);
14 | _delay_ms(10);
15 | }
16 |
17 | void SPI_Transmit(char Data)
18 | {
19 | SPDR = Data; //Daten ins SPI-Register
20 | while(!(SPSR & (1<<SPIF))); //warte bis Daten weg sind
21 | }
22 |
23 | void LCD_Write_Instr(char instr)
24 | {
25 | SPI_Transmit(0x1F); //sende 5 synchronisations-bits, RS = 0, R/W = 0
26 | SPI_Transmit(instr & 0x0F); //sende untere daten-bits
27 | SPI_Transmit((instr >> 4) & 0x0F); //sende obere daten-bits
28 | _delay_us(500);
29 | }
30 |
31 | void LCD_Write_Data(char data)
32 | {
33 | SPI_Transmit(0x5F); //sende 5 synchronisations-bits, RS = 1, R/W = 0
34 | SPI_Transmit(data & 0x0F); //sende untere daten-bits
35 | SPI_Transmit((data >> 4) & 0x0F); //sende obere daten-bits
36 | _delay_us(500);
37 | }
38 |
39 | void SetPos(unsigned char Zeile, unsigned char Spalte)
40 | {
41 | switch(Zeile)
42 | {
43 | case 1: LCD_Write_Instr(0x80 + Spalte-1);
44 | break;
45 | case 2: LCD_Write_Instr(0xA0 + Spalte-1);
46 | break;
47 | case 3: LCD_Write_Instr(0xC0 + Spalte-1);
48 | break;
49 | case 4: LCD_Write_Instr(0xE0 + Spalte-1);
50 | break;
51 | default: LCD_Write_Instr(0x80);
52 | break;
53 | }
54 | }
55 |
56 | void ClrDisplay(void)
57 | {
58 | LCD_Write_Instr(0x01);
59 | LCD_Write_Instr(0x80);
60 | }
61 |
62 | void LCD_Zahl(unsigned int daten)
63 | {
64 | unsigned char byt=0;
65 | unsigned int stelle=1000;
66 |
67 | while(stelle > 1)
68 | {
69 | byt = daten / stelle;
70 | daten = daten - (unsigned char) byt * stelle;
71 | LCD_Write_Data(byt + 48);
72 | stelle = stelle / 10;
73 | }
74 | LCD_Write_Data(daten + 48);
75 | }
76 |
77 |
78 | int main(void)
79 | {
80 | DDRB |= (1<<DDB0) | (1<<DDB1); //Reset fürs LCD und LED
81 | PORTB |= (1<<PB0) | (1<<PB1);
82 |
83 | ACSR |= (1<<ACD); //Analog Komparator deaktivieren
84 |
85 | _delay_ms(1000);
86 | SPI_MasterInit();
87 |
88 | LCD_Write_Instr(0x3A); //8-Bit data length extension Bit RE=1; REV=0
89 | LCD_Write_Instr(0x09); //4 line display
90 | LCD_Write_Instr(0x06); //Bottom view
91 | LCD_Write_Instr(0x1E); //Bias setting BS1=1
92 | LCD_Write_Instr(0x39); //8-Bit data length extension Bit RE=0; IS=1
93 | LCD_Write_Instr(0x1B); //BS0=1 -> Bias=1/6
94 | LCD_Write_Instr(0x6E); //Devider on and set value
95 | LCD_Write_Instr(0x57); //Booster on and set contrast (BB1=C5, DB0=C4)
96 | LCD_Write_Instr(0x72); //Set contrast (DB3-DB0=C3-C0)
97 | LCD_Write_Instr(0x38); //8-Bit data length extension Bit RE=0; IS=0
98 | LCD_Write_Instr(0x0C); //display on, cursor off, blink off
99 | LCD_Write_Instr(0x01); //Clear Display
100 |
101 | unsigned int i=0;
102 |
103 | while(1)
104 | {
105 | SetPos(2,9);
106 | LCD_Zahl(i);
107 | if(i>9999) i=0;
108 | else i++;
109 |
110 | PORTB ^= (1<<PB1);
111 | _delay_ms(100);
112 | }
113 | return(0);
114 | }
