1 | //#define INIT_A
2 | //#define INIT_B
3 | //#define INIT_C
4 | //#define INIT_D
5 | //#define SQRT_2
6 | //#define SQRT_3
7 | using System;
8 | using System.Text;
9 |
10 | namespace NTLM
11 | {
12 | internal class _NTLM
13 | {
14 | private const uint INIT_A = 0x67452301;
15 | private const uint INIT_B = 0xefcdab89;
16 | private const uint INIT_C = 0x98badcfe;
17 | private const uint INIT_D = 0x10325476;
18 | private const uint SQRT_2 = 0x5a827999;
19 | private const uint SQRT_3 = 0x6ed9eba1;
20 |
21 | //private static uint[] nt_buffer = new uint[16];
22 | //private static uint[] output = new uint[4];
23 | //private static char[] hex_format = new char[34];
24 | //public static string result = "";
25 | //private static string itoa16 = "0123456789abcdef";
26 | //***************************************************************
27 |
28 | //public static void NTLM(string key)
29 | public static string Crypt(string key)
30 | {
31 | //int i = 0;
32 | //int length = key.Length;
33 |
34 | //memset(nt_buffer, 0, 16 * 4);
35 | //for (int z = 0; z < nt_buffer.Length; z++)
36 | //{
37 | // nt_buffer[z] = 16*4;
38 | //}
39 |
40 | // The length of key need to be <= 27 (bytes)
41 | // oder 13 char in C#
42 | if (key.Length > 13)
43 | key = key.Substring(0, 13);
44 |
45 | //for (; i < length/2; i++)
46 | //{
47 | // nt_buffer[i] = Convert.ToUInt32(key[2*i] | (key[2*i + 1] << 16));
48 | //}
49 | //if (length%2 == 1)
50 | //{
51 | // nt_buffer[i] = Convert.ToUInt32(key[length - 1] | 0x800000);
52 | //}
53 | //else
54 | //{
55 | // nt_buffer[i] = 0x80;
56 | //}
57 | ////put the length
58 | //nt_buffer[14] = Convert.ToUInt32(length << 4);
59 |
60 | var nt_buffer = new uint[16];
61 |
62 | // strings in C# sind IMMER Unicode, d.h. 1 char sind immer 2 bytes!
63 | var i = 0;
64 | foreach (var item in key)
65 | {
66 | var bytes = BitConverter.GetBytes(item);
67 | nt_buffer[i] = (uint)(bytes[0] | (bytes[1] << 16));
68 | i++;
69 | }
70 | nt_buffer[i] = 0x80;
71 | nt_buffer[14] = Convert.ToUInt32(key.Length << 4);
72 | // evtl. ist die folgende Zeile richtig und die vorhergehende falsch??
73 | //nt_buffer[i+1] = Convert.ToUInt32(key.Length << 4);
74 |
75 | uint a = INIT_A;
76 | uint b = INIT_B;
77 | uint c = INIT_C;
78 | uint d = INIT_D;
79 |
80 | /* Round 1 */
81 | a += (d ^ (b & (c ^ d))) + nt_buffer[0]; a = (a << 3) | (a >> 29);
82 | d += (c ^ (a & (b ^ c))) + nt_buffer[1]; d = (d << 7) | (d >> 25);
83 | c += (b ^ (d & (a ^ b))) + nt_buffer[2]; c = (c << 11) | (c >> 21);
84 | b += (a ^ (c & (d ^ a))) + nt_buffer[3]; b = (b << 19) | (b >> 13);
85 |
86 | a += (d ^ (b & (c ^ d))) + nt_buffer[4]; a = (a << 3) | (a >> 29);
87 | d += (c ^ (a & (b ^ c))) + nt_buffer[5]; d = (d << 7) | (d >> 25);
88 | c += (b ^ (d & (a ^ b))) + nt_buffer[6]; c = (c << 11) | (c >> 21);
89 | b += (a ^ (c & (d ^ a))) + nt_buffer[7]; b = (b << 19) | (b >> 13);
90 |
91 | a += (d ^ (b & (c ^ d))) + nt_buffer[8]; a = (a << 3) | (a >> 29);
92 | d += (c ^ (a & (b ^ c))) + nt_buffer[9]; d = (d << 7) | (d >> 25);
93 | c += (b ^ (d & (a ^ b))) + nt_buffer[10]; c = (c << 11) | (c >> 21);
94 | b += (a ^ (c & (d ^ a))) + nt_buffer[11]; b = (b << 19) | (b >> 13);
95 |
96 | a += (d ^ (b & (c ^ d))) + nt_buffer[12]; a = (a << 3) | (a >> 29);
97 | d += (c ^ (a & (b ^ c))) + nt_buffer[13]; d = (d << 7) | (d >> 25);
98 | c += (b ^ (d & (a ^ b))) + nt_buffer[14]; c = (c << 11) | (c >> 21);
99 | b += (a ^ (c & (d ^ a))) + nt_buffer[15]; b = (b << 19) | (b >> 13);
100 |
101 | /* Round 2 */
102 | a += ((b & (c | d)) | (c & d)) + nt_buffer[0] + SQRT_2; a = (a << 3) | (a >> 29);
103 | d += ((a & (b | c)) | (b & c)) + nt_buffer[4] + SQRT_2; d = (d << 5) | (d >> 27);
104 | c += ((d & (a | b)) | (a & b)) + nt_buffer[8] + SQRT_2; c = (c << 9) | (c >> 23);
105 | b += ((c & (d | a)) | (d & a)) + nt_buffer[12] + SQRT_2; b = (b << 13) | (b >> 19);
106 |
107 | a += ((b & (c | d)) | (c & d)) + nt_buffer[1] + SQRT_2; a = (a << 3) | (a >> 29);
108 | d += ((a & (b | c)) | (b & c)) + nt_buffer[5] + SQRT_2; d = (d << 5) | (d >> 27);
109 | c += ((d & (a | b)) | (a & b)) + nt_buffer[9] + SQRT_2; c = (c << 9) | (c >> 23);
110 | b += ((c & (d | a)) | (d & a)) + nt_buffer[13] + SQRT_2; b = (b << 13) | (b >> 19);
111 |
112 | a += ((b & (c | d)) | (c & d)) + nt_buffer[2] + SQRT_2; a = (a << 3) | (a >> 29);
113 | d += ((a & (b | c)) | (b & c)) + nt_buffer[6] + SQRT_2; d = (d << 5) | (d >> 27);
114 | c += ((d & (a | b)) | (a & b)) + nt_buffer[10] + SQRT_2; c = (c << 9) | (c >> 23);
115 | b += ((c & (d | a)) | (d & a)) + nt_buffer[14] + SQRT_2; b = (b << 13) | (b >> 19);
116 |
117 | a += ((b & (c | d)) | (c & d)) + nt_buffer[3] + SQRT_2; a = (a << 3) | (a >> 29);
118 | d += ((a & (b | c)) | (b & c)) + nt_buffer[7] + SQRT_2; d = (d << 5) | (d >> 27);
119 | c += ((d & (a | b)) | (a & b)) + nt_buffer[11] + SQRT_2; c = (c << 9) | (c >> 23);
120 | b += ((c & (d | a)) | (d & a)) + nt_buffer[15] + SQRT_2; b = (b << 13) | (b >> 19);
121 |
122 | /* Round 3 */
123 | a += (d ^ c ^ b) + nt_buffer[0] + SQRT_3; a = (a << 3) | (a >> 29);
124 | d += (c ^ b ^ a) + nt_buffer[8] + SQRT_3; d = (d << 9) | (d >> 23);
125 | c += (b ^ a ^ d) + nt_buffer[4] + SQRT_3; c = (c << 11) | (c >> 21);
126 | b += (a ^ d ^ c) + nt_buffer[12] + SQRT_3; b = (b << 15) | (b >> 17);
127 |
128 | a += (d ^ c ^ b) + nt_buffer[2] + SQRT_3; a = (a << 3) | (a >> 29);
129 | d += (c ^ b ^ a) + nt_buffer[10] + SQRT_3; d = (d << 9) | (d >> 23);
130 | c += (b ^ a ^ d) + nt_buffer[6] + SQRT_3; c = (c << 11) | (c >> 21);
131 | b += (a ^ d ^ c) + nt_buffer[14] + SQRT_3; b = (b << 15) | (b >> 17);
132 |
133 | a += (d ^ c ^ b) + nt_buffer[1] + SQRT_3; a = (a << 3) | (a >> 29);
134 | d += (c ^ b ^ a) + nt_buffer[9] + SQRT_3; d = (d << 9) | (d >> 23);
135 | c += (b ^ a ^ d) + nt_buffer[5] + SQRT_3; c = (c << 11) | (c >> 21);
136 | b += (a ^ d ^ c) + nt_buffer[13] + SQRT_3; b = (b << 15) | (b >> 17);
137 |
138 | a += (d ^ c ^ b) + nt_buffer[3] + SQRT_3; a = (a << 3) | (a >> 29);
139 | d += (c ^ b ^ a) + nt_buffer[11] + SQRT_3; d = (d << 9) | (d >> 23);
140 | c += (b ^ a ^ d) + nt_buffer[7] + SQRT_3; c = (c << 11) | (c >> 21);
141 | b += (a ^ d ^ c) + nt_buffer[15] + SQRT_3; b = (b << 15) | (b >> 17);
142 |
143 | var output = new uint[4];
144 | output[0] = a + INIT_A;
145 | output[1] = b + INIT_B;
146 | output[2] = c + INIT_C;
147 | output[3] = d + INIT_D;
148 |
149 | //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
150 | // Convert the hash to hex (for being readable)
151 | //~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
152 | //for (i = 0; i < 4; i++)
153 | //{
154 | // int j = 0;
155 | // uint n = output[i];
156 | // //iterate the bytes of the integer
157 | // for (; j < 4; j++)
158 | // {
159 | // uint convert = n%256;
160 | // hex_format[i*8 + j*2 + 1] = itoa16[Convert.ToInt16(convert%16)];
161 | // convert = convert/16;
162 | // hex_format[i*8 + j*2 + 0] = itoa16[Convert.ToInt16(convert%16)];
163 | // n = n/256;
164 | // }
165 | //}
166 | ////null terminate the string
167 | //hex_format[33] = "0".ToCharArray()[0];
168 | //foreach (char k in hex_format)
169 | //{
170 | // result += k.ToString();
171 | //}
172 | var buffer = new StringBuilder();
173 | foreach (var o in output)
174 | {
175 | buffer.Append(o.ToString("X8"));
176 | }
177 | return buffer.ToString();
178 | }
179 |
180 | //internal static partial class DefineConstants
181 | //{
182 | // public const int INIT_A = 0x67452301;
183 | // public const long INIT_B = 0xefcdab89;
184 | // public const long INIT_C = 0x98badcfe;
185 | // public const int INIT_D = 0x10325476;
186 | // public const int SQRT_2 = 0x5a827999;
187 | // public const int SQRT_3 = 0x6ed9eba1;
188 | //}
189 | }
190 | }
