1 | #include "io430.h"
2 | #include "stdlib.h"
3 | #include <stdint.h> // Integers of defined sizes
4 | #include <math.h>
5 | #include <float.h>
6 | #define Vobj 0x00;
7 | #define Temp 0x01;
8 | #define Conf 0x02;
9 |
10 | /// P2.5 => switches on
11 | // after switch on, chech left and right, delay ~0.25 s
12 | //if all touch buttons idle=> start measurments
13 | // if set temperature is acchived=> go stand by with delay of 12 s
14 | void I2C_SEND (int address, int pointer);
15 | void I2C_REC () ;
16 | void Measure() ;
17 | uint8_t LowerByte,UpperByte;
18 | int16_t Voltage;
19 | int Temperature;
20 | void Calc(int T, int P);
21 | void Touch_Sample(uint8_t BTN);
22 | void Touch_Start(uint8_t BTN);
23 | long double Result;
24 | int SetTemp=20;//default temperature
25 | uint16_t SampleTime;
26 | uint8_t R,G,B=0;
27 | uint8_t BTN_SLT =BIT5; // P2.5 (centre)
28 | uint16_t delay=0xFFFF ;
29 | int FLAG = 0;
30 | int wait =10;
31 | void StandBy(int Value);
32 | void Send_1();
33 | void Send_0();
34 | void LED_RST();
35 | void LED_CTRL(int red, int green, int blue);
36 | main( void )
37 | {
38 |
39 | WDTCTL = WDTPW|WDTHOLD; // Stop watchdog timer to prevent time out reset
40 | BCSCTL1 |= RSEL0|RSEL1|RSEL2|RSEL3;
41 | BCSCTL2 = SELM_3|SELS; // VCO as SMCLK,DCO as MCLK
42 | BCSCTL3 = LFXT1S_2; //USE VCO as LFXT (ACLK)
43 | P1OUT =0x0 ; //LOW
44 | P2OUT =0x0; //LOW
45 | P1DIR =0xFF; //output
46 | P2DIR =0xFF; //output
47 | P2SEL = 0;
48 | P2SEL2 = 0;
49 | TACTL |= TASSEL0|TAIE; // Timer clock ACLK
50 | //I2C Configuration//
51 | USICKCTL |= USISSEL_1|USICKPL; // SMLCK, IdleState=Low
52 | USICTL1 |= USII2C; // I2C Mode
53 | USICTL0 = USIPE7|USIPE6|USIMST; // Enable SDO/SDI/SCLK etc, master mode
54 | while(1){
55 | __enable_interrupt();
56 | StandBy(delay) ;// start timer in standby mode
57 | if(FLAG ==1){ //touch detected
58 | Measure(); //measure temp.
59 | }
60 | __low_power_mode_3();
61 |
62 |
63 | }
64 | }
65 | #pragma vector = TIMER0_A1_VECTOR
66 | __interrupt void TIMER0_A1_ISR (void) // ISR for TACCR1 CCIFG and TAIFG
67 | {
68 | Touch_Start(BTN_SLT);
69 |
70 | }
71 | #pragma vector = WDT_VECTOR
72 | __interrupt void WDT (void)
73 | {
74 | Touch_Sample(BTN_SLT);
75 | __bic_SR_register_on_exit(CPUOFF);
76 | }
77 | void Measure (){
78 |
79 | P1OUT|=BIT1; //acivate TMP006
80 | LED_CTRL(0,0,150);
81 |
82 | __delay_cycles(15000000);
83 | I2C_SEND(0x80,0x01) ; // get temp
84 | __delay_cycles(100) ;
85 | I2C_REC() ;
86 | Temperature =(UpperByte<<8) | LowerByte; //merge 2x8Bits
87 | Temperature = Temperature>>2;
88 | I2C_SEND(0x80,0x00) ; //get voltage
89 | __delay_cycles(100) ;
90 | I2C_REC() ;
91 | Voltage =(UpperByte<<8) | LowerByte;
92 | //Calculate object temperature//
93 | Calc(Temperature, Voltage);
94 | P1OUT &=~BIT1;
95 | if(Result>SetTemp){ //exit measument mode
96 | FLAG=0;
97 | delay=0xFFFF;
98 | LED_CTRL(0,200,0);
99 | __delay_cycles(1000000);
100 |
101 | }
102 |
103 | }
104 | void I2C_SEND (int address, int pointer ) {
105 | USICNT &=~USI16B; //8 bit register
106 | USISRH =0;
107 | USISRL =0;
108 | USICTL0 |=USIGE|USIOE ; //Latch/SDA output enabled
109 | USICTL0 &=~USIGE; // Latch disabled
110 | USISR = address; // send address first
111 | USICTL0 |= USIOE; //output enable
112 | USICNT =8;
113 | while((USICTL1&USIIFG)==0) {} // wait till finish
114 | USICTL0 &=~USIOE;
115 | USICNT=1;
116 | while((USICTL1&USIIFG)==0) {} //wait ack
117 | USISR = pointer; //send pointer
118 | USICTL0 |= USIOE;
119 | USICNT =8;
120 | while((USICTL1&USIIFG)==0) {} // wait till finish
121 | USICTL0 &=~USIOE;
122 | USICNT=1;
123 | while((USICTL1&USIIFG)==0) {} //wait ack
124 | // SEND STOP//
125 | USICTL0 |= USIOE; //output enable
126 | USISRL =0;
127 | USICNT =1;
128 | while((USICTL1&USIIFG)==0) {}
129 | USISRL= 0xFF;
130 | USICTL0 |=USIGE;
131 | USICTL0 &=~USIOE|USIGE;
132 | }
133 | void I2C_REC() {
134 | USICNT &=~USI16B; //8 bit register
135 | USISRH =0;
136 | USISRL =0;
137 | USICTL0 |=USIGE|USIOE ; //Latch/SDA output enabled
138 | USICTL0 &=~USIGE; // Latch disabled
139 | USISR = 0x81; // send address first
140 | USICTL0 |= USIOE; //output enable
141 | USICNT =8;
142 | while((USICTL1&USIIFG)==0) {} // wait till finish
143 | USICTL0 &=~USIOE;
144 | USICNT=1;
145 | //wait for ACK
146 | USICTL0 &=~USIOE;
147 | USICNT=1;
148 | while((USICTL1&USIIFG)==0) {} //wait ack
149 | USICNT=8; // receive first 8 bit
150 | while((USICTL1&USIIFG)==0) {} //wait till done
151 | // generate ACK
152 | UpperByte = USISRL;
153 | USICTL0 |= USIOE;
154 | USISRL =0;
155 | USICNT=1;
156 | while((USICTL1&USIIFG)==0) {}//wait
157 | USICTL0 &=~USIOE;
158 | USICNT=8; // receive second 8 bit
159 | while((USICTL1&USIIFG)==0) {} //wait till done
160 | //SEND STOP
161 | LowerByte =USISRL;
162 | USICTL0 |= USIOE; //output enable
163 | USISRL =0;
164 | USICNT =1;
165 | while((USICTL1&USIIFG)==0) {}
166 | USISRL= 0xFF;
167 | USICTL0 |=USIGE;
168 | USICTL0 &=~USIOE|USIGE;
169 |
170 | }
171 | void Calc(int T, int P){
172 | long double Vobj2 = (double)P*156.25*pow(10,-9);
173 | long double Tdie2 = (double)T*.03125 + 273.15;
174 | long double S0 =6.633*pow(10,-14);
175 | long double a1 = 1.75*pow(10,-3);
176 | long double a2 = -1.678*pow(10,-5);
177 | long double b0 = -2.94*pow(10,-5);
178 | long double b1 = -5.7*pow(10,-7);
179 | long double b2 =4.63*pow(10,-9);
180 | long double c2 = 13.4;
181 | long double Tref = 298.15;
182 | long double S = S0*(1+a1*(Tdie2 - Tref)+a2*pow((Tdie2 - Tref),2));
183 | long double Vos = b0 + b1*(Tdie2 - Tref) + b2*pow((Tdie2 - Tref),2);
184 | long double fObj = (Vobj2 - Vos) + c2*pow((Vobj2 - Vos),2);
185 | long double Tobj = pow(pow(Tdie2,4) + (fObj/S),.25);
186 | Result= (Tobj-273.15);
187 | }
188 | void Touch_Start(uint8_t BTN) // start touch sensing
189 | {
190 | TACTL &=~TAIE; //disable Timer interrupt
191 | WDTCTL = WDTPW|WDTHOLD|WDTCNTCL; // WDT OFF
192 | TACTL |= TASSEL1|TASSEL0|ID0; //CLOCK TACLK (oscillating pin)
193 | IE1 |=WDTIE; // Enable WDT interrupt
194 | P2SEL = 0;
195 | P2SEL2 =BTN;// oscillation on BTN
196 | WDTCTL = WDTPW|WDTTMSEL|WDTSSEL|WDTCNTCL|WDTIS1; //interval mode,ACLK,clear
197 | TACTL &=~TAIFG; // Clear flag
198 | IFG1 &=~WDTIFG;
199 | TACTL &=~MC_1;
200 | TACTL |= MC_2|TACLR; //start timer free mode
201 |
202 | }
203 | void Touch_Sample(uint8_t BTN)
204 | {
205 | TACTL &=~MC_2; // STOP TIMER
206 | P2SEL2 &=~ BTN; // Stop oscillation
207 | WDTCTL = WDTPW|WDTHOLD|WDTCNTCL; //WDT OFF
208 | IE1 &=~ WDTIE; // disable WTD interrupt
209 | SampleTime= TAR; // save sample time
210 | LED_CTRL(SetTemp,0,0);
211 |
212 | if (BTN==BIT5){ // if true switch on the deivce!!! Measure left/right pads
213 | if( SampleTime<33000){
214 | FLAG=0;
215 | wait=20;
216 | P1OUT|=BIT0;
217 | BTN_SLT=BIT4;
218 | delay=0x05FF; //dalay for touch sampling
219 | }
220 | }
221 | if (BTN==BIT4) {
222 | if(SampleTime<32000){ //touch detected? dec temp
223 | if(SetTemp>2){
224 | SetTemp=SetTemp-2;
225 | }
226 | wait =20;
227 |
228 | } else {
229 | wait--;
230 | }
231 | BTN_SLT=BIT3;
232 | if(wait==0){ //deactivate setTemp mode, measure temp
233 | FLAG=1;
234 | P1OUT &=~BIT0;
235 | BTN_SLT=BIT5;
236 | delay=0xFFFF;// delay for temp measurments
237 |
238 | }
239 | }
240 | if (BTN==BIT3) {
241 | if(SampleTime<32000){ //touch detected? inc temp
242 | if(SetTemp<85){
243 | SetTemp=SetTemp+2;
244 | }
245 | wait =20;
246 | } else {
247 | wait--;
248 | }
249 | BTN_SLT=BIT4;
250 |
251 | if(wait==0){ //deactivate setTemp mode, measure temp
252 | FLAG=1;
253 | P1OUT &=~BIT0;
254 | BTN_SLT=BIT5;
255 | delay=0xFFFF;// delay for temp measurments
256 | LED_CTRL(0,0,0);
257 |
258 | }
259 | }
260 |
261 |
262 |
263 | TACTL |= TAIE|TACLR; // Enable timer interrupt, clear flag
264 | TACTL &=~TAIFG; // Clear flag
265 | TACTL &=~TASSEL1;
266 |
267 |
268 | }
269 | void StandBy( int Value){
270 | TACCR0 = Value;
271 | TACTL|= MC_1|TACLR; // clear and start counting to TAR, stand by mode
272 | }
273 |
274 | void LED_CTRL(int red, int green, int blue) {
275 | //LED_RST();
276 | if((green&BIT7)==BIT7){
277 | Send_1();
278 | } else {
279 | Send_0();
280 | }
281 | if((green&BIT6)==BIT6){
282 | Send_1();
283 | } else {
284 | Send_0();
285 | }
286 | if((green&BIT5)==BIT5){
287 | Send_1();
288 | } else {
289 | Send_0();
290 | }
291 | if((green&BIT4)==BIT4){
292 | Send_1();
293 | } else {
294 | Send_0();
295 | }
296 | if((green&BIT3)==BIT3){
297 | Send_1();
298 | } else {
299 | Send_0();
300 | }
301 | if((green&BIT2)==BIT2){
302 | Send_1();
303 | } else {
304 | Send_0();
305 | }
306 | if((green&BIT1)==BIT1){
307 | Send_1();
308 | } else {
309 | Send_0();
310 | }
311 | if((green&BIT0)==BIT0){
312 | Send_1();
313 | } else {
314 | Send_0();
315 | }
316 | if((green&BIT7)==BIT7){
317 | Send_1();
318 | } else {
319 | Send_0();
320 | }
321 | //////////RED///////////////////////////////////////
322 | if((red&BIT6)==BIT6){
323 | Send_1();
324 | } else {
325 | Send_0();
326 | }
327 | if((red&BIT5)==BIT5){
328 | Send_1();
329 | } else {
330 | Send_0();
331 | }
332 | if((red&BIT4)==BIT4){
333 | Send_1();
334 | } else {
335 | Send_0();
336 | }
337 | if((red&BIT3)==BIT3){
338 | Send_1();
339 | } else {
340 | Send_0();
341 | }
342 | if((red&BIT2)==BIT2){
343 | Send_1();
344 | } else {
345 | Send_0();
346 | }
347 | if((red&BIT1)==BIT1){
348 | Send_1();
349 | } else {
350 | Send_0();
351 | }
352 | if((red&BIT0)==BIT0){
353 | Send_1();
354 | } else {
355 | Send_0();
356 | }
357 | ///////////////////BLUE
358 | if((blue&BIT7)==BIT7){
359 | Send_1();
360 | } else {
361 | Send_0();
362 | }
363 | if((blue&BIT6)==BIT6){
364 | Send_1();
365 | } else {
366 | Send_0();
367 | }
368 | if((blue&BIT5)==BIT5){
369 | Send_1();
370 | } else {
371 | Send_0();
372 | }
373 | if((blue&BIT4)==BIT4){
374 | Send_1();
375 | } else {
376 | Send_0();
377 | }
378 | if((blue&BIT3)==BIT3){
379 | Send_1();
380 | } else {
381 | Send_0();
382 | }
383 | if((green&BIT2)==BIT2){
384 | Send_1();
385 | } else {
386 | Send_0();
387 | }
388 | if((blue&BIT1)==BIT1){
389 | Send_1();
390 | } else {
391 | Send_0();
392 | }
393 | if((blue&BIT0)==BIT0){
394 | Send_1();
395 | } else {
396 | Send_0();
397 | }
398 |
399 |
400 |
401 | }
402 | void Send_0(){
403 | P2OUT|=BIT0; //set LED_IN HIGH
404 | __delay_cycles(3); //delay
405 | P2OUT &=~BIT0; //set LED_IN LOW
406 | __delay_cycles(8);
407 | }
408 | void Send_1(){
409 | P2OUT|=BIT0; //set LED_IN HIGH
410 | __delay_cycles(16);
411 | P2OUT &=~BIT0;
412 | __delay_cycles(1);
413 | }
414 |
415 | void LED_RST(){
416 | P2OUT|=BIT0; //set LED_IN HIGH
417 | P2OUT &=~BIT0;
418 | __delay_cycles(2000);
419 | P2OUT|=BIT0; //set LED_IN HIGH
420 |
421 | }
