1 | /************************************************************************/
2 | //Include Dateien
3 | /************************************************************************/
4 | #include <p18f46k80.h> // PIC18F46K80 auswählen
5 | #include <stdio.h> // Standard-Bibiotheken
6 | #include "SP_PIC18F46K80.H"
7 | #include "Warten_MS.C"
8 | #include "Segment.C"
9 | #include "USART.C"
10 | /************************************************************************/
11 |
12 | /************************************************************************/
13 | // Microcontroller-Konfiguration
14 | /************************************************************************/
15 | // CONFIG1L
16 | #pragma config RETEN = OFF
17 | #pragma config INTOSCSEL = LOW
18 | #pragma config SOSCSEL = DIG
19 | #pragma config XINST = OFF
20 |
21 | // CONFIG1H
22 | #pragma config FOSC = HS2 // Oscillator (HS oscillator (Medium power, 16 MHz - 25 MHz))
23 | #pragma config PLLCFG = OFF
24 | #pragma config FCMEN = OFF
25 | #pragma config IESO = OFF
26 |
27 | // CONFIG2L
28 | #pragma config PWRTEN = OFF // Power Up Timer (Disabled)
29 | #pragma config BOREN = OFF
30 | #pragma config BORV = 3 // Brown-out Reset Voltage bits (1.8V)
31 | #pragma config BORPWR = ZPBORMV // BORMV Power level (ZPBORMV instead of BORMV is selected)
32 |
33 | // CONFIG2H
34 | #pragma config WDTEN = SWDTDIS // Watchdog Timer (WDT enabled in hardware; SWDTEN bit disabled)
35 | #pragma config WDTPS = 1048576 // Watchdog Postscaler (1:1048576)
36 |
37 | // CONFIG3H
38 | #pragma config CANMX = PORTC // ECAN Mux bit (ECAN TX and RX pins are located on RB2 and RB3, respectively)
39 | #pragma config MSSPMSK = MSK7 // MSSP address masking (7 Bit address masking mode)
40 | #pragma config MCLRE = ON // Master Clear Enable (MCLR Enabled, RG5 Disabled)
41 |
42 | // CONFIG4L
43 | #pragma config STVREN = OFF // Stack Overflow Reset (Disabled)
44 | #pragma config BBSIZ = BB2K // Boot Block Size (2K word Boot Block size)
45 |
46 | // CONFIG5L
47 | #pragma config CP0 = OFF // Code Protect 00800-03FFF (Disabled)
48 | #pragma config CP1 = OFF // Code Protect 04000-07FFF (Disabled)
49 | #pragma config CP2 = OFF // Code Protect 08000-0BFFF (Disabled)
50 | #pragma config CP3 = OFF // Code Protect 0C000-0FFFF (Disabled)
51 |
52 | // CONFIG5H
53 | #pragma config CPB = OFF // Code Protect Boot (Disabled)
54 | #pragma config CPD = OFF // Data EE Read Protect (Disabled)
55 |
56 | // CONFIG6L
57 | #pragma config WRT0 = OFF // Table Write Protect 00800-03FFF (Disabled)
58 | #pragma config WRT1 = OFF // Table Write Protect 04000-07FFF (Disabled)
59 | #pragma config WRT2 = OFF // Table Write Protect 08000-0BFFF (Disabled)
60 | #pragma config WRT3 = OFF // Table Write Protect 0C000-0FFFF (Disabled)
61 |
62 | // CONFIG6H
63 | #pragma config WRTC = OFF // Config. Write Protect (Disabled)
64 | #pragma config WRTB = OFF // Table Write Protect Boot (Disabled)
65 | #pragma config WRTD = OFF // Data EE Write Protect (Disabled)
66 |
67 | // CONFIG7L
68 | #pragma config EBTR0 = OFF // Table Read Protect 00800-03FFF (Disabled)
69 | #pragma config EBTR1 = OFF // Table Read Protect 04000-07FFF (Disabled)
70 | #pragma config EBTR2 = OFF // Table Read Protect 08000-0BFFF (Disabled)
71 | #pragma config EBTR3 = OFF // Table Read Protect 0C000-0FFFF (Disabled)
72 |
73 | // CONFIG7H
74 | #pragma config EBTRB = OFF // Table Read Protect Boot (Disabled)
75 | /************************************************************************/
76 |
77 |
78 | /************************************************************************/
79 | // sonstige Deklarationen
80 | /************************************************************************/
81 | #define True 1
82 | #define False 0
83 | /************************************************************************/
84 |
85 | /************************************************************************/
86 | // Hauptprogramm
87 | /************************************************************************/
88 |
89 | void main(void)
90 | {
91 |
92 | unsigned char unc_Wert;
93 |
94 |
95 | PORTB = 0x00;
96 | LATB = 0x00;
97 | TRISB = 0x00;
98 |
99 | TRISC= 0b01011000; // PORTC initalisieren
100 | LATC= 0b01011000;
101 |
102 | Init_USART(19200);
103 |
104 | PORTD = 0x00;
105 | LATD = 0x00;
106 | TRISD = 0x00;
107 |
108 | //*************************************************************************
109 | // Start der Hauptprogramm-Schleife
110 | //*************************************************************************
111 |
112 | while(1) // Ganzes Programm ist Endlosschleife
113 | {
114 |
115 |
116 | // funktioniert
117 | //unc_Wert = 'F';
118 | //LATB = unc_Wert;
119 | //LATD = unc_Wert;
120 | //Zeichen_Anzeigen(unc_Wert);
121 |
122 | LATB = 0xFF;
123 | LATD =~ LATB;
124 |
125 | // funktioniert
126 | //LATD = 0x00;
127 | //LATB = 0x00;
128 | //Delay10KTCYx(200);
129 | //LATD = 0xFF;
130 | //LATB = 0xFF;
131 | //Delay10KTCYx(200);
132 |
133 | DA= 1;
134 | printf("%.3u", LATD
135 | printf("\r\n");
136 | DA= 0;
137 |
138 | }
139 | //************************************************************************
140 | } // Ende des Hauptprogramm
141 | //************************************************************************
