Was muss ich bitte bei "clock" ändern, es kommt eine Fehlermeldung.
Gast #3835350
Hallo, guten Tag.
Ich bekomme diese Fehlermeldung:
Error (10822): HDL error at ram_ram.vhd(58): couldn't implement
registers for assignments on
this clock edge.
Ich weis nicht, was ich da ändern soll?
Danke.
Gruss
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;
entity ram_ram is port(
  clock : in  std_logic;
  led_g : out STD_LOGIC_VECTOR(7 downto 0);
  sw0   : in  STD_LOGIC;
  sw1   : in  STD_LOGIC;
  sw2   : in  STD_LOGIC
end ram_ram;
architecture Behavioral of ram_ram is
signal we1      : STD_LOGIC :='0';
signal address1 : integer range 0 to 255 := 0;
signal datain1  : STD_LOGIC_VECTOR(7 downto 0);
signal dataout1 : STD_LOGIC_VECTOR(7 downto 0);
signal we2      : STD_LOGIC;
23
signal address2 : integer range 0 to 255 := 0;
24
signal datain2  : STD_LOGIC_VECTOR(7 downto 0);
25
signal dataout2 : STD_LOGIC_VECTOR(7 downto 0);
26
27
signal cnt      : integer range 0 to 50000000 := 0;
28
29
component ram1 port(
30
  we1      : in  STD_LOGIC;
31
  address1 : in  integer range 0 to 255 := 0;
32
  datain1  : in  STD_LOGIC_VECTOR(7 downto 0);
33
  dataout1 : out STD_LOGIC_VECTOR(7 downto 0);
34
35
36
end component;
37
38
component ram2 port(
39
  we2      : in  STD_LOGIC;
40
  address2 : in  integer range 0 to 255 := 0;
41
  datain2  : in  STD_LOGIC_VECTOR(7 downto 0);
42
  dataout2 : out STD_LOGIC_VECTOR(7 downto 0);
43
44
45
end component;
46
47
begin
48
io1 : ram1  port map(we1,address1,datain1,dataout1,clock);
49
io2 : ram2  port map(we2,address2,datain2,dataout2,clock);
50
51
process(clock)
52
variable address_z3 : integer range 0 to 255 := 0;
53
variable address_z2 : integer range 0 to 255 := 0;
54
variable address_z1 : integer range 0 to 255 := 0;
55
56
begin
57
  if rising_edge(clock) then
58
    if (cnt<20000000 and sw2='1') then
59
      cnt <= cnt+1;
60
    else
61
      cnt <= 0;
62
      we2<='0';
63
      if address_z1 <= 255 then
64
        address_z1 := address_z1 +1;
65
        address2  <=address_z1;
66
      end if;
67
    end if;
68
  end if;
69
70
  if sw0='1' then
71
    address_z1:=0;
72
    address_z2:=0;
73
    address_z3:=0;
74
  end if;
75
76
  if sw1='1' then
77
    we2<='1';
78
    if address_z2 <= 255 then
79
      address_z3 := address_z3 +1;
80
      address_z2 := address_z2 +1;
81
      address1<=address_z2;
82
      address2<=address_z3;
83
84
      datain2<=dataout1;
85
    end if;
86
  end if;
87
end process;
88
89
led_g <= dataout2;
90
end Behavioral;
Gast #3835428
>       end if;
>     end if;
Kann sein, dass das das Problem ist. Du fragst die Adresse mit
rising_edge ab und inkrementierst sie darauf hin. Da es sich dabei um
eine Variable handelt, wird diese "sofort" geupdatet und nicht erst zum
nächsten Takt.
ändere diese variablen mal in signale um, dann sollte es gehn.
#3835475
> nächsten Takt.
nope, das waer im Prinzip legitim.
Das Problem ist dass der address_z2 / address_z3 Ramsch nicht im
getakteten Teil des Prozesses stattfindet, sondern im kombinatorischen.
Zeigt wiedermal ein Vorteil der
wait until rising_edge(clock);
Schreibweise.
Cheers, Roger
Gast #3835477
Du beschreibst Register, deren Ausgänge sich zum einen mit der
Taktflanke ändern sollen, aber gleichzeitig auch unabhängig von der
Taktflanke sein sollen.
Sowas gibt es nicht
z.B. hier:
  ...  address2 <= address_z1;
  end if;
  if sw1='1' then
  ...  address2 <= address_z3;
  end if;
Gast #3835555
Danke für eure mühe.
      datain2<=dataout1;
    end if;
  end if;
end if;
end process;
Da hatte ich ein "end if;"vergessen.
jetzt werden die Rams beschrieben gelesen und angezeigt mit Led's.
Die Fehlermeldung war für mich nicht nachvollziehbar.
Danke.
Gruss
Moderator (Firma: Titel) Persönliche Seite #3835568
Du hättest es aber recht leicht anhand der Identebenen (Einrückungen)
sehen können:
process(clock)
begin
  end if;
  if sw0='1' then
  end if;
  if sw1='1' then
  end if;
end process;
led_g <= dataout2;
end Behavioral;
Die kann man nämlich gut nutzen, um seinen Quelltext verständlich und
lesbar darzustellen...
Mitnichten! Es  hat nicht gefehlt (das hätte der Synthesizer shcon
angemeckert, probiers aus), sondern es war an der falschen Stelle, so
dass du Hardware beschrieben hast, die der Synthesizer nicht umsetzen
kann.
Gast #3835628
Hmm.., verstehe ich jetzt nicht.
so war es mit der Fehlermeldung:
      datain2<=dataout1;
    end if;
  end if;
end process;
so ist es ohne der Fehlermeldung:
      datain2<=dataout1;
    end if;
  end if;
end if;
end process;
Danke.
Gruss
Moderator (Firma: Titel) Persönliche Seite #3835638
Also, nehme ich mal deine originale VHDL Beschreibung und bekomme damit:
WARNING:Xst:819 - "C:/..."  line 51: One or more signals are missing in
the process sensitivity list. ... The missing signals are:
<sw0>, <sw1>, <dataout1>
ALARM! Das hätte man bei einem getakteten Prozess nicht erwartet! Denn
da gehört nur der Takt in die Sensitivliste.
Und dann
WARNING:Xst:737 - Found 8-bit latch for signal <address_z2>. Latches
may be generated from incomplete case or if statements. We do not recommend
the use of latches in FPGA/CPLD designs, as they may lead to timing problems.
WARNING:Xst:737 - Found 8-bit latch for signal <address_z3>. Latches ....
WARNING:Xst:737 - Found 8-bit latch for signal <datain2>. Latches ....
WARNING:Xst:737 - Found 8-bit latch for signal <address1>. Latches ....
ALARM, ALARM, ALARM!!! Warum sollte es bei einem getakteten Prozess
Latches geben? Da muss irgendwas nicht passen!
Und wenn ich jetzt einfach hinten ein "end if;" anhänge, dann bekomme
ich wie erwartet einen Fehler, der genau dieses if anmeckert:
ERROR:HDLParsers:164 - "C:/...." Line 87. parse error, unexpected IF, expecting PROCESS
Ergo: du hast das "end if;" VERSCHOBEN. Und zwar so:
process(clock)
begin
      cnt <= cnt+1;
    else
      cnt <= 0;
      we2<='0';
      end if;
    end if;
--   end if;        ---------> hier raus
  if sw0='1' then
    address_z1:=0;
    address_z2:=0;
23
    address_z3:=0;
24
  end if;
25
26
  if sw1='1' then
27
    we2<='1';
28
29
30
31
32
33
34
      datain2<=dataout1;
35
    end if;
36
  end if;
37
 end if;     --      <----------  hier rein
38
39
end process;
Das ist klar wie Kloßbrühe!
Mit "wait until rising_edge()" wäre das nicht passiert, deshalb verwende
ich es so gern...
process
begin
    cnt <= cnt+1;
  else
    cnt <= 0;
    we2<='0';
    end if;
  end if;
  if sw0='1' then
    address_z1:=0;
    address_z2:=0;
    address_z3:=0;
23
  end if;
24
25
  if sw1='1' then
26
    we2<='1';
27
28
29
30
31
32
33
      datain2<=dataout1;
34
    end if;
35
  end if;
36
37
end process;
Achja, Peter: wenn du das Zeug so leicht wieder vergisst, das ich zum
Thema Bibliotheken und Variablen schon alles geschrieben habe, dann
DRUCK ES DIR AUS und häng es an die Wand.
Gast #3836759
Ich bin ja dafuer, dass Peter uns mal den folgenden, unheimlich
komplizierten Design (pardon, das Programm) erklaert, also was machen
die LEDs 1..4?:
library ieee;
entity variable_top is
port (
   clk : in std_logic;
   led1 : out std_logic := '0';
   led2 : out std_logic := '0';
   led3 : out std_logic := '0';
   led4 : out std_logic := '0'
end;
architecture rtl of variable_top is
   constant OUTBIT : natural range 0 to 3 := 3;
   signal cnt : unsigned (3 downto 0) := (others => '0');
begin
   proc_cntvar : process
      variable cnt : unsigned (3 downto 0) := (others => '0');
   begin
      wait until rising_edge (clk);
      led1 <= cnt (OUTBIT);
      cnt := cnt + 1;
23
      led2 <= cnt (OUTBIT);
24
   end process;
25
   proc_cntsig : process
26
   begin
27
28
      led3 <= cnt (OUTBIT);
29
      cnt <= cnt + 1;
30
      led4 <= cnt (OUTBIT);
31
   end process;
32
end rtl;
Da Peter ja aus Prinzip keinen Simulator benutzt, haenge ich die TB auch
mal an...
Gast #3837231
peter schrieb:
> Hmmm.. Led2 und 4 gehen an , wenn das 3.Bit von cnt erreicht ist.
Das ist prinzipiell richtig, aber halt nur unvollstaendig...
Auch die LEDs 1 und 3 gehen an. Und interessant sind die Phasenlagen der
4 LEDs... Das kannst du mit einem 4-Kanal Oszilloskop an der echten HW
nachschauen oder eben halt den Simulator bemuehen...
