1 | int main(void)
2 | {
3 | volatile unsigned int i; // volatile to prevent optimization
4 | volatile unsigned int conversion_result;
5 | WDTCTL = WDTPW + WDTHOLD; // Stop Watch Dog Timer
6 |
7 | ADC12CTL0 = REFON | REF2_5V | SHT0_2 + ADC12ON; // Set sampling time, turn on ADC12
8 | //SHT1x (Sample-and-hold time) = 0000b -> N/A
9 | //SHT0x (Sample-and-hold time) = 0010b -> 64 ADC12CLK
10 | //MSC (Multiple sample and conversion) = 0b -> N/A
11 | //REF2_5V (Reference generator voltage) = 1b -> 2.5 V
12 | //REFON (Reference generator on) = 1b -> Reference on
13 | //ADC12ON (ADC12 on) = 1b -> ADC12 on
14 | //ADC12OVIE (overflow-int. enable) = 0b -> disabled
15 | //ADC12TOVIE (conversion-time-overflow int enable) = 0b -> disabled
16 | //ENC (Enable conversion) = 0b -> enable configuration
17 | //ADC12SC (Start conversion) = 1b -> Start conversion
18 | ADC12CTL1 = SHP;
19 | //CSTARTADDx (Conv. start address.) = 0000b
20 | // -> ADC12MEM0
21 | //SHSx (Sample-and-hold source) = 00b -> ADC12SC bit
22 | //SHP (Sample-and-hold pulse-mode select) = 0b
23 | // -> SAMPCON signal is sourced from the sample-input
24 | // signal.
25 | //ISSH (Invert signal S-H) = 0b -> not inverted.
26 | //ADC12DIVx (ADC12 clock divider) = 000b -> /1
27 | //ADC12SSELx (ADC12 clock source) = 00b -> ADC12OSC
28 | //CONSEQx (Conversion sequence mode) = 00b -> Single-
29 | // channel, single-conversion
30 | //ADC12BUSY (ADC12 busy) = xb -> read only
31 | ADC12MCTL0 = SREF_1 | INCH_0;
32 | //EOS (End of sequence) = 0b -> Not Used
33 | //SREFx (Select ref.) = 001b -> VR+=VREF+/VR-=AVSS
34 | //INCHx (Input channel select) = 0001b -> A1
35 |
36 | OA0CTL0 = OAP_0 | OAPM_1 | OAADC0;
37 | //OANx (Inverting input) = XXb -> not important
38 | //OAPx (Non-inverting input) = 10b -> DAC0 internal
39 | //OAPMx (Slew rate select) = 11b -> Fast
40 | //OAADC1 (OA output) = 1b -> output connected to A1
41 | //OAADC0 (OA output) = 0b -> output _not_ connected A1
42 | OA0CTL1 = OAFBR_3 | OAFC_4 | OARRIP;
43 | //OAFBRx (feedback resistor) = 0x60 -> x2.7 gain
44 | //OAFCx (OAx function) = 100b -> Non-inverting PGA
45 | //OARRIP = 1b -> OAx input range is limited
46 |
47 | /*
48 | OAFBR_0 => x1 gain
49 | OAFBR_1 => x1.3 gain
50 | OAFBR_2 => x2 gain
51 | OAFBR_3 => x2.7 gain
52 | OAFBR_4 => x4 gain
53 | OAFBR_5 => x5.3 gain
54 | OAFBR_6 => x8 gain
55 | OAFBR_7 => x16 gain
56 | */
57 |
58 | // P6SEL |= 0x01; // P6.0 ADC option select
59 | // Configure UCA0 for RS232
60 | uart_configure();
61 |
62 | ADC12CTL0 |= ENC; // Conversion enabled
63 |
64 | while (1)
65 | {
66 | ADC12CTL0 |= ADC12SC; // Start conversions
67 | while (!(ADC12IFG & 0x0001))
68 | ; // Conversion done?
69 | conversion_result = ADC12MEM0; // Access result, resets ADC12IFG0
70 | //rs232_printf("conversion_result = %d\n", conversion_result);
71 | conversion_result = (conversion_result * 0.610); //(2,5/4096*100=0.610)
72 | rs232_printf("res = %d\n", conversion_result);
73 | // rs232_printf("OA0CTL0 = %d\n", OA0CTL0);
74 | // rs232_printf("OA0CTL1 = %d\n", OA0CTL1);
75 |
76 | i = 1000; // SW Delay
77 | do
78 | i--;
79 | while (i != 0);
80 | // i = 65535; // SW Delay
81 | // do
82 | // i--;
83 | // while (i != 0);
84 | }
85 |
86 | return 0;
87 | }
