1 | Konfiguration ***
2 | '*******************************************************************************
3 | 'AVR
4 | $regfile = "M32def.dat"
5 | $crystal = 16000000
6 | $hwstack = 100
7 | $swstack = 100
8 | $framesize = 100
9 | $baud = 19200
10 |
11 |
12 | '**************************************************************************
13 | '*** Ein-Ausgängedefinieren ***
14 | '**************************************************************************
15 | Config Portd.6 = Output
16 | Pad_att_line Alias Portd.6
17 |
18 | '**************************************************************************
19 | '*** Variablen ***
20 | '**************************************************************************
21 | Dim Cmdstart As Byte
22 | Cmdstart = &H01
23 | Dim Cmdstatus As Byte
24 | Cmdstatus = &H42
25 |
26 | 'PSX Type ID
27 | Const Cnstid_digital = &H41
28 | Const Cnstid_negocn = &H23
29 | Const Cnstid_analogred = &H73
30 | Const Cnstid_analoggreen = &H53
31 |
32 | 'These are for local storage of last read packet from PSX PAD
33 | Dim Pspad_present As Byte
34 | Dim Pspad_mode As Byte
35 | Dim Pspad_byte1 As Byte
36 | Dim Pspad_byte2 As Byte
37 |
38 | 'PSX PAD Joysticks
39 | 'Horizontal
40 | Dim Pspad_rjoy_h_pos As Byte '0 = Left , 255 = Right
41 | Dim Pspad_ljoy_h_pos As Byte '0 = Left , 255 = Right
42 |
43 | 'Vertikal
44 | Dim Pspad_rjoy_v_pos As Byte '0 = Up , 255 = Down
45 | Dim Pspad_ljoy_v_pos As Byte '0 = Up , 255 = Down
46 |
47 |
48 | '**************************************************************************
49 | '*** Alias Namen für PSX-PAD Tasten ***
50 | '**************************************************************************
51 | Pspad_key_select Alias Pspad_byte1.0
52 | Pspad_key_joyr Alias Pspad_byte1 .1
53 | Pspad_key_joyl Alias Pspad_byte1.2
54 | Pspad_key_start Alias Pspad_byte1.3
55 | Pspad_key_up Alias Pspad_byte1.4
56 | Pspad_key_right Alias Pspad_byte1.5
57 | Pspad_key_down Alias Pspad_byte1.6
58 | Pspad_key_left Alias Pspad_byte1.7
59 |
60 | Pspad_key_l2 Alias Pspad_byte2.0
61 | Pspad_key_r2 Alias Pspad_byte2.1
62 | Pspad_key_l1 Alias Pspad_byte2.2
63 | Pspad_key_r1 Alias Pspad_byte2.3
64 | Pspad_key_triangle Alias Pspad_byte2.4
65 | Pspad_key_circle Alias Pspad_byte2.5
66 | Pspad_key_x Alias Pspad_byte2.6
67 | Pspad_key_square Alias Pspad_byte2.7
68 |
69 | '**************************************************************************
70 | '*** Subroutine Declaration ***
71 | '**************************************************************************
72 | Declare Sub Query_pspad
73 |
74 | '**************************************************************************
75 | '*** SPI-Mode in Hardware konfigurieren ***
76 | '**************************************************************************
77 | Config Spi = Hard , Interrupt = Off , Data Order = Lsb , Master = Yes , _
78 | Polarity = High , Phase = 1 , Clockrate = 128
79 | Spiinit
80 |
81 | '**************************************************************************
82 | '*** HAUPTPROGRAMM ***
83 | '**************************************************************************
84 |
85 | Do
86 | 'Buttons are active low
87 | 'Update langsam zum testen im Terminal
88 | Waitms 1000
89 | 'Get current Button states from PSX-Controller
90 | Gosub Query_pspad
91 | 'Now do something base on the results
92 | If Pspad_present = 1 Then '0 = not present , 1 = present
93 |
94 | Print "Select:" ; Pspad_key_select
95 | Print "JoyR:" ; Pspad_key_joyr
96 | Print "JoyL:" ; Pspad_key_joyl
97 | Print "Start:" ; Pspad_key_start
98 | Print "Up:" ; Pspad_key_up
99 | Print "Right:" ; Pspad_key_right
100 | Print "Down:" ; Pspad_key_down
101 | Print "Left:" ; Pspad_key_left
102 | Print "L2:" ; Pspad_key_l2
103 | Print "R2:" ; Pspad_key_r2
104 | Print "L1:" ; Pspad_key_l1
105 | Print "R1:" ; Pspad_key_r1
106 | Print "Triangle:" ; Pspad_key_triangle
107 | Print "Circle:" ; Pspad_key_circle
108 | Print "X Key:" ; Pspad_key_x
109 | Print "Square:" ; Pspad_key_square
110 | Print "Right Joystick H Position:" ; Pspad_rjoy_h_pos
111 | Print "Right Joystick V Position:" ; Pspad_rjoy_v_pos
112 | Print "Left Joystick H Position:" ; Pspad_ljoy_h_pos
113 | Print "Left Joystick V Position:" ; Pspad_ljoy_v_pos
114 |
115 | Else
116 | Print " No Response From PSX-PAD"
117 | End If
118 |
119 | Loop
120 |
121 | '**************************************************************************
122 |
123 | Sub Query_pspad
124 | Reset Pad_att_line 'Get PSX-PAD Attention
125 | Spiout Cmdstart , 1 'Send Start
126 | Pspad_mode = Spimove(cmdstatus) 'Send Request, Receive ID Byte
127 |
128 | Spiin Pspad_present , 1 'Is PAD Responding
129 | 'Now see if the Controller is going to send something
130 |
131 |
132 | If Pspad_present = 90 Then '90 = Data on its way
133 | Pspad_present = 1 'Set the global bit
134 | Spiin Pspad_byte1 , 1 'Byte 1 and 2 are always used
135 | Spiin Pspad_byte2 , 1
136 | Spiin Pspad_rjoy_h_pos , 1 'Byte 3-6 are for Analog Modes
137 | Spiin Pspad_rjoy_v_pos , 1
138 | Spiin Pspad_ljoy_h_pos , 1
139 | Spiin Pspad_ljoy_v_pos , 1
140 | Set Pad_att_line
141 |
142 | Else
143 |
144 | Pspad_present = 0 'Set the global state set Pad_Att_Line 'Release Attention Line to the PS2 PAD
145 |
146 | End If
147 |
148 | End Sub
149 |
150 |
151 | '*******************************************************************************
