CAN BUS Acknowledgment error
OP #3898430
Hallo
           I am using STM32F429 CAN bus Program with TJA1041A as CAN
Transreciver.
The Problem is the messages are not getting acknowledged and herewith I
am attaching the code for further reference.I am using PCAN View to see
the messages.
I kindly request to check the code and tell me if there r any faults.
Code:-
int main(void)
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN2, ENABLE);
// SystemInit();
    GPIO_InitTypeDef GPIO_InitDef;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    GPIO_InitDef.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13;
    GPIO_InitDef.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitDef.GPIO_OType = GPIO_OType_PP;
    GPIO_InitDef.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_InitDef.GPIO_Speed = GPIO_Speed_100MHz;
   GPIO_Init(GPIOB, &GPIO_InitDef);
/* Connect CAN pins to AF */
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_CAN2); // CAN2_RX
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_CAN2); // CAN2_TX
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
   GPIO_InitDef.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
    GPIO_InitDef.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitDef.GPIO_PuPd = GPIO_PuPd_NOPULL;
  /* Connect PD5 and PD7 pins  for CAN Transreceiver to enable and
stanby */
 GPIO_Init(GPIOD, &GPIO_InitDef);
     GPIO_SetBits(GPIOD, GPIO_Pin_5|GPIO_Pin_7);
   RCC_ClocksTypeDef     RCC_Clocks;
  CAN_InitTypeDef       CAN_InitStructure;
  CAN_FilterInitTypeDef CAN_FilterInitStructure;
  RCC_GetClocksFreq(&RCC_Clocks);
  CAN_DeInit(CAN2);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal ;
  /* quanta 1+14+6 = 21, 21 * 4 = 84, 42000000 / 84 = 5000000 */
  /* CAN Baudrate = 500Kbps (CAN clocked at 42 MHz) Prescale = 4 */
  /* Requires a clock with integer division into APB clock */
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; // 1+6+7 = 14, 1+14+6 = 21,
1+15+5 = 21
  CAN_InitStructure.CAN_BS1 = CAN_BS1_14tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_6tq;
  CAN_InitStructure.CAN_Prescaler = 4; // quanta by baudrate - 125kbps
  CAN_Init(CAN2, &CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask; //
IdMask or IdList
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_16bit; // 16
or 32
  CAN_FilterInitStructure.CAN_FilterIdHigh      = 0x0000; // Everything,
otherwise 11-bit in top bits
  CAN_FilterInitStructure.CAN_FilterIdLow       = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh  = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow   = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_FIFO0; // Rx
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  //CAN_FilterInitStructure.CAN_FilterNumber = 0; // CAN1 [ 0..13]
//  CAN_FilterInit(&CAN_FilterInitStructure);
  CAN_FilterInitStructure.CAN_FilterNumber = 14; // CAN2 [14..27]
  CAN_ITConfig(CAN2, CAN_IT_FMP0, ENABLE);
 CanTxMsg TxMessage;
  // transmit */
  TxMessage.StdId = 0x321;
  TxMessage.ExtId = 0x00;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 8;
  TxMessage.Data[0] = 0x02;
  TxMessage.Data[1] = 0x11;
  TxMessage.Data[2] = 0x11;
  TxMessage.Data[3] = 0x11;
 while(1)
    uint32_t i;
     int j = 0;
    uint8_t TransmitMailbox = 0;
  TxMessage.Data[4] = (j >>  0) & 0xFF; // Cycling
   TxMessage.Data[5] = (j >>  8) & 0xFF;
    TxMessage.Data[6] = (j >> 16) & 0xFF;
    TxMessage.Data[7] = (j >> 24) & 0xFF;
    j++;
    TransmitMailbox = CAN_Transmit(CAN2, &TxMessage);
i = 0;
    while((CAN_TransmitStatus(CAN2, TransmitMailbox) != CANTXOK) && (i
!= 0xFFFF)) // Wait on Transmit
      i++;
      CAN2RX();// Pump RX
#3898678
Sure, that your device transmit a message? (not loop back mode - check
it/measure it)
In case, that your transceiver can be dactivate - is it activated?
Is you Peak device in Listen only mode? In Listen only mode the device
do not send an acknowlede.
In case all of them should be correct - Change the bitrate of the Peak
and transmit a message. Now the Peak should go in Error Busoff. In other
case your device is not active on the CAN bus.
#3898727
You mean:
You see the CAN messages of your STM on the CAN bus?
Is the Peak your second node? Send with the Peak device. Do you see this
messages, too?
stanby */
High active?
#3899699
Peak and STM are connected and online.
1) You send with the STM and see the waveform. You get an Acknowledge
Error.
2) You send with the Peak and see the waveform. You see a Error Message
(Acknowledge Error, too?). Only one? Bus heavy.
3) You switch the Peak to a different CAN bitrate (use a higher bitrate)
and send a message. You see the waveform and the error like 2).
Sure, that the CAN busses are connected of both devices and both running
at the same time?
One additional test:
Connect CAN-H and CAN-L (short circuit). If you transmit a message with
the STM, the STM has to go in Busoff. If you transmit with the Peak, the
Peak has to go in Busoff.
OP #3900127
I want to know whether CAN2 bus alone can be initalized seperately and
transmit the messages.
Because when I studied through the reference manual,I came to know CAN2
is a Slave and CAN1 is a Master Node.
So I kindly request you to tell me whether is ist possible to implement
CAN2 message communication seperately by initalzing the GPIO Pins
