1 | #include "Arduino.h"
2 | #include "Adafruit_GPS.h"
3 | #include "SoftwareSerial.h"
4 | #include "temperature.h"
5 | #include "ph.h"
6 | #include "SD.h"
7 |
8 | SoftwareSerial mySerial_gps(6, 5); //Simulierte Serielle
9 |
10 | Adafruit_GPS GPS(&mySerial_gps);
11 |
12 | // Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
13 | // Set to 'true' if you want to debug and listen to the raw GPS sentences.
14 | #define GPSECHO false
15 |
16 | // this keeps track of whether we're using the interrupt
17 | // off by default!
18 | boolean usingInterrupt = false;
19 | void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
20 |
21 | float temp;
22 |
23 |
24 | //SD
25 | //=====================================================================================
26 | #define ECHO_TO_SERIAL 1 // echo data to serial port
27 | #define WAIT_TO_START 0 // Wait for serial input in setup()
28 | #define redLEDpin 7
29 | #define greenLEDpin 8
30 | const int chipSelect = 10;
31 | File logfile;
32 | //=====================================================================================
33 |
34 | void error(char *str)
35 | {
36 | //Fehlertext-Ausgabe
37 | Serial.print("Fehler: ");
38 | Serial.println(str);
39 | digitalWrite(redLEDpin, HIGH); //Rote LED leuchtet permanent
40 | while(1); //bleibt hier hängen im Falle eines Fehlers
41 | }
42 |
43 |
44 | void setup()
45 | {
46 |
47 | Serial.begin(115200);
48 | Serial.println("GPS Ausgabe starten...");
49 | pinMode(tempVcc, OUTPUT);
50 | pinMode(redLEDpin, OUTPUT);
51 | pinMode(greenLEDpin, OUTPUT);
52 | // 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
53 | GPS.begin(9600);
54 |
55 | GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
56 |
57 | // Set the update rate
58 | GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
59 |
60 | // Request updates on antenna status, comment out to keep quiet
61 | // GPS.sendCommand(PGCMD_ANTENNA);
62 |
63 | useInterrupt(true); // Jede 1 millisekunden - GPS read
64 |
65 |
66 | //SD
67 | //=====================================================================================
68 | //Check ob Speicherkarte vorhanden ist
69 | if (!SD.begin(chipSelect)) {
70 | error("Zugriff auf SD-Speicherkarte nicht moeglich");
71 | }
72 |
73 | Serial.println("SD-Speicherkarte initialisiert.");
74 |
75 | //Logging-File erstellen
76 | char filename[] = "LOGGER00.CSV";
77 | for (uint8_t i = 0; i < 100; i++) {
78 | filename[6] = i/10 + '0';
79 | filename[7] = i%10 + '0';
80 | if (! SD.exists(filename)) {
81 | // only open a new file if it doesn't exist
82 | logfile = SD.open(filename, FILE_WRITE);
83 | break; // leave the loop!
84 | }
85 | }
86 |
87 | if (! logfile) {
88 | error("Datei konnte nicht erstellt werden.");
89 | }
90 | //=====================================================================================
91 |
92 |
93 | delay(1000);
94 |
95 | }
96 |
97 |
98 | // Interrupt is called once a millisecond, looks for any new GPS data, and stores it
99 | SIGNAL(TIMER0_COMPA_vect) {
100 | char c = GPS.read();
101 | // if you want to debug, this is a good time to do it!
102 | #ifdef UDR0
103 | if (GPSECHO)
104 | if (c) UDR0 = c;
105 | // writing direct to UDR0 is much much faster than Serial.print
106 | // but only one character can be written at a time.
107 | #endif
108 | }
109 |
110 | void useInterrupt(boolean v) {
111 | if (v) {
112 | // Timer0 is already used for millis() - we'll just interrupt somewhere
113 | // in the middle and call the "Compare A" function above
114 | OCR0A = 0xAF;
115 | TIMSK0 |= _BV(OCIE0A);
116 | usingInterrupt = true;
117 | } else {
118 | // do not call the interrupt function COMPA anymore
119 | TIMSK0 &= ~_BV(OCIE0A);
120 | usingInterrupt = false;
121 | }
122 | }
123 |
124 | uint32_t timer = millis();
125 | void loop() // run over and over again
126 | {
127 | temp = read_temp();
128 | ph = read_ph();
129 |
130 | // in case you are not using the interrupt above, you'll
131 | // need to 'hand query' the GPS, not suggested :(
132 | if (! usingInterrupt) {
133 | // read data from the GPS in the 'main loop'
134 | char c = GPS.read();
135 | // if you want to debug, this is a good time to do it!
136 | if (GPSECHO)
137 | if (c) Serial.print(c);
138 | }
139 |
140 |
141 | // if a sentence is received, we can check the checksum, parse it...
142 | if (GPS.newNMEAreceived()) {
143 |
144 | if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
145 | return; // we can fail to parse a sentence in which case we should just wait for another
146 | }
147 |
148 | // if millis() or timer wraps around, we'll just reset it
149 | if (timer > millis()) timer = millis();
150 |
151 | //approximately every 2 seconds or so, print out the current stats
152 | if (millis() - timer > 2000) {
153 | timer = millis(); // reset the timer
154 | delay(1000);
155 | Serial.print("\nZeit: ");
156 | Serial.print(GPS.hour+1, DEC); Serial.print(':'); // +1 wegen GMT+1
157 | Serial.print(GPS.minute, DEC); Serial.print(':');
158 | Serial.print(GPS.seconds, DEC); Serial.print('.');
159 | Serial.println(GPS.milliseconds);
160 | Serial.print("Datum: ");
161 | Serial.print(GPS.day, DEC); Serial.print('/');
162 | Serial.print(GPS.month, DEC); Serial.print("/20");
163 | Serial.println(GPS.year, DEC);
164 | Serial.print("Fix: "); Serial.print((int)GPS.fix);
165 | Serial.print(" Quali: "); Serial.println((int)GPS.fixquality);
166 | Serial.println("Temperatur: ");
167 | Serial.println(temp);
168 | Serial.println("pH-Wert: ");
169 | Serial.println(ph);
170 | if (GPS.fix) {
171 | Serial.print("Position: ");
172 | Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
173 | Serial.print(", ");
174 | Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
175 | Serial.print("Position (in degrees, works with Google Maps): ");
176 | Serial.print(GPS.latitudeDegrees, 4);
177 | Serial.print(", ");
178 | Serial.println(GPS.longitudeDegrees, 4);
179 |
180 | Serial.print("Geschwindigkeit (Knoten): "); Serial.println(GPS.speed);
181 | Serial.print("Angle: "); Serial.println(GPS.angle);
182 | Serial.print("Altitude: "); Serial.println(GPS.altitude);
183 | Serial.print("Satelliten: "); Serial.println((int)GPS.satellites);
184 | }
185 | }
186 | }
