1 | static inline void xspi_put( unsigned char value )
2 | {
3 | //ENC_DEBUG("spi_put(%2x)\n", (unsigned) value );
4 | SPDR = value;
5 | while( !(SPSR & (1<<SPIF)) ) ;
6 | }
7 |
8 | static inline unsigned char xspi_get(void)
9 | {
10 | unsigned char value = SPDR;
11 | //ENC_DEBUG("spi_get()=%2x\n", (unsigned) value );
12 | return value;
13 | }
14 |
15 |
16 | static void enc_read_buf( unsigned char *buf, unsigned int len )
17 | {
18 | enc_select();
19 | spi_put( ENC_SPI_OP_RBM );
20 | //if(len > 0){len--; buf++ ;*(buf) = xspi_get();}
21 | for(; len > 0; len--, buf++ ) {
22 | xspi_put( 0x00 );
23 | *(buf) = xspi_get();
24 | }
25 | enc_deselect();
26 | }
27 |
28 |
29 |
30 | unsigned int enc_receive_packet( unsigned int bufsize, unsigned char *buf )
31 | {
32 | unsigned char rxheader[18];
33 | unsigned int len, status;
34 | unsigned char u;
35 |
36 | // check rx packet counter
37 | u = enc_read_reg( ENC_REG_EPKTCNT );
38 | ENC_DEBUG("enc_receive: EPKTCNT=%i\n", (int) u);
39 | if( u == 0 ) {
40 | // packetcounter is 0, there is nothing to receive, go back
41 | return 0;
42 | }
43 |
44 | //set read pointer to next packet
45 | enc_write_reg( ENC_REG_ERDPTL, LO8(enc_next_packet_ptr) );
46 | enc_write_reg( ENC_REG_ERDPTH, HI8(enc_next_packet_ptr) );
47 |
48 | // read enc rx packet header
49 | enc_read_buf( rxheader, 6 );
50 | enc_next_packet_ptr = rxheader[0];
51 | enc_next_packet_ptr |= ((unsigned)(rxheader[1])) << 8;
52 | len = rxheader[2];
53 | len |= ((unsigned)(rxheader[3])) << 8;
54 | status = rxheader[4];
55 | status |= ((unsigned)(rxheader[5])) << 8;
56 |
57 | //kk
58 | ePtr=enc_next_packet_ptr;
59 | eLen=len;
60 | eStatus=status;
61 |
62 | /*
63 | //kk
64 | //kein Fehler:
65 | for(i=6;i<12;i++){
66 | tmp_macd[i-6]=rxheader[i];
67 | }
68 |
69 | for(i=12;i<18;i++){
70 | tmp_macs[i-12]=rxheader[i];
71 | }
72 |
73 |
74 | //Fehler:
75 | enc_read_buf( tmp_macd, 6 );//1.byte wird ausgelassen
76 | enc_read_buf( tmp_macs, 6 );//1.byte wird ausgelassen
77 | */
78 | // added by Sjors: reset the ENC when needed
79 | // If the receive OK bit is not 1 or the zero bit is not zero, or the packet is larger then the buffer, reset the enc chip and SPI
80 | if ((!(status & (1<<7))) || (status & 0x8000) || (len > bufsize))
81 | {
82 | enc_init();
83 | }
84 | //ENC_DEBUG("enc_receive: status=%4x\n", (unsigned) status);
85 |
86 | // skip the checksum (4 bytes) at the end of the buffer
87 | len -= 4;
88 |
89 | // if the application buffer is to small, we just truncate
90 | if( len > bufsize ) len = bufsize;
91 |
92 | // now read the packet data into buffer
93 | enc_read_buf( buf, len );//1.byte wird ausgelassen
94 |
95 |
96 |
97 | // adjust the ERXRDPT pointer (= free this packet in rx buffer)
98 | if( enc_next_packet_ptr-1 > ENC_RX_BUFFER_END
99 | || enc_next_packet_ptr-1 < ENC_RX_BUFFER_START ) {
100 | enc_write_reg( ENC_REG_ERXRDPTL, LO8(ENC_RX_BUFFER_END) );
101 | enc_write_reg( ENC_REG_ERXRDPTH, HI8(ENC_RX_BUFFER_END) );
102 | } else {
103 | enc_write_reg( ENC_REG_ERXRDPTL, LO8(enc_next_packet_ptr-1) );
104 | enc_write_reg( ENC_REG_ERXRDPTH, HI8(enc_next_packet_ptr-1) );
105 | }
106 |
107 | // trigger a decrement of the rx packet counter
108 | // this will clear PKTIF if EPKTCNT reaches 0
109 | enc_setbits_reg( ENC_REG_ECON2, (1<<ENC_BIT_PKTDEC) );
110 |
111 | // return number of bytes written to the buffer
112 | ENC_DEBUG("enc_receive: %i bytes\n", len);
113 | return len;
114 | }
