1 | #include <Tone.h>
2 | Tone speakerpin;
3 | int starttune[] = {NOTE_C4, NOTE_F4, NOTE_C4, NOTE_F4, NOTE_C4, NOTE_F4, NOTE_C4, NOTE_F4, NOTE_G4, NOTE_F4, NOTE_E4, NOTE_F4, NOTE_G4};
4 | int duration2[] = {100, 200, 100, 200, 100, 400, 100, 100, 100, 100, 200, 100, 500};
5 | int note[] = {NOTE_C4, NOTE_C4, NOTE_G4, NOTE_C5, NOTE_G4, NOTE_C5};
6 | int duration[] = {100, 100, 100, 300, 100, 300};
7 | boolean button[] = {2, 3, 4, 5}; //The four button input pins
8 | boolean ledpin[] = {8, 9, 10, 11}; // LED pins
9 | int turn = 0; // turn counter
10 | int buttonstate = 0; // button state checker
11 | int randomArray[100]; //Intentionally long to store up to 100 inputs (doubtful anyone will get this far)
12 | int inputArray[100];
13 |
14 |
15 | void setup()
16 | {
17 |
18 | speakerpin.begin(12); // Lautsprecher pin 12
19 |
20 | for(int x=0; x<4; x++) // LED pins are outputs
21 | {
22 | pinMode(ledpin[x], OUTPUT);
23 | }
24 |
25 | for(int x=0; x<4; x++)
26 | {
27 | pinMode(button[x], INPUT); // button pins are inputs
28 | digitalWrite(button[x], HIGH); // enable internal pullup; buttons start in high position; logic reversed
29 | }
30 |
31 | randomSeed(analogRead(0)); //Added to generate "more randomness" with the randomArray for the output function
32 | for (int thisNote = 0; thisNote < 13; thisNote ++) {
33 | // play the next note:
34 | speakerpin.play(starttune[thisNote]);
35 | // hold the note:
36 | if (thisNote==0 || thisNote==2 || thisNote==4 || thisNote== 6)
37 | {
38 | digitalWrite(ledpin[0], HIGH);
39 | }
40 | if (thisNote==1 || thisNote==3 || thisNote==5 || thisNote== 7 || thisNote==9 || thisNote==11)
41 | {
42 | digitalWrite(ledpin[1], HIGH);
43 | }
44 | if (thisNote==8 || thisNote==12)
45 | {
46 | digitalWrite(ledpin[2], HIGH);
47 | }
48 | if (thisNote==10)
49 | {
50 | digitalWrite(ledpin[3], HIGH);
51 | }
52 | delay(duration2[thisNote]);
53 | // stop for the next note:
54 | speakerpin.stop();
55 | digitalWrite(ledpin[0], LOW);
56 | digitalWrite(ledpin[1], LOW);
57 | digitalWrite(ledpin[2], LOW);
58 | digitalWrite(ledpin[3], LOW);
59 | delay(25);
60 | }
61 | delay(1000);
62 | }
63 |
64 | void loop()
65 | {
66 |
67 |
68 |
69 | digitalWrite(ledpin[0], LOW);
70 | digitalWrite(ledpin[1], LOW);
71 | digitalWrite(ledpin[2], LOW);
72 | digitalWrite(ledpin[3], LOW);
73 | delay(1000);
74 |
75 | for (int y=turn; y <= turn; y++)
76 | { //Limited by the turn variable
77 |
78 | randomArray[y] = random(1, 5); //Assigning a random number (1-4) to the randomArray[y], y being the turn count
79 | for (int x=0; x <= turn; x++)
80 | {
81 |
82 |
83 | for(int y=0; y<4; y++)
84 | {
85 |
86 | if (randomArray[x] == 1 && ledpin[y] == 8)
87 | { //if statements to display the stored values in the array
88 | digitalWrite(ledpin[y], HIGH);
89 | speakerpin.play(NOTE_G3, 100);
90 | delay(400);
91 | digitalWrite(ledpin[y], LOW);
92 | delay(100);
93 | }
94 |
95 | if (randomArray[x] == 2 && ledpin[y] == 9)
96 | {
97 | digitalWrite(ledpin[y], HIGH);
98 | speakerpin.play(NOTE_A3, 100);
99 | delay(400);
100 | digitalWrite(ledpin[y], LOW);
101 | delay(100);
102 | }
103 |
104 | if (randomArray[x] == 3 && ledpin[y] == 10)
105 | {
106 | digitalWrite(ledpin[y], HIGH);
107 | speakerpin.play(NOTE_B3, 100);
108 | delay(400);
109 | digitalWrite(ledpin[y], LOW);
110 | delay(100);
111 | }
112 |
113 | if (randomArray[x] == 4 && ledpin[y] == 11)
114 | {
115 | digitalWrite(ledpin[y], HIGH);
116 | speakerpin.play(NOTE_C4, 100);
117 | delay(400);
118 | digitalWrite(ledpin[y], LOW);
119 | delay(100);
120 | }
121 | }
122 | }
123 | }
124 | input();
125 | //}
126 | }
127 |
128 | void input() { //Function for allowing user input and checking input against the generated array
129 |
130 | for (int x=0; x <= turn;)
131 | { //Statement controlled by turn count
132 |
133 | for(int y=0; y<4; y++)
134 | {
135 |
136 | buttonstate = digitalRead(button[y]);
137 |
138 | if (buttonstate == LOW && button[y] == 2)
139 | { //Checking for button push
140 | digitalWrite(ledpin[0], HIGH);
141 | speakerpin.play(NOTE_G3, 100);
142 | delay(200);
143 | digitalWrite(ledpin[0], LOW);
144 | inputArray[x] = 1;
145 | delay(250);
146 |
147 | if (inputArray[x] != randomArray[x]) { //Checks value input by user and checks it against
148 | fail(); //the value in the same spot on the generated array
149 | } //The fail function is called if it does not match
150 | x++;
151 | }
152 | if (buttonstate == LOW && button[y] == 3)
153 | {
154 | digitalWrite(ledpin[1], HIGH);
155 | speakerpin.play(NOTE_A3, 100);
156 | delay(200);
157 | digitalWrite(ledpin[1], LOW);
158 | inputArray[x] = 2;
159 | delay(250);
160 |
161 | if (inputArray[x] != randomArray[x]) {
162 | fail();
163 | }
164 | x++;
165 | }
166 |
167 | if (buttonstate == LOW && button[y] == 4)
168 | {
169 | digitalWrite(ledpin[2], HIGH);
170 | speakerpin.play(NOTE_B3, 100);
171 | delay(200);
172 | digitalWrite(ledpin[2], LOW);
173 | inputArray[x] = 3;
174 | delay(250);
175 |
176 | if (inputArray[x] != randomArray[x]) {
177 | fail();
178 | }
179 | x++;
180 | }
181 |
182 | if (buttonstate == LOW && button[y] == 5)
183 | {
184 | digitalWrite(ledpin[3], HIGH);
185 | speakerpin.play(NOTE_C4, 100);
186 | delay(200);
187 | digitalWrite(ledpin[3], LOW);
188 | inputArray[x] = 4;
189 | delay(250);
190 |
191 | if (inputArray[x] != randomArray[x])
192 | {
193 | fail();
194 | }
195 | x++;
196 | }
197 | }
198 | }
199 | delay(500);
200 | turn++; //Increments the turn count, also the last action before starting the output function over again
201 | }
202 |
203 |
204 |
205 |
206 |
207 |
208 | void fail() { //Function used if the player fails to match the sequence
209 |
210 | for (int y=0; y<=2; y++)
211 | { //Flashes lights for failure
212 |
213 | digitalWrite(ledpin[0], HIGH);
214 | digitalWrite(ledpin[1], HIGH);
215 | digitalWrite(ledpin[2], HIGH);
216 | digitalWrite(ledpin[3], HIGH);
217 | speakerpin.play(NOTE_G3, 300);
218 | delay(200);
219 | digitalWrite(ledpin[0], LOW);
220 | digitalWrite(ledpin[1], LOW);
221 | digitalWrite(ledpin[2], LOW);
222 | digitalWrite(ledpin[3], LOW);
223 | speakerpin.play(NOTE_C3, 300);
224 | delay(200);
225 | }
226 | delay(500);
227 | turn = -1; //Resets turn value so the game starts over without need for a reset button
228 | }
