1 | #include <msp430.h>
2 | #include "CC2500\cc2500.h"
3 | #include "UART\uart.h"
4 |
5 |
6 | const int THRESHOLD = -75;
7 |
8 | //#define DEBUG
9 |
10 |
11 | void t_itoa(int z, unsigned char* Buffer);
12 |
13 | unsigned char RSSI_A[10] = { 0 };
14 | unsigned char Channel[10] = { 0 };
15 |
16 |
17 |
18 | /*
19 | * main.c
20 | *
21 | */
22 | void main(void) {
23 |
24 | volatile int rssi_value = 0;
25 | volatile unsigned char state = 0;
26 | volatile unsigned int i = 0;
27 | volatile int rssi_array[500] = {0};
28 |
29 | WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
30 |
31 | UART_INIT();
32 | SPI_INIT();
33 | cc2500_sendCmdStrobe(SRES);
34 | cc2500_init();
35 | P1DIR |= 0x01;
36 |
37 |
38 |
39 | P1OUT = 0x01;
40 |
41 | cc2500_sendCmdStrobe(CC2500_RX);
42 |
43 | for(;;)
44 | {
45 |
46 | for(i = 0; i <= 250; i++)
47 | {
48 | state = cc2500_readReg(MARCSTATE);
49 | while((cc2500_readReg(MARCSTATE) & 0x1F) != 0x0D);
50 | state = cc2500_readReg(MARCSTATE);
51 | rssi_value = cc2500_readRssi();
52 | cc2500_sendCmdStrobe(CC2500_IDLE);
53 | cc2500_writeReg(CHANNR, i);
54 | cc2500_sendCmdStrobe(CC2500_RX);
55 |
56 | rssi_array[i] = rssi_value;
57 | }
58 |
59 | cc2500_sendCmdStrobe(CC2500_IDLE);
60 |
61 | cc2500_writeReg(FREQ2, 0x5D);
62 | cc2500_writeReg(FREQ1, 0xF0);
63 | cc2500_writeReg(FREQ0, 0x10);
64 |
65 | cc2500_sendCmdStrobe(CC2500_RX);
66 |
67 | for(i = 0; i <= 247; i++)
68 | {
69 | while((cc2500_readReg(MARCSTATE) & 0x1F) != 0x0D);
70 | rssi_value = cc2500_readRssi();
71 | cc2500_sendCmdStrobe(CC2500_IDLE);
72 | cc2500_writeReg(CHANNR, i);
73 | cc2500_sendCmdStrobe(CC2500_RX);
74 |
75 | rssi_array[i + 251] = rssi_value;
76 | }
77 |
78 |
79 | cc2500_sendCmdStrobe(CC2500_IDLE);
80 | cc2500_writeReg(FREQ2, 0x5C);
81 | cc2500_writeReg(FREQ1, 0x4F);
82 | cc2500_writeReg(FREQ0, 0xBB);
83 | cc2500_sendCmdStrobe(CC2500_RX);
84 |
85 | for(i = 0; i <= 499; i++)
86 | {
87 | if(rssi_array[i] >= (-75))
88 | {
89 | t_itoa(i,&Channel[0]); //funktioniert
90 | t_itoa(rssi_array[i],RSSI_A); //funktioniert
91 | uart_puts(&Channel[0]); //funktioniert überschreibt aber RSSI_A teilweise
92 | uart_putc(':');
93 | uart_puts(&RSSI_A[0]);
94 | uart_putc('\n');
95 | }
96 | }
97 | }
98 | }
99 |
100 | void t_itoa(int z, unsigned char* Buffer)
101 | {
102 | int i = 0;
103 | int j;
104 | char tmp;
105 | unsigned int u;
106 |
107 | //zahl negativ?
108 | if( z < 0 ) {
109 | Buffer[0] = '-';
110 | Buffer++;
111 | u = ( (unsigned int)(-(z+1))) + 1;
112 | }
113 | else {
114 | u = (unsigned int)z;
115 | }
116 |
117 | //Stellen berechnen
118 | do {
119 | Buffer[i++] = '0' + u % 10;
120 | u /= 10;
121 | } while( u > 0 );
122 |
123 |
124 | //spiegeln
125 | for( j = 0; j < i / 2; j++ )
126 | {
127 | tmp = Buffer[j];
128 | Buffer[j] = Buffer[i-j-1];
129 | Buffer[i-j-1] = tmp;
130 | }
131 |
132 | //Stringende einfügen
133 | Buffer[i] = '\0';
134 | }
135 |
136 | /////in uart.h definiert
137 | void uart_putc(unsigned char data)
138 | {
139 |
140 | while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?
141 | UCA0TXBUF = data; // write TX buffer
142 | }
143 |
144 | void uart_puts(unsigned char *data)
145 | {
146 | volatile unsigned int i = 0;
147 |
148 | do
149 | {
150 | while (!(IFG2&UCA0TXIFG)); // USCI_A0 TX buffer ready?
151 | UCA0TXBUF = *(data + i++); // write TX buffer
152 | }
153 | while(*(data + i) != '\0');
154 |
155 | }
