1 | /************************************************************************/
2 | /* */
3 | /* Debouncing 8 Keys */
4 | /* Sampling 4 Times */
5 | /* With Repeat Function */
6 | /* */
7 | /* Author: Peter Dannegger */
8 | /* danni@specs.de */
9 | /* */
10 | /************************************************************************/
11 |
12 | #include <avr/io.h>
13 | #include <stdio.h>
14 | #include <stdlib.h>
15 | #include <string.h>
16 | #include "main.h"
17 | #include "lcd.h"
18 | #include <avr/wdt.h>
19 | #include <avr/interrupt.h>
20 | #include <util/delay.h>
21 | #include <inttypes.h>
22 |
23 | #ifndef F_CPU
24 | #define F_CPU 7372800 // processor clock frequency
25 | #warning kein F_CPU definiert
26 | #endif
27 |
28 | #define KEY_DDR DDRC
29 | #define KEY_PORT PORTC
30 | #define KEY_PIN PINC
31 | #define KEY_mitte 7
32 | #define KEY_links 3
33 | #define KEY_rechts 4
34 | #define KEY_oben 6
35 | #define KEY_unten 2
36 | #define ALL_KEYS (1<<KEY_mitte | 1<<KEY_links | 1<<KEY_rechts | 1<<KEY_oben | 1<<KEY_unten)
37 |
38 | #define REPEAT_MASK (1<<KEY_links | 1<<KEY_rechts | 1<<KEY_mitte | 1<<KEY_oben | 1<<KEY_unten) // repeat: key1, key2
39 | #define REPEAT_START 50 // after 500ms
40 | #define REPEAT_NEXT 20 // every 200ms
41 |
42 | #define LED_DDR DDRD
43 | #define LED_PORT PORTD
44 | #define LED0 0
45 | #define LED1 1
46 | #define LED2 2
47 | #define LED3 3
48 | #define LED4 4
49 | #define LED5 5
50 |
51 | #define ADCINPUTS 8 // Anzahl der ADC Eingänge
52 |
53 | volatile uint8_t key_state; // debounced and inverted key state:
54 | // bit = 1: key pressed
55 | volatile uint8_t key_press; // key press detect
56 |
57 | volatile uint8_t key_rpt; // key long press and repeat
58 | uint16_t display_update = 100; // Aktualisierungstimer Display in ms
59 | volatile uint8_t menu =0;
60 | volatile uint16_t countdown =0;
61 |
62 | /*
63 | Globale Variablen im RAM
64 | */
65 | char ram_string[32];
66 | uint8_t counter=0 , ledcounter=0;
67 | volatile uint8_t flag_update_display = 0; // Variable jederzeit änderbar
68 | volatile uint8_t flag_start=1;
69 | volatile uint8_t flag_countdown=0;
70 | volatile uint8_t flag_firstcount=0;
71 | uint16_t sekunden=0;
72 | uint16_t adc[ADCINPUTS];
73 | uint8_t flag_high[ADCINPUTS];
74 |
75 |
76 | void timer0()
77 | {
78 | TCCR0 = (1<<CS02)|(1<<CS00); // divide by 1024
79 | TCNT0 = (-72); // preload for 10ms
80 | TIMSK |= 1<<TOIE0; // enable timer interrupt
81 | }
82 |
83 | ISR( TIMER0_OVF_vect ) // every 10ms
84 | {
85 | static uint8_t ct0, ct1, rpt;
86 | uint8_t i;
87 |
88 | TCNT0 = (-72); // preload for 10ms
89 | i = key_state ^ ~KEY_PIN; // key changed ?
90 | ct0 = ~( ct0 & i ); // reset or count ct0
91 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
92 | i &= ct0 & ct1; // count until roll over ?
93 | key_state ^= i; // then toggle debounced state
94 | key_press |= key_state & i; // 0->1: key press detect
95 |
96 | if( (key_state & REPEAT_MASK) == 0 ) // check repeat function
97 | rpt = REPEAT_START; // start delay
98 | if( --rpt == 0 )
99 | {
100 | rpt = REPEAT_NEXT; // repeat delay
101 | key_rpt |= key_state & REPEAT_MASK;
102 | }
103 |
104 | counter++;
105 | if(!(flag_start)) // Kein Startzustand mehr
106 | {
107 | if((countdown==0) && (flag_firstcount!=0))
108 | {
109 | flag_countdown = 0;
110 | }
111 | else countdown--;
112 | if(flag_countdown==0)
113 | {
114 | menu = 1;
115 | PORTB &= ~(1<<PB0);
116 | lcd_clear();
117 | lcd_setcursor(0,0);
118 | lcd_string("Standardmodus");
119 | flag_countdown=1;
120 | }
121 | }
122 | if(menu==2)
123 | {
124 | if(counter==(display_update)/10)
125 | {
126 | flag_update_display = 1;
127 | }
128 | }
129 | if(menu==1)
130 | {
131 | if(counter==(display_update)/10)
132 | {
133 | flag_update_display = 1;
134 | }
135 | if(counter==100) // 1 Sekunde
136 | {
137 | sekunden++;
138 | switch(ledcounter)
139 | {
140 | case 0: PORTD ^= (1<<PD0); break;
141 | case 1: PORTD ^= (1<<PD1); break;
142 | case 2: PORTD ^= (1<<PD2); break;
143 | case 3: PORTD ^= (1<<PD3); break;
144 | case 4: PORTD ^= (1<<PD4); break;
145 | case 5: PORTD ^= (1<<PD5); break;
146 | case 6: PORTD ^= (1<<PB6); break;
147 | case 7: PORTD ^= (1<<PB7); break;
148 | }
149 | ledcounter++;
150 | if(ledcounter==8)ledcounter=0;
151 | counter=0;
152 | }
153 | }
154 |
155 | ///////////////////////////////////////////////////////////////////
156 | //
157 | // check if a key has been pressed. Each pressed key is reported
158 | // only once
159 | //
160 | uint8_t get_key_press( uint8_t key_mask )
161 | {
162 | cli(); // read and clear atomic !
163 | key_mask &= key_press; // read key(s)
164 | key_press ^= key_mask; // clear key(s)
165 | sei();
166 | return key_mask;
167 | }
168 |
169 | ///////////////////////////////////////////////////////////////////
170 | //
171 | // check if a key has been pressed long enough such that the
172 | // key repeat functionality kicks in. After a small setup delay
173 | // the key is reported being pressed in subsequent calls
174 | // to this function. This simulates the user repeatedly
175 | // pressing and releasing the key.
176 | //
177 | uint8_t get_key_rpt( uint8_t key_mask )
178 | {
179 | cli(); // read and clear atomic !
180 | key_mask &= key_rpt; // read key(s)
181 | key_rpt ^= key_mask; // clear key(s)
182 | sei();
183 | return key_mask;
184 | }
185 |
186 | ///////////////////////////////////////////////////////////////////
187 | //
188 | // check if a key is pressed right now
189 | //
190 | uint8_t get_key_state( uint8_t key_mask )
191 |
192 | {
193 | key_mask &= key_state;
194 | return key_mask;
195 | }
196 |
197 | ///////////////////////////////////////////////////////////////////
198 | //
199 | uint8_t get_key_short( uint8_t key_mask )
200 | {
201 | cli(); // read key state and key press atomic !
202 | return get_key_press( ~key_state & key_mask );
203 | }
204 |
205 | ///////////////////////////////////////////////////////////////////
206 | //
207 | uint8_t get_key_long( uint8_t key_mask )
208 | {
209 | return get_key_press( get_key_rpt( key_mask ));
210 | }
211 |
212 |
213 | void ADC_Init(void)
214 | {
215 | cli();
216 | PORTB &= ~(1 << PB0); // Blaue LED resetten
217 | ACSR = (1<<ACD); // Analog Comperator AUS
218 |
219 | // die Versorgungsspannung AVcc als Refernz wählen:
220 | ADMUX = (1<<REFS0);
221 |
222 | /* oder interne Referenzspannung als Referenz für den ADC wählen:
223 | ADMUX = (1<<REFS1) | (1<<REFS0);
224 |
225 | Bit ADFR ("free running") in ADCSRA steht beim Einschalten
226 | schon auf 0, also single conversion
227 |
228 |
229 | ADC Takt zwischen 50-200kHz
230 | TFmin = CLK/200kHz = 36,8 (7,372MHz)
231 | Nächstgrößerer Teilungsfaktor: 64
232 | mit ADPS2 = 1 , ADPS1 = 1 und ADPS0 = 0 */
233 |
234 | ADCSRA = ((1<<ADPS2)|(1<<ADPS1));
235 | ADCSRA &= ~(1<<ADPS0);
236 | ADCSRA = (1<<ADEN); // ADC aktivieren
237 |
238 | /* nach Aktivieren des ADC wird ein "Dummy-Readout" empfohlen, man liest
239 | also einen Wert und verwirft diesen, um den ADC "warmlaufen zu lassen" */
240 |
241 | ADCSRA |= (1<<ADSC); // eine ADC-Wandlung
242 | while (ADCSRA & (1<<ADSC) ) // auf Abschluss der Konvertierung warten
243 | {
244 | }
245 | /* ADCW muss einmal gelesen werden, sonst wird Ergebnis der nächsten
246 | Wandlung nicht übernommen. */
247 |
248 | sei();
249 | (void) ADCW;
250 | }
251 |
252 |
253 | uint16_t ADC_Read( uint8_t channel )
254 | {
255 | // Kanal waehlen, ohne andere Bits zu beeinflußen
256 | ADMUX = (ADMUX & ~(0x1F)) | (channel & 0x1F);
257 | ADCSRA |= (1<<ADSC); // eine Wandlung "single conversion"
258 | while (ADCSRA & (1<<ADSC) ) // auf Abschluss der Konvertierung warten
259 | {
260 | }
261 | return ADCW; // ADC auslesen und zurückgeben
262 | }
263 |
264 | /* ADC Mehrfachmessung mit Mittelwertbbildung */
265 | /* beachte: Wertebereich der Summenvariablen */
266 | uint16_t ADC_Read_Avg( uint8_t channel, uint8_t nsamples )
267 | {
268 | uint32_t sum = 0;
269 |
270 | for (uint8_t i = 0; i < nsamples; ++i )
271 | {
272 | sum += ADC_Read( channel );
273 | }
274 |
275 | return (uint16_t)( sum / nsamples );
276 | }
277 |
278 |
279 |
280 | void declaration()
281 | {
282 | /* WDTCR = (1<<WDTOE);
283 | WDTCR &= ~(1<<WDE); // Watchdog deaktivieren */
284 | DDRB = 0xFF; // Blaue LED: Ausgang
285 | PORTB &= ~(1<< PB0);
286 | DDRC = 0x00; // Eingänge
287 | DDRC = ((1 << DDC0) | (1 << DDC1)) ; // PC0-3 Ausgang
288 | PORTC = 0xFF;
289 | PORTC &= ~((1<<PC0) | (1 <<PC1));
290 |
291 | DDRD = 0xFF; // Alle Pins von Port D als Ausgang
292 | PORTD = (0<<PD0)| (0<<PD1)|(0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
293 |
294 | DDRA = 0xFF; // LCD Ausgänge
295 | DDRA &= ~((1<<PA6) | (1<<PA7)); // ADC Eingänge
296 | }
297 |
298 |
299 | int main( void )
300 | {
301 | double dAufloesung = 5000/(2*2*2*2*2*2*2*2*2*2);
302 | char cEingang;
303 | int8_t i=6, k=0;
304 |
305 | LED_PORT = 0xFF;
306 | LED_DDR = 0xFF;
307 |
308 | // Configure debouncing routines
309 | KEY_DDR &= ~ALL_KEYS; // configure key port for input
310 | KEY_PORT |= ALL_KEYS; // and turn on pull up resistors
311 |
312 |
313 | /* IOs initialisieren */
314 |
315 | declaration();
316 | lcd_init();
317 | ADC_Init();
318 | timer0(); // 10ms
319 | sei();
320 |
321 | // Strings aus dem RAM ausgeben
322 | // sinnvoll, wenn Variablen in die Formatierung eingebaut werden sollen.
323 | lcd_clear();
324 | lcd_setcursor(0,0); // (Spalte,Zeile)
325 | lcd_string("System Bereit?");
326 | lcd_setcursor(0,1);
327 | //lcd_string("78 aktiv!");
328 |
329 | for(uint8_t m=6; m<ADCINPUTS; m++)
330 | {
331 | adc[m] = ADC_Read_Avg(m,5);
332 | }
333 | for (uint8_t l=6; l<ADCINPUTS; l++)
334 | {
335 | if(adc[l]>255)flag_high[l]=1;
336 | else flag_high[l]=0;
337 | }
338 | uint8_t x =0;
339 | if(flag_high[6]==1)
340 | {
341 | lcd_string("7");
342 | x++;
343 | lcd_setcursor(x,1);
344 | }
345 | if(flag_high[7]==1)
346 | {
347 | lcd_string("8");
348 | x++;
349 | lcd_setcursor(x,1);
350 | }
351 | lcd_string(" aktiv!");
352 |
353 | for(uint8_t n=0; n<(ADCINPUTS-2); n++)
354 | {
355 | flag_high[n]=0;
356 | }
357 | /*while(menu==0)
358 | {
359 |
360 | if(get_key_short(ALL_KEYS))
361 | {
362 | menu=1;
363 | }
364 | }
365 | lcd_clear();
366 | lcd_setcursor(0,0);
367 | lcd_string("ADC Werte Test!"); // verbraucht unnötig RAM beim AVR
368 | lcd_setcursor(0,1);*/
369 |
370 |
371 |
372 | while(1)
373 | {
374 | //if( get_key_short( 1<<KEY_mitte ))
375 |
376 | //LED_PORT ^= 1<<LED1;
377 | /*
378 | for(uint8_t m=0; m<ADCINPUTS; m++)
379 | {
380 | adc[m] = ADC_Read_Avg(m,5);
381 | } */
382 | if((PINC & 0b00100000)&& (menu!=4))
383 | {
384 | menu=4;
385 | lcd_clear();
386 | lcd_setcursor(0,0);
387 | lcd_string("Poti Test");
388 | }
389 | switch(menu)
390 | {
391 | case 0: // Start
392 | {
393 | if(get_key_short(ALL_KEYS))
394 | {
395 |
396 | lcd_clear();
397 | lcd_setcursor(0,0);
398 | lcd_string("Standardmodus!"); // verbraucht unnötig RAM beim AVR
399 | lcd_setcursor(0,1);
400 | menu=1;
401 | flag_start=0;
402 | }
403 | } break;
404 |
405 | case 1: // Standardbetrieb
406 | {
407 | for(uint8_t m=0; m<ADCINPUTS; m++)
408 | {
409 | adc[m] = ADC_Read_Avg(m,5);
410 | }
411 | for(uint8_t j=6;j<8;j++)
412 | {
413 | if((adc[j]<256) && flag_high[j])
414 | {
415 | lcd_setcursor(k,1);
416 | if(j==6)lcd_string("A");
417 | else if(j==7) lcd_string("B");
418 | k++;
419 | if(k==16)k=0;
420 | }
421 | else if(adc[j]>255)flag_high[j]=1;
422 | }
423 | if(get_key_short(ALL_KEYS))
424 | {
425 | lcd_clear();
426 | lcd_setcursor(0,0);
427 | lcd_string("Testmodus");
428 | countdown = 1000; // 5 Sekunden
429 | flag_firstcount=1;
430 | menu = 2;
431 | LED_PORT = 0x00;
432 | PORTB |= (1<<PB0);
433 | }
434 | } break;
435 | case 2: // Testmodus, ADC läuft weiter, 5 Sekunden ohne Eingabe
436 | {
437 | for(uint8_t m=0; m<ADCINPUTS; m++)
438 | {
439 | adc[m] = ADC_Read_Avg(m,5);
440 | }
441 | if(flag_update_display)
442 | {
443 | flag_update_display =0;
444 | cEingang = '0'+i+1; // ASCII Codes erzeugen
445 | lcd_setcursor(0,1);
446 | sprintf_P(ram_string, PSTR("In %c: %i"), cEingang, (int)(adc[i]*dAufloesung));
447 | lcd_string(ram_string); // hier sinnvoll
448 | }
449 | if( get_key_short( 1<<KEY_unten))
450 | {
451 | LED_PORT ^= 1<<LED0;
452 | countdown = 1000; // 5 Sekunden
453 | }
454 | if( get_key_long( 1<<KEY_unten))
455 | {
456 | LED_PORT ^= 1<<LED1;
457 | countdown = 1000;
458 | }
459 | if( get_key_short( 1<<KEY_oben))
460 | {
461 | LED_PORT ^= 1<<LED1;
462 | countdown = 500; // 5 Sekunden
463 | }
464 | if( get_key_short( 1<<KEY_links))
465 | {
466 | LED_PORT ^= 1<<LED2;
467 | countdown = 1000; // 5 Sekunden
468 | }
469 | if( get_key_short( 1<<KEY_rechts))
470 | {
471 | LED_PORT ^= 1<<LED0;
472 | countdown = 1000; // 5 Sekunden
473 | }
474 | if (get_key_long(1<<KEY_rechts))
475 | {
476 | LED_PORT ^= 1<<LED1;
477 | countdown = 1000; // 5 Sekunden
478 | }
479 | if( get_key_short( 1<<KEY_mitte))
480 | {
481 | i++;
482 | if(i==8)i=6;
483 | countdown = 1000; // 5 Sekunden
484 | flag_update_display=1;
485 | }
486 |
487 | // single press and repeat
488 | if( get_key_press( 1<<KEY_oben ) || get_key_rpt( 1<<KEY_oben ))
489 | {
490 | countdown = 1000; // 5 Sekunden
491 | uint8_t i = LED_PORT;
492 | i = (i & 0x07) | ((i << 1) & 0xF0);
493 | if( i < 0xF0 )
494 | i |= 0x08;
495 | LED_PORT = i;
496 | }
497 | } break;
498 | case 4:
499 | {
500 | for(uint8_t m=0; m<ADCINPUTS; m++)
501 | {
502 | adc[m] = ADC_Read_Avg(m,5);
503 | }
504 | if(adc[i]<128)LED_PORT=0b00000010;
505 | else if((adc[i]>127)&&(adc[i]<256)) LED_PORT=0b00000011;
506 | else if((adc[i]>255)&&(adc[i]<385))LED_PORT=0b00000111;
507 | else if((adc[i]>384)&&(adc[i]<512))LED_PORT=0b00001111;
508 | else if((adc[i]>511)&&(adc[i]<683))LED_PORT=0b00011111;
509 | else if((adc[i]>682)&&(adc[i]<853))LED_PORT=0b00111111;
510 | else if(adc[i]>852)LED_PORT=0b01111111;
511 | if(!(PINC && 0b00100000))flag_countdown=0;
512 | } break;
513 | }
514 | }
515 | }
