1 | Building to ensure sources are up-to-date
2 | Selecting target:
3 | Debug
4 | Adding source dir: /home/sean/Dokumente/iCBox/
5 | Adding source dir: /home/sean/Dokumente/iCBox/
6 | Adding file: /home/sean/Dokumente/iCBox/bin/Debug/iCBox
7 | Changing directory to: /home/sean/Dokumente/iCBox/.
8 | Set variable: LD_LIBRARY_PATH=.:/home/sean/Dokumente/iCBox/linker:
9 |
10 | [debug]Command-line: /usr/bin/arm-none-eabi-gdb -nx -fullname -quiet -args /home/sean/Dokumente/iCBox/bin/Debug/iCBox
11 | [debug]Working dir : /home/sean/Dokumente/iCBox
12 |
13 | Starting debugger: /usr/bin/arm-none-eabi-gdb -nx -fullname -quiet -args /home/sean/Dokumente/iCBox/bin/Debug/iCBox
14 | done
15 |
16 | [debug]Reading symbols from /home/sean/Dokumente/iCBox/bin/Debug/iCBox...
17 | [debug]done.
18 | [debug](gdb)
19 | [debug]> set prompt >>>>>>cb_gdb:
20 |
21 | Registered new type: wxString
22 | Registered new type: STL String
23 | Registered new type: STL Vector
24 | Connecting to remote target
25 | Setting breakpoints
26 |
27 | [debug]>>>>>>cb_gdb:
28 | [debug]> show version
29 | [debug]GNU gdb (7.6.50.20131218-0ubuntu1+1) 7.6.50.20131218-cvs
30 | [debug]Copyright (C) 2013 Free Software Foundation, Inc.
31 | [debug]License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
32 | [debug]This is free software: you are free to change and redistribute it.
33 | [debug]There is NO WARRANTY, to the extent permitted by law. Type "show copying"
34 | [debug]and "show warranty" for details.
35 | [debug]This GDB was configured as "--host=x86_64-linux-gnu --target=arm-none-eabi".
36 | [debug]Type "show configuration" for configuration details.
37 | [debug]For bug reporting instructions, please see:
38 | [debug]<http://www.gnu.org/software/gdb/bugs/>.
39 | [debug]Find the GDB manual and other documentation resources online at:
40 | [debug]<http://www.gnu.org/software/gdb/documentation/>.
41 | [debug]For help, type "help".
42 | [debug]Type "apropos word" to search for commands related to "word".
43 | [debug]>>>>>>cb_gdb:
44 | [debug]> set confirm off
45 |
46 | Debugger name and version: GNU gdb (7.6.50.20131218-0ubuntu1+1) 7.6.50.20131218-cvs
47 |
48 | [debug]>>>>>>cb_gdb:
49 | [debug]> set width 0
50 | [debug]>>>>>>cb_gdb:
51 | [debug]> set height 0
52 | [debug]>>>>>>cb_gdb:
53 | [debug]> set breakpoint pending on
54 | [debug]>>>>>>cb_gdb:
55 | [debug]> set print asm-demangle on
56 | [debug]>>>>>>cb_gdb:
57 | [debug]> set unwindonsignal on
58 | [debug]>>>>>>cb_gdb:
59 | [debug]> set print elements 0
60 | [debug]>>>>>>cb_gdb:
61 | [debug]> set disassembly-flavor intel
62 | [debug]No symbol "disassembly" in current context.
63 | [debug]>>>>>>cb_gdb:
64 | [debug]> catch throw
65 | [debug]Catchpoint 1 (throw)
66 | [debug]>>>>>>cb_gdb:
67 | [debug]> source /usr/share/codeblocks/scripts/stl-views-1.0.3.gdb
68 | [debug]>>>>>>cb_gdb:
69 | [debug]> directory /home/sean/Dokumente/iCBox/
70 | [debug]Source directories searched: /home/sean/Dokumente/iCBox:$cdir:$cwd
71 | [debug]>>>>>>cb_gdb:
72 | [debug]> target remote tcp:localhost:3333
73 | [debug]Queued:[tty /dev/pts/0]
74 | [debug]Remote debugging using tcp:localhost:3333
75 | [debug]0x00000000 in ?? ()
76 | [debug]>>>>>>cb_gdb:
77 |
78 | Connected
79 |
80 | [debug]> monitor halt
81 |
82 | In ?? () ()
83 |
84 | [debug]> monitor halt
85 | [debug]target was in unknown state when halt was requested
86 | [debug]target state: halted
87 | [debug]target halted due to debug-request, current mode: Thread
88 | [debug]xPSR: 0x410f0000 pc: 0x08006024 msp: 0x2001fff8
89 | [debug]>>>>>>cb_gdb:>>>>>>cb_gdb:
90 | [debug]> load ./bin/Debug/iCBox.bin
91 | [debug]"./bin/Debug/iCBox.bin" is not an object file: File format not recognized
92 | [debug]>>>>>>cb_gdb:
93 | [debug]> file ./bin/Debug/iCBox.bin
94 | [debug]"/home/sean/Dokumente/iCBox/./bin/Debug/iCBox.bin": not in executable format: File format not recognized
95 | [debug]>>>>>>cb_gdb:
96 | [debug]> monitor sleep 1000
97 | [debug]>>>>>>cb_gdb:
98 | [debug]> monitor reset
99 | [debug]>>>>>>cb_gdb:
100 | [debug]> tty /dev/pts/0
101 | [debug]>>>>>>cb_gdb:
102 | [debug]> bt 30
103 | [debug]#0 0x00000000 in ?? ()
104 | [debug]#1 0x00000000 in ?? ()
105 | [debug]>>>>>>cb_gdb:
