1 | //DCF-Uhr mit LCD20x4
2 | //ATmega16 @ 16 MHz
3 | //Autor: Johannes Maslowski
4 | //Version 2010-02-28-00-11
5 | //AVR-Studio 4.18 Build 692, WinAVR 20100110
6 |
7 | //Header Dateien
8 | #include <avr/io.h>
9 | #include <avr/interrupt.h>
10 | #include <stdlib.h>
11 | #include "lcd-routines.h"
12 |
13 | /////////////
14 | //Variablen//
15 | /////////////
16 | //date
17 | unsigned char week_day;
18 | unsigned char day;
19 | unsigned char month;
20 | unsigned int year;
21 |
22 | //time
23 | unsigned int hundertstelsecond;
24 | unsigned char second;
25 | unsigned char minute;
26 | unsigned char hour;
27 | unsigned char timezone;
28 |
29 | //Weckzeit
30 | unsigned char alarm_stunde=17;
31 | unsigned char alarm_minute=20;
32 |
33 | //Temperatur
34 | int temperatur;
35 |
36 | //Speicherbereich für DCF-Pegel
37 | unsigned char dataPC;
38 |
39 | //Pegel-Auswertung
40 | unsigned int counter_high;
41 | unsigned int counter_low;
42 | unsigned char bit_number;
43 |
44 | //dcf_date
45 | unsigned char dcf_week_day;
46 | unsigned char dcf_day;
47 | unsigned char dcf_month;
48 | unsigned char dcf_year;
49 | unsigned char dcf_date_parity;
50 |
51 | //dcf_time
52 | unsigned char dcf_second;
53 | unsigned char dcf_minute;
54 | unsigned char dcf_minute_parity;
55 | unsigned char dcf_hour;
56 | unsigned char dcf_hour_parity;
57 | unsigned char dcf_timezone;
58 |
59 | //Puffer für die int --> char Umwandlung
60 | char itoa_buffer[8];
61 |
62 | //Array für die DCF-Datenbits
63 | //uint8_t minute_frame[60]; //wird noch nicht genutzt
64 |
65 | //Schaltjahr
66 | unsigned char leapyear;
67 |
68 | ////////////////////
69 | //Reset-Funktionen//
70 | ////////////////////
71 | void counter_reset(void)
72 | {
73 | counter_high=0;
74 | counter_low=0;
75 | bit_number=0;
76 | }
77 |
78 | void dcf_date_reset(void)
79 | {
80 | dcf_week_day=0;
81 | dcf_day=0;
82 | dcf_month=0;
83 | dcf_year=0;
84 | dcf_date_parity=0;
85 | }
86 |
87 | void dcf_time_reset(void)
88 | {
89 | dcf_minute=0;
90 | dcf_minute_parity=0;
91 | dcf_hour=0;
92 | dcf_hour_parity=0;
93 | dcf_timezone=0;
94 | }
95 |
96 | /////////////
97 | //Sonstiges//
98 | /////////////
99 | //Eine führende 0 ergänzen bei Zahlen kleiner/gleich 9
100 | void leading_0(unsigned char digit)
101 | {
102 | if(digit<=9)
103 | {
104 | lcd_data('0');
105 | }
106 | }
107 |
108 | /////////////////
109 | //LCD-Ausgaben///
110 | /////////////////
111 |
112 | //Intelligy Schriftzug
113 | void show_intelligy_string(unsigned char column,unsigned char row) //Übergabe der Cursorposition (Spalte,Zeile)
114 | {
115 | set_cursor(column,row);
116 |
117 | lcd_string("Intelligy Clock");
118 | }
119 |
120 | //Zusammengeführte Zeit
121 | void show_matched_time(unsigned char column,unsigned char row) //Übergabe der Cursorposition (Spalte,Zeile)
122 | {
123 | set_cursor(column,row);
124 |
125 | //LCD-Ausgabe: Stunde
126 | leading_0(hour);
127 | itoa(hour,itoa_buffer,10);
128 | lcd_string(itoa_buffer);
129 | lcd_data(':');
130 |
131 | //LCD-Ausgabe: Minute
132 | leading_0(minute);
133 | itoa(minute,itoa_buffer,10);
134 | lcd_string(itoa_buffer);
135 | lcd_data(':');
136 |
137 | //LCD-Ausgabe: Sekunde
138 | leading_0(second);
139 | itoa(second,itoa_buffer,10);
140 | lcd_string(itoa_buffer);
141 | // lcd_data(' ');
142 |
143 | }
144 |
145 | //Zusammengeführtes Datum
146 | void show_matched_date(unsigned char column,unsigned char row) //Übergabe der Cursorposition (Spalte,Zeile)
147 | {
148 | set_cursor(column,row);
149 |
150 | //LCD-Ausgabe: Wochentag
151 | switch(week_day)
152 | {
153 | case 1: lcd_string("Mo, ");break; //LCD-Ausgabe: Montag
154 | case 2: lcd_string("Di, ");break; //LCD-Ausgabe: Dienstag
155 | case 3: lcd_string("Mi, ");break; //LCD-Ausgabe: Mittwoch
156 | case 4: lcd_string("Do, ");break; //LCD-Ausgabe: Donnerstag
157 | case 5: lcd_string("Fr, ");break; //LCD-Ausgabe: Freitag
158 | case 6: lcd_string("Sa, ");break; //LCD-Ausgabe: Samstag
159 | case 7: lcd_string("So, ");break; //LCD-Ausgabe: Sonntag
160 | default:lcd_string(" ");break;
161 | }
162 |
163 | //LCD-Ausgabe: Tag
164 | leading_0(day);
165 | itoa(day,itoa_buffer,10);
166 | lcd_string(itoa_buffer);
167 | lcd_data('.');
168 |
169 | //LCD-Ausgabe: Monat
170 | leading_0(month);
171 | itoa(month,itoa_buffer,10);
172 | lcd_string(itoa_buffer);
173 | lcd_string(".");
174 |
175 | //LCD-Ausgabe: Jahreszahl
176 | leading_0(year);
177 | itoa(year,itoa_buffer,10);
178 | lcd_string(itoa_buffer);
179 | }
180 |
181 | //Weckzeit
182 | void show_weckzeit(unsigned char column,unsigned char row)//Übergabe der Cursorposition (Spalte,Zeile)
183 | {
184 |
185 | set_cursor(column,row);
186 |
187 |
188 | lcd_string("Weckzeit: ");
189 |
190 | //LCD Ausgabe Weckstunde
191 |
192 | leading_0(alarm_stunde);
193 | itoa(alarm_stunde,itoa_buffer,10);
194 | lcd_string(itoa_buffer);
195 | lcd_string(":");
196 |
197 | //LCD Ausgabe Weckminute
198 |
199 | leading_0(alarm_minute);
200 | itoa(alarm_minute,itoa_buffer,10);
201 | lcd_string(itoa_buffer);
202 |
203 |
204 |
205 | }
206 |
207 |
208 | //Temperatur
209 | void show_temperatur(unsigned char column,unsigned char row)//Übergabe der Cursorposition (Spalte,Zeile)
210 | {
211 |
212 | set_cursor(column,row);
213 |
214 | //LCD Ausgabe Temperatur
215 |
216 | itoa(temperatur,itoa_buffer,10);
217 | lcd_string(itoa_buffer);
218 |
219 | lcd_string("°C");
220 | }
221 |
222 | ///////////////////////////
223 | //DCF-Synchronisation/////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
224 | //High-Pegel muß für 1700-1900ms anliegen
225 | //Danach muß ein Low-Pegel folgen
226 | void dcf_sync(void)
227 | {
228 | show_matched_date(0,3);
229 | show_matched_time(6,2);
230 | show_weckzeit(0,4);
231 | show_temperatur(17,4);
232 |
233 | //LCD-Ausgabe: Synchronisation läuft gerade
234 | set_cursor(19,1);
235 | lcd_data('?');
236 |
237 | if(!(dataPC & (1<<PINC1)))
238 | {
239 | if(counter_high>=175 && counter_high<=195)
240 | {
241 | //LCD-Ausgabe: Synchronisation erfolgreich
242 | set_cursor(19,1);
243 | lcd_data('!');
244 |
245 | counter_reset();
246 | dcf_date_reset();
247 | dcf_time_reset();
248 | }
249 | else
250 | {
251 | counter_high=0;
252 | dcf_sync();
253 | }
254 | }
255 | else
256 | {
257 | dcf_sync();
258 | }
259 | }
260 |
261 | //////////////////
262 | //DCF-Auswertung//
263 | //////////////////
264 | void dcf_0(void)
265 | {
266 | switch(bit_number)
267 | {
268 | case 0: ;break; //Start einer neuen Minuten, muß immer 0 sein
269 | case 1: ;break; //Wetterdaten
270 | case 2: ;break; //Wetterdaten
271 | case 3: ;break; //Wetterdaten
272 | case 4: ;break; //Wetterdaten
273 | case 5: ;break; //Wetterdaten
274 | case 6: ;break; //Wetterdaten
275 | case 7: ;break; //Wetterdaten
276 | case 8: ;break; //Wetterdaten
277 | case 9: ;break; //Wetterdaten
278 | case 10: ;break; //Wetterdaten
279 | case 11: ;break; //Wetterdaten
280 | case 12: ;break; //Wetterdaten
281 | case 13: ;break; //Wetterdaten
282 | case 14: ;break; //Wetterdaten
283 | case 15: ;break; //Rufbit für PTB
284 | case 16: ;break; //Keine Änderung der Zeitzone
285 | case 17: ;break; //Zeitzone: dcf_timezone=dcf_timezone
286 | case 18: dcf_timezone+=1;break; //Zeitzone:
287 | case 19: ;break; //keine Schaltsekunde
288 | case 20: dcf_sync();break; //Beginn der Zeitinformation (immer 1)
289 | case 21: ;break;
290 | case 22: ;break;
291 | case 23: ;break;
292 | case 24: ;break;
293 | case 25: ;break;
294 | case 26: ;break;
295 | case 27: ;break;
296 | case 28: ;break; //Parität: Minute
297 | case 29: ;break;
298 | case 30: ;break;
299 | case 31: ;break;
300 | case 32: ;break;
301 | case 33: ;break;
302 | case 34: ;break;
303 | case 35: ;break; //Parität: Stunde
304 | case 36: ;break;
305 | case 37: ;break;
306 | case 38: ;break;
307 | case 39: ;break;
308 | case 40: ;break;
309 | case 41: ;break;
310 | case 42: ;break;
311 | case 43: ;break;
312 | case 44: ;break;
313 | case 45: ;break;
314 | case 46: ;break;
315 | case 47: ;break;
316 | case 48: ;break;
317 | case 49: ;break;
318 | case 50: ;break;
319 | case 51: ;break;
320 | case 52: ;break;
321 | case 53: ;break;
322 | case 54: ;break;
323 | case 55: ;break;
324 | case 56: ;break;
325 | case 57: ;break;
326 | case 58: ;break; //Parität: Datum
327 | case 59: dcf_sync();break; //keine Absenkung --> neue Minute
328 | default: dcf_sync();break;
329 | }
330 | }
331 |
332 | void dcf_1(void)
333 | {
334 | switch(bit_number)
335 | {
336 | case 0: dcf_sync();break; //Start einer neuen Minute, muß immer 0 sein
337 | case 1: ;break; //Wetterdaten
338 | case 2: ;break; //Wetterdaten
339 | case 3: ;break; //Wetterdaten
340 | case 4: ;break; //Wetterdaten
341 | case 5: ;break; //Wetterdaten
342 | case 6: ;break; //Wetterdaten
343 | case 7: ;break; //Wetterdaten
344 | case 8: ;break; //Wetterdaten
345 | case 9: ;break; //Wetterdaten
346 | case 10: ;break; //Wetterdaten
347 | case 11: ;break; //Wetterdaten
348 | case 12: ;break; //Wetterdaten
349 | case 13: ;break; //Wetterdaten
350 | case 14: ;break; //Wetterdaten
351 | case 15: ;break; //Rufbit für PTB
352 | case 16: ;break; //Am Ende dieser Stunde wird auf MEZ/MESZ umgestellt
353 | case 17: dcf_timezone+=1;break; //Zeitzone:
354 | case 18: ;break; //Zeitzone: dcf_timezone=dcf_timezone
355 | case 19: ;break; //Am Ende diese Stunde wird eine Schaltsekunde eingefügt.
356 | case 20: ;break; //Beginn der Zeitinformation (immer 1)
357 | case 21: dcf_minute+=1;dcf_minute_parity+=1;break;
358 | case 22: dcf_minute+=2;dcf_minute_parity+=1;break;
359 | case 23: dcf_minute+=4;dcf_minute_parity+=1;break;
360 | case 24: dcf_minute+=8;dcf_minute_parity+=1;break;
361 | case 25: dcf_minute+=10;dcf_minute_parity+=1;break;
362 | case 26: dcf_minute+=20;dcf_minute_parity+=1;break;
363 | case 27: dcf_minute+=40;dcf_minute_parity+=1;break;
364 | case 28: dcf_minute_parity+=1;break; //Parität: Minute
365 | case 29: dcf_hour+=1;dcf_hour_parity+=1;break;
366 | case 30: dcf_hour+=2;dcf_hour_parity+=1;break;
367 | case 31: dcf_hour+=4;dcf_hour_parity+=1;break;
368 | case 32: dcf_hour+=8;dcf_hour_parity+=1;break;
369 | case 33: dcf_hour+=10;dcf_hour_parity+=1;break;
370 | case 34: dcf_hour+=20;dcf_hour_parity+=1;break;
371 | case 35: dcf_hour_parity+=1;break; //Parität: Stunde
372 | case 36: dcf_day+=1;dcf_date_parity+=1;break;
373 | case 37: dcf_day+=2;dcf_date_parity+=1;break;
374 | case 38: dcf_day+=4;dcf_date_parity+=1;break;
375 | case 39: dcf_day+=8;dcf_date_parity+=1;break;
376 | case 40: dcf_day+=10;dcf_date_parity+=1;break;
377 | case 41: dcf_day+=20;dcf_date_parity+=1;break;
378 | case 42: dcf_week_day+=1;dcf_date_parity+=1;break;
379 | case 43: dcf_week_day+=2;dcf_date_parity+=1;break;
380 | case 44: dcf_week_day+=4;dcf_date_parity+=1;break;
381 | case 45: dcf_month+=1;dcf_date_parity+=1;break;
382 | case 46: dcf_month+=2;dcf_date_parity+=1;break;
383 | case 47: dcf_month+=4;dcf_date_parity+=1;break;
384 | case 48: dcf_month+=8;dcf_date_parity+=1;break;
385 | case 49: dcf_month+=10;dcf_date_parity+=1;break;
386 | case 50: dcf_year+=1;dcf_date_parity+=1;break;
387 | case 51: dcf_year+=2;dcf_date_parity+=1;break;
388 | case 52: dcf_year+=4;dcf_date_parity+=1;break;
389 | case 53: dcf_year+=8;dcf_date_parity+=1;break;
390 | case 54: dcf_year+=10;dcf_date_parity+=1;break;
391 | case 55: dcf_year+=20;dcf_date_parity+=1;break;
392 | case 56: dcf_year+=40;dcf_date_parity+=1;break;
393 | case 57: dcf_year+=80;dcf_date_parity+=1;break;
394 | case 58: dcf_date_parity+=1;break; //Parität: Datum
395 | case 59: dcf_sync();break; //keine Absenkung --> neue Minute
396 | default: dcf_sync();break;
397 | }
398 | }
399 | /////////////////////////
400 | //Berechnung Schaltjahr//
401 | /////////////////////////
402 | void leap_year(void)
403 | {
404 | if(year%4==0 && year%100!=0)
405 | {
406 | leapyear=1; //Schaltjahr, da durch 4 teilbar aber nicht durch 100
407 | }
408 | else
409 | {
410 | if(year%4!=0)
411 | {
412 | leapyear=0;//Kein Schaltjahr, da nicht durch 4 teilbar
413 | }
414 | else
415 | {
416 | if(year%400==0)
417 | {
418 | leapyear=1;//Schaltjahre, da durch 400 teilbar
419 | }
420 | else
421 | {
422 | leapyear=0;//Kein Schaltjahr, da durch 100 teilbar aber nicht durch 400
423 | }
424 | }
425 | }
426 | }
427 |
428 |
429 | /////////////////////////////////
430 | //Interrupt Service Routine/////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
431 | //Der Compare Interrupt Handler wird aufgerufen, wenn TCNT0 = OCR0 = 156-1 ist (250 Schritte), d.h. genau alle 10 ms
432 | ISR (TIMER0_COMP_vect)
433 | {
434 | hundertstelsecond++; //Counter für die Millisekunden
435 | dataPC = PINC; //Der aktuelle Pegel vom DCF-Modul wird eingelesen und in dataPC den anderen Funktionen zur Verfügung gestellt
436 | counter_high++; //Counter für die Bit-Auswertung (Dauer des High-Pegels), Rücksetzen muß in den Funktionen geschehen
437 | counter_low++; //Counter für die Bit-Auswertung (Dauer des Low-Pegels), Rücksetzen muß in den Funktionen geschehen
438 | if(hundertstelsecond==100) //"selbstlaufende" Uhr
439 | {
440 | second++;
441 | hundertstelsecond=0;
442 | if(second==60)
443 | {
444 | minute++;
445 | second=0;
446 |
447 | }
448 | if(minute==60)
449 | {
450 | hour++;
451 | minute=0;
452 | }
453 | if(hour==24)
454 | {
455 | day++;
456 | week_day++;
457 | hour=0;
458 | }
459 | if(week_day==8)
460 | {
461 | week_day=1;
462 | }
463 | switch(day)
464 | {
465 | case 29: //Tag 28
466 | {
467 | leap_year();
468 | if(month==2 && leapyear==0)
469 | {
470 | month++;
471 | day=1;
472 | }
473 | }
474 | break;
475 |
476 | case 30: //Tag 29
477 | {
478 | leap_year();
479 | if(month==2 && leapyear==1)
480 | {
481 | month++;
482 | day=1;
483 | }
484 | }
485 | break;
486 |
487 | case 31: //Tag 30
488 | {
489 | if(month==4 || month==6 || month==9 || month==11)
490 | {
491 | month++;
492 | day=1;
493 | }
494 | }
495 | break;
496 |
497 | case 32: //Tag 31
498 | {
499 | if(month==1 || month==3 || month==5 || month==7|| month==8 || month==10 || month==12)
500 | {
501 | month++;
502 | day=1;
503 | }
504 | }
505 | break;
506 |
507 | default: ;break;
508 | }
509 | if(month==13)
510 | {
511 | year++;
512 | month=1;
513 | }
514 | }
515 | }
516 |
517 | ////////////////////////////////////////////////////////
518 | //Zusammenführung der internen Daten und der DCF-Daten//
519 | ////////////////////////////////////////////////////////
520 |
521 | void match_date(void)
522 | {
523 | week_day=dcf_week_day;
524 | day=dcf_day;
525 | month=dcf_month;
526 | year=2000+dcf_year;
527 | }
528 |
529 | void match_time(void)
530 | {
531 | hundertstelsecond=0;
532 | second=0;
533 | minute=dcf_minute;
534 | hour=dcf_hour;
535 | timezone=dcf_timezone;
536 | }
537 |
538 | /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
539 | //////Weckzeit///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
540 | /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////
541 |
542 | void weckzeit(void)
543 | {
544 | if(alarm_stunde==hour)
545 | {
546 | if(alarm_minute==minute)
547 | {
548 | if(PORTB >= 0x80) //wenn LED 8 ein dann
549 | PORTB = 0x01; //setzte wieder LED 1
550 | else
551 | PORTB = PORTB << 1; //ansonsten zähle hoch
552 |
553 | // zeit(500); //0,5s warten
554 | }
555 | else
556 | {
557 | PORTB=0x02;
558 | }
559 | }
560 | else
561 | {
562 | PORTB=0x02;
563 | }
564 | }
565 |
566 | ///////////////////////
567 | //DCF-Pegelauswertung//
568 | ///////////////////////
569 | void level_analysis(void)
570 | {
571 | if(dataPC & (1<<PINC1))
572 | {
573 |
574 | if(counter_low>=3 && counter_low<=15) //logisch 0
575 | {
576 | // minute_frame[bit_number]=0;
577 |
578 | dcf_0();
579 |
580 | bit_number++;
581 | dcf_second++;
582 |
583 | counter_high=0;
584 | counter_low=0;
585 | }
586 | else
587 | {
588 | if(counter_low>=16 && counter_low<=30) //logisch 1
589 | {
590 | // minute_frame[bit_number]=1;
591 |
592 | dcf_1();
593 |
594 | bit_number++;
595 |
596 | counter_high=0;
597 | counter_low=0;
598 | }
599 | else
600 | {
601 | counter_low=0;
602 | }
603 | }
604 | }
605 | else
606 | {
607 | if(counter_high>=175 && counter_high<=195)
608 | {
609 | if(bit_number==59 && dcf_minute_parity%2==0 && dcf_hour_parity%2==0 && dcf_date_parity%2==0)
610 | {
611 | bit_number=0;
612 |
613 | match_date();
614 | match_time();
615 | }
616 | else
617 | {
618 | dcf_date_reset();
619 | dcf_time_reset();
620 |
621 | counter_high=0;
622 |
623 | if(year==0)
624 | {
625 | dcf_sync();
626 | }
627 | }
628 |
629 | counter_high=0;
630 |
631 | dcf_date_reset();
632 | dcf_time_reset();
633 | }
634 | }
635 | }
636 |
637 |
638 |
639 | ////////
640 | //Main//
641 | ////////
642 | int main(void)
643 | {
644 | //Setzen der Port-Richtungsregister
645 | DDRC &= ~(1<<PC1); //PC1 Eingang (0)
646 | DDRB = 0xff;
647 | //Initialisieren der Ports
648 | PORTC |= (1<<PC1); //PC1 Pull-Up gesetzt (1)
649 |
650 | lcd_init(); //Initialisierung des LCDs
651 |
652 | // Timer 0 konfigurieren
653 | TCCR0 = (1<<WGM01) | (1<<CS00) | (1<<CS02); //CTC Modus (1), Prescaler 1024 (1) (1)
654 | OCR0 = 156-1; //((16000000/1024)/100) = 156,25
655 | TIMSK |= (1<<OCIE0); //Compare Interrupt erlauben (1)
656 | sei(); //Global Interrupts aktivieren
657 |
658 | dcf_sync(); //Synchronisierung des DCF-Moduls
659 |
660 | while(1)
661 | {
662 | level_analysis();
663 | show_matched_date(0,3);
664 | show_matched_time(6,2);
665 | // show_weckzeit(0,4);
666 | // show_temperatur(17,4);
667 | weckzeit();
668 |
669 |
670 |
671 | }
672 | }
