Forum: Analoge Elektronik und Schaltungstechnik Analog + Digital Ground or just only a general Ground plane in high speed designs?
von Enrique P. (flote21)
Hello guys,
I have reading some documentation in internet and some people recommend
to use two different ground planes (AGND + DGND) but other people
recommend to use just one good GND plane with the digital part and the
analog part very well placed and differenced.
In my last designs I have been using only one ground plane and I placed
the analog part and the digital part in the right way.And I got good
results (I follow the next TI paper:
http://www.ti.com/lit/an/scaa082/scaa082.pdf),
However, I would like to know which are your experience?
Thanks too much.
von Peter D. (peda)
I use always separate planes and connect them only on a single point
(net-tie).
Since planes are also resistors and inductors, like every wire.
So digital current should not flow during the analog area.
von Alexxx (Gast)
It depends on so much things.
Which digital frequency range you use?
How about disturbances on your ground plane because of connections with
other devices? (Connection with PC etc.)
Best things you can employ:
- proper layout is paramount!
=> keep trace lengths as short as possible
=> keep sensible / high frequency current flows in the smallest possible
loop area
=> use series resistance in your digital output lines to reduce slew
rate of your signals
=> Place high speed and low level analog as far away as possible
=> shield digital signals with surrounding ground lines
=> decouple DC with ferrite beads and special low-impedance ceramic
capacitors
For low level / high accuracy analog measurements (ADC > 14 Bits) it
might be best practice to keep analog & digital ground (and power
supply!)seperated and use optocouplers in between the domains, but this
introduces time delays of 20ns to µs-seconds.
von Carsten W. (eagle38106)
Hi!
We do use only single ground planes over a complete layer in our high
speed designs (> 1 GHz) at work. And it works well. Having split or
interrupted planes always gives you impedance changes at the gap and
therefore the signal quality goes down.
And as you wrote: One single ground plane worked well in your last
design, so why change a running system?
For ripple-pickups in audio circuits, it is a different story.
Cheers,
Carsten
von Peter D. (peda)
I assumed, exact this was the question.
Many Notebooks, MP3-Players and so one have such problems with audible
noise because wrong decoupling of the analog GND/VCC and digital signals
to the analog circuits.
According to the quoted datasheet, it is all about high speed design,
not audio.
von Enrique (Gast)
mmmm I see that there are different opnions respecting to this issue. I
would like to know if there is some kind of gold rule regarding to the
ground planes which is valid for all kind of designs: video, audio, etc.
For example, in theory IPHONE(Apple) is a good product and in therory it
is an example to follow respecting to the PCB design..., Anybody knows
how is the ground plane here?
von Arc N. (arc)
Good question...
The iPhone 4 uses a 10 layer PCB
http://www.eetimes.com/document.asp?doc_id=1259324
and the tear down shows that the audio codec is more or less beneath the
CPU
https://de.ifixit.com/Teardown/iPhone+4+Teardown/3130
For the iPhone 6
https://de.ifixit.com/Teardown/iPhone+6+Teardown/29213
von R23 (Gast)
First look at the current flows.
