1 | #include <avr/io.h>
2 | #include <stdio.h>
3 | #include <stdlib.h>
4 | #include <string.h>
5 | #include "main.h"
6 | #include "lcd.h"
7 | #include <avr/wdt.h>
8 | #include <avr/interrupt.h>
9 | #include <util/delay.h>
10 | #include <inttypes.h>
11 |
12 | #ifndef F_CPU
13 | #define F_CPU 7372800 // processor clock frequency
14 | #warning kein F_CPU definiert
15 | #endif
16 |
17 | #define KEY_DDR DDRC
18 | #define KEY_PORT PORTC
19 | #define KEY_PIN PINC
20 | #define KEY_mitte 7
21 | #define KEY_links 3
22 | #define KEY_rechts 4
23 | #define KEY_oben 6
24 | #define KEY_unten 2
25 | #define ALL_KEYS (1<<KEY_mitte | 1<<KEY_links | 1<<KEY_rechts | 1<<KEY_oben /*| 1<<KEY_unten*/)
26 |
27 | #define REPEAT_MASK (1<<KEY_mitte | 1<<KEY_links | 1<<KEY_rechts | 1<<KEY_oben /*| 1<<KEY_unten*/)
28 | #define REPEAT_START 50 // after 500ms
29 | #define REPEAT_NEXT 20 // every 200ms
30 |
31 | #define LED_DDR DDRD
32 | #define LED_PORT PORTD
33 | #define LED0 0
34 | #define LED1 1
35 | #define LED2 2
36 | #define LED3 3
37 | #define LED4 4
38 | #define LED5 5
39 |
40 | #define ADCINPUTS 8 // Anzahl der ADC Eingänge
41 |
42 | volatile uint8_t key_state; // debounced and inverted key state:
43 | // bit = 1: key pressed
44 | volatile uint8_t key_press; // key press detect
45 |
46 | volatile uint8_t key_rpt; // key long press and repeat
47 |
48 |
49 | void timer0()
50 | {
51 | TCCR0 = (1<<CS02)|(1<<CS00); // divide by 1024
52 | TCNT0 = (-72); // preload for 10ms
53 | TIMSK |= 1<<TOIE0; // enable timer interrupt
54 | }
55 |
56 | ISR( TIMER0_OVF_vect ) // every 10ms
57 | {
58 | static uint8_t ct0, ct1, rpt;
59 | uint8_t i;
60 |
61 | TCNT0 = (-72); // preload for 10ms
62 | i = key_state ^ ~KEY_PIN; // key changed ?
63 | ct0 = ~( ct0 & i ); // reset or count ct0
64 | ct1 = ct0 ^ (ct1 & i); // reset or count ct1
65 | i &= ct0 & ct1; // count until roll over ?
66 | key_state ^= i; // then toggle debounced state
67 | key_press |= key_state & i; // 0->1: key press detect
68 |
69 | if( (key_state & REPEAT_MASK) == 0 ) // check repeat function
70 | rpt = REPEAT_START; // start delay
71 | if( --rpt == 0 )
72 | {
73 | rpt = REPEAT_NEXT; // repeat delay
74 | key_rpt |= key_state & REPEAT_MASK;
75 | }
76 | }
77 |
78 | ///////////////////////////////////////////////////////////////////
79 | //
80 | // check if a key has been pressed. Each pressed key is reported
81 | // only once
82 | //
83 | uint8_t get_key_press( uint8_t key_mask )
84 | {
85 | cli(); // read and clear atomic !
86 | key_mask &= key_press; // read key(s)
87 | key_press ^= key_mask; // clear key(s)
88 | sei();
89 | return key_mask;
90 | }
91 |
92 | ///////////////////////////////////////////////////////////////////
93 | //
94 | // check if a key has been pressed long enough such that the
95 | // key repeat functionality kicks in. After a small setup delay
96 | // the key is reported being pressed in subsequent calls
97 | // to this function. This simulates the user repeatedly
98 | // pressing and releasing the key.
99 | //
100 | uint8_t get_key_rpt( uint8_t key_mask )
101 | {
102 | cli(); // read and clear atomic !
103 | key_mask &= key_rpt; // read key(s)
104 | key_rpt ^= key_mask; // clear key(s)
105 | sei();
106 | return key_mask;
107 | }
108 |
109 | ///////////////////////////////////////////////////////////////////
110 | //
111 | // check if a key is pressed right now
112 | //
113 | uint8_t get_key_state( uint8_t key_mask )
114 | {
115 | key_mask &= key_state;
116 | return key_mask;
117 | }
118 |
119 | ///////////////////////////////////////////////////////////////////
120 | //
121 | uint8_t get_key_short( uint8_t key_mask )
122 | {
123 | cli(); // read key state and key press atomic !
124 | return get_key_press( ~key_state & key_mask );
125 | }
126 |
127 | ///////////////////////////////////////////////////////////////////
128 | //
129 | uint8_t get_key_long( uint8_t key_mask )
130 | {
131 | return get_key_press( get_key_rpt( key_mask ));
132 | }
133 |
134 |
135 | void declaration()
136 | {
137 | /* WDTCR = (1<<WDTOE);
138 | WDTCR &= ~(1<<WDE); // Watchdog deaktivieren */
139 | DDRB = 0xFF; // Blaue LED: Ausgang
140 | PORTB &= ~(1<< PB0);
141 | DDRC = 0x00; // Eingänge
142 | DDRC = ((1 << DDC0) | (1 << DDC1)) ; // PC0-1 Ausgang
143 | PORTC = 0xFF;
144 | PORTC &= ~((1<<PC0) | (1 <<PC1));
145 |
146 | DDRD = 0xFF; // Alle Pins von Port D als Ausgang
147 | PORTD = (0<<PD0)| (0<<PD1)|(0<<PD2)|(0<<PD3)|(0<<PD4)|(0<<PD5)|(0<<PD6);
148 |
149 | DDRA = 0xFF; // LCD Ausgänge
150 | DDRA &= ~((1<<PA6) | (1<<PA7)); // ADC Eingänge
151 | }
152 |
153 | int main( void )
154 | {
155 |
156 |
157 | KEY_DDR &= ~ALL_KEYS; // configure key port for input
158 | KEY_PORT |= ALL_KEYS; // and turn on pull up resistors
159 |
160 | LED_PORT = 0xFF;
161 | LED_DDR = 0xFF;
162 |
163 | // Configure debouncing routines
164 |
165 |
166 |
167 | /* IOs initialisieren */
168 |
169 | declaration();
170 |
171 |
172 |
173 | timer0(); // 10ms
174 | sei();
175 |
176 | while(1)
177 | {
178 |
179 |
180 | if(get_key_short(KEY_links)) PORTD ^= (1<<PD0);
181 | if(get_key_short(KEY_rechts)) PORTD ^= (1<<PD1);
182 | if(get_key_short(KEY_oben)) PORTD ^= (1<<PD2);
183 | if(get_key_short(KEY_unten)) PORTD ^= (1<<PD3);
184 | if(get_key_short(KEY_mitte)) PORTD ^= (1<<PD4);
185 |
186 |
187 | if(get_key_long(KEY_links)) PORTD ^= (1<<PD0);
188 | if(get_key_long(KEY_rechts)) PORTD ^= (1<<PD1);
189 | if(get_key_long(KEY_oben)) PORTD ^= (1<<PD2);
190 | if(get_key_short(KEY_unten)) PORTD ^= (1<<PD3);
191 | if(get_key_long(KEY_mitte)) PORTD ^= (1<<PD4);
192 | }
193 | }
