1 | // Example testing sketch for various DHT humidity/temperature sensors
2 | // Written by ladyada, public domain
3 |
4 | #include "DHT.h"
5 | #include <RCSwitch.h>
6 |
7 | RCSwitch mySwitch = RCSwitch();
8 |
9 | #define DHTPIN 8 // what pin we're connected to
10 |
11 | // Uncomment whatever type you're using!
12 | //#define DHTTYPE DHT11 // DHT 11
13 | #define DHTTYPE DHT22 // DHT 22 (AM2302)
14 | //#define DHTTYPE DHT21 // DHT 21 (AM2301)
15 |
16 | // Connect pin 1 (on the left) of the sensor to +5V
17 | // NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
18 | // to 3.3V instead of 5V!
19 | // Connect pin 2 of the sensor to whatever your DHTPIN is
20 | // Connect pin 4 (on the right) of the sensor to GROUND
21 | // Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
22 |
23 | // Initialize DHT sensor for normal 16mhz Arduino
24 | DHT dht(DHTPIN, DHTTYPE);
25 | // NOTE: For working with a faster chip, like an Arduino Due or Teensy, you
26 | // might need to increase the threshold for cycle counts considered a 1 or 0.
27 | // You can do this by passing a 3rd parameter for this threshold. It's a bit
28 | // of fiddling to find the right value, but in general the faster the CPU the
29 | // higher the value. The default for a 16mhz AVR is a value of 6. For an
30 | // Arduino Due that runs at 84mhz a value of 30 works.
31 | // Example to initialize DHT sensor for Arduino Due:
32 | //DHT dht(DHTPIN, DHTTYPE, 30);
33 |
34 | void setup() {
35 | Serial.begin(9600);
36 | Serial.println("DHTxx test!");
37 |
38 | dht.begin();
39 | // Transmitter is connected to Arduino Pin #10
40 | mySwitch.enableTransmit(10);
41 | // Optional set pulse length.
42 | mySwitch.setPulseLength(313);
43 | // Optional set protocol (default is 1, will work for most outlets)
44 | mySwitch.setProtocol(1);
45 | // Optional set number of transmission repetitions.
46 | // mySwitch.setRepeatTransmit(15);
47 |
48 | }
49 |
50 | void loop() {
51 | // Wait a few seconds between measurements.
52 | delay(2000);
53 |
54 | // Reading temperature or humidity takes about 250 milliseconds!
55 | // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
56 | float h = dht.readHumidity();
57 | // Read temperature as Celsius
58 | float t = dht.readTemperature();
59 | // Read temperature as Fahrenheit
60 | float f = dht.readTemperature(true);
61 |
62 | // Check if any reads failed and exit early (to try again).
63 | if (isnan(h) || isnan(t) || isnan(f)) {
64 | Serial.println("Failed to read from DHT sensor!");
65 | return;
66 | }
67 |
68 | // Compute heat index
69 | // Must send in temp in Fahrenheit!
70 | float hi = dht.computeHeatIndex(f, h);
71 |
72 | Serial.print("Humidity: ");
73 | Serial.print(h);
74 | Serial.print(" %\t");
75 | Serial.print("Temperature: ");
76 | Serial.print(t);
77 | Serial.print(" *C ");
78 | Serial.print(f);
79 | Serial.print(" *F\t");
80 | Serial.print("Heat index: ");
81 | Serial.print(hi);
82 | Serial.println(" *F");
83 |
84 |
85 | mySwitch.send("000001000000010101010001 "); //einschalten
86 | delay(1000);
87 | mySwitch.send("000001000000010101010100 "); //ausschalten
88 | delay(1000);
89 | }
