1 | /**
2 | * The common bootloader for RX and TX
3 | */
4 |
5 | #include <avr/io.h>
6 | #include <avr/interrupt.h>
7 | #include <avr/pgmspace.h>
8 | #include <avr/eeprom.h>
9 | #include <avr/boot.h>
10 | #include <stdlib.h>
11 | #include <string.h>
12 | #include <util/crc16.h>
13 | #include <avr/wdt.h>
14 |
15 | #include "../global_files/avr_helper.h"
16 |
17 | #if defined(_TYPE_1001_) || defined(_TYPE_1002_) || defined(_TYPE_1004_)
18 | #warning "compiling mega32"
19 | #define RESET_SOURCE_MASK (_BV(JTRF)|_BV(WDRF)|_BV(BORF)|_BV(EXTRF)|_BV(PORF))
20 | #elif _TYPE_1003_
21 | #warning "compiling mega328(p)"
22 | #define RESET_SOURCE_MASK (_BV(WDRF)|_BV(BORF)|_BV(EXTRF)|_BV(PORF))
23 | #elif _TYPE_1006_
24 | #warning "compiling mega1284p"
25 | #define RESET_SOURCE_MASK (_BV(WDRF)|_BV(BORF)|_BV(EXTRF)|_BV(PORF))
26 | #else
27 | #error "This code is not yet done for this module type"
28 | #endif
29 |
30 | char rxbuffer_boot[SPM_PAGESIZE*2+20]; // This is a hughe array, but we are in the bootloader and have all for us
31 | char txbuffer[40];
32 | uint16_t rxpos_boot = 0; // anzahl empfangener Zeichen
33 | uint8_t txpos = 0; // anzahl zu sendender Zeichen
34 | uint8_t txspos = 0; // nächstes zu senden
35 | uint8_t myAddress = MY_DEF_ADDR; // unsere Adresse
36 | uint32_t page = 0;
37 | uint16_t crc = 0;
38 | uint16_t shouldCrc = 0;
39 |
40 | /**
41 | * The different states of the bootloader
42 | */
43 | enum
44 | {
45 | BOOT_CMD = 1,
46 | BOOT_DATA,
47 | BOOT_CHK
48 | };
49 |
50 | #define PROGMEM_CRC_ADDR 0x0000
51 |
52 | void (*startMainApp)( void ) = 0x0000; /* Funktionspointer auf 0x0000 */
53 |
54 | /*
55 | FUSES =
56 | {
57 | .low = 0xFF, // 0xff
58 | .high = ( FUSE_EESAVE & FUSE_SPIEN & FUSE_CKOPT & FUSE_BOOTSZ1 & FUSE_BOOTSZ0 ) // 0xc1
59 | };
60 | */
61 | #if defined(_TYPE_1001_) || defined(_TYPE_1002_) || defined(_TYPE_1004_)
62 | FUSES =
63 | {
64 | 0xFF,
65 | ( FUSE_EESAVE & FUSE_SPIEN & FUSE_CKOPT & FUSE_BOOTSZ1 & FUSE_BOOTSZ0 ) // 0xc1
66 | //EFUSE_DEFAULT
67 | };
68 | #elif defined (_TYPE_1006_) || defined (_TYPE_1003_)
69 | FUSES =
70 | {
71 | 0xFD,
72 | ( FUSE_EESAVE & FUSE_SPIEN & FUSE_BOOTSZ1 & FUSE_BOOTSZ0 ), // 0xc1
73 | 0xFF
74 | //EFUSE_DEFAULT
75 | };
76 | #endif
77 | void ( *bootloader ) ( void ) = (void(*)(void))0x3800;
78 |
79 |
80 | /**
81 | * converts AH to uint8_t value
82 | */
83 | uint8_t ahtoUint8 ( uint8_t *data )
84 | {
85 | uint8_t val = 0;
86 |
87 | for ( uint8_t i = 0 ; i < 2 ; i++ )
88 | {
89 | if ( ( data[i] >= '0' ) && ( data[i] <= '9' ) )
90 | val = ( val * 16 ) + ( data[i] - '0' );
91 | else if ( ( data[i] >= 'a' ) && ( data[i] <= 'f' ) )
92 | val = ( val * 16 ) + ( data[i] - 'a' + 0x0a );
93 | else
94 | break;
95 | }
96 |
97 | return val;
98 | }
99 |
100 | /**
101 | * converts AH to uint16_t value
102 | */
103 | uint16_t ahtoUint16 ( uint8_t *data )
104 | {
105 | uint16_t val = 0;
106 |
107 | for ( uint8_t i = 0 ; i < 4 ; i++ )
108 | {
109 | if ( ( data[i] >= '0' ) && ( data[i] <= '9' ) )
110 | val = ( val * 16 ) + ( data[i] - '0' );
111 | else if ( ( data[i] >= 'a' ) && ( data[i] <= 'f' ) )
112 | val = ( val * 16 ) + ( data[i] - 'a' + 0x0a );
113 | else
114 | break;
115 | }
116 |
117 | return val;
118 | }
119 |
120 | /**
121 | * convert uint16_t to AH. The result is stored in buffer
122 | */
123 | char* uint16ToAh ( char *buffer, uint16_t val )
124 | {
125 | uint16_t t = val;
126 | uint8_t z;
127 |
128 | for ( uint8_t i = 0 ; i < 4 ; i++ )
129 | {
130 | z = ( uint8_t ) ( ( t & 0xF000 ) >> 12 );
131 | t = t << 4;
132 |
133 | if ( ( z >= 0 ) && ( z <= 9 ) )
134 | buffer[i] = z + '0';
135 | else if ( ( z >= 0x0a ) && ( z <= 0x0f ) )
136 | buffer[i] = z + 'a' - 10;
137 | }
138 |
139 | buffer[4] = 0;
140 |
141 | return buffer;
142 | }
143 |
144 | /**
145 | * convert uint8_t to AH. The result is stored in buffer
146 | */
147 | char* uint8ToAh ( char *buffer, uint8_t val )
148 | {
149 | uint8_t t = val;
150 | uint8_t z;
151 |
152 | for ( uint8_t i = 0 ; i < 2 ; i++ )
153 | {
154 | z = ( uint8_t ) ( ( t & 0xF0 ) >> 4 );
155 | t = t << 4;
156 |
157 | if ( ( z >= 0 ) && ( z <= 9 ) )
158 | buffer[i] = z + '0';
159 | else if ( ( z >= 0x0a ) && ( z <= 0x0f ) )
160 | buffer[i] = z + 'a' - 10;
161 | }
162 |
163 | buffer[2] = 0;
164 |
165 | return buffer;
166 | }
167 |
168 | /**
169 | * Append Zero terminated string to TX buffer
170 | */
171 | void uartPuts(const char *sb)
172 | {
173 | int len = strlen(sb);
174 | if ((txpos+len) < sizeof(txbuffer))
175 | {
176 | strcat(txbuffer, sb);
177 | txpos+=strlen(sb);
178 | }
179 | }
180 |
181 | #define MSG "BOOT" /*SPM_PAGESIZE "\r\n"*/
182 |
183 | /**
184 | * setup UART comm port
185 | */
186 | void initUart(uint16_t baud)
187 | {
188 | uint16_t ubrr = ( uint16_t ) ( ( ( uint32_t ) F_CPU / ( 16UL * baud ) ) - 1 );
189 |
190 | #if defined(_TYPE_1001_) || defined(_TYPE_1002_) || defined(_TYPE_1004_)
191 | UBRRH = ( uint8_t ) ( ubrr << 8 ) & 0x0F;
192 | UBRRL = ( uint8_t ) ( ubrr & 0xFF );
193 |
194 | UCSRA = _BVC(U2X) | _BVC(MPCM);
195 |
196 | UCSRB = _BV ( RXEN ) | _BV ( TXEN ) | _BVC( RXCIE ) | _BVC(UCSZ2);
197 |
198 | UCSRC = _BV ( URSEL ) | _BVC(UMSEL) | _BV ( UCSZ1 ) | _BV ( UCSZ0 ) | _BVC(USBS) | _BVC(UPM1) | _BVC(UPM0) | _BVC(UCPOL);
199 | #elif defined (_TYPE_1006_) || defined (_TYPE_1003_)
200 | UBRR0H = ( uint8_t ) ( ubrr << 8 ) & 0x0F;
201 | UBRR0L = ( uint8_t ) ( ubrr & 0xFF );
202 |
203 | UCSR0A = _BVC(U2X0) | _BVC(MPCM0);
204 |
205 | UCSR0B = _BV ( RXEN0 ) | _BV ( TXEN0 ) | _BVC( RXCIE0 ) | _BVC(UCSZ02);
206 |
207 | UCSR0C = _BVC ( UMSEL01 ) | _BVC(UMSEL00) | _BV ( UCSZ01 ) | _BV ( UCSZ00 ) | _BVC(USBS0) | _BVC(UPM01) | _BVC(UPM00) | _BVC(UCPOL0);
208 | #endif
209 | }
210 |
211 |
212 |
213 | /**
214 | * write a buffer to flash page.
215 | * This is 1:1 from the avrlibc documentation
216 | */
217 | void boot_program_page (uint32_t page, uint8_t *buf)
218 | {
219 | uint16_t i;
220 | uint8_t sreg;
221 |
222 | uint8_t z='0'+page;
223 |
224 | // Disable interrupts.
225 |
226 | sreg = SREG;
227 | cli();
228 |
229 | eeprom_busy_wait ();
230 |
231 | boot_page_erase (page);
232 | boot_spm_busy_wait (); // Wait until the memory is erased.
233 |
234 | for (i=0; i<SPM_PAGESIZE; i+=2)
235 | {
236 | // Set up little-endian word.
237 |
238 | uint16_t w = *buf++;
239 | w += (*buf++) << 8;
240 |
241 | boot_page_fill (page + i, w);
242 | }
243 |
244 | boot_page_write (page); // Store buffer in flash page.
245 | boot_spm_busy_wait(); // Wait until the memory is written.
246 |
247 | // Reenable RWW-section again. We need this if we want to jump back
248 | // to the application after bootloading.
249 |
250 | boot_rww_enable ();
251 |
252 | // Re-enable interrupts (if they were ever enabled).
253 |
254 | SREG = sreg;
255 | }
256 |
257 | /**
258 | * Send the header of a command
259 | */
260 | void sendHeader(uint8_t toAddr)
261 | {
262 | char buffer[6];
263 | uartPuts("@");
264 | uartPuts(uint8ToAh(buffer, toAddr));
265 | uartPuts(uint8ToAh(buffer, myAddress));
266 | }
267 |
268 | /**
269 | * send module ID
270 | */
271 | void sendModuleID(uint8_t toAddr)
272 | {
273 | char buffer[6];
274 | sendHeader(toAddr);
275 | uartPuts("T");
276 | uartPuts(uint16ToAh(buffer, MODULE_ID));
277 | uartPuts("\r");
278 | }
279 |
280 | /**
281 | * Send flash page size
282 | * This is used by the app to adjust data send
283 | */
284 | void sendPageSize(uint8_t toAddr)
285 | {
286 | char buffer[6];
287 | sendHeader(toAddr);
288 | uartPuts("BT");
289 | uartPuts(uint16ToAh(buffer, SPM_PAGESIZE));
290 | uartPuts("\r");
291 | }
292 |
293 | /**
294 | * Send ACK for reboot command
295 | */
296 | void sendRebootACK(uint8_t toAddr)
297 | {
298 | char buffer[6];
299 | sendHeader(toAddr);
300 | uartPuts("RTA");
301 | uartPuts("\r");
302 | }
303 |
304 | /**
305 | * Send Bot loader ACK
306 | */
307 | void sendBootloaderACK(uint8_t toAddr)
308 | {
309 | char buffer[6];
310 | sendHeader(toAddr);
311 | uartPuts("BLA");
312 | uartPuts(uint16ToAh(buffer, page));
313 | uartPuts("\r");
314 | }
315 |
316 | /**
317 | * Send bootloader NACK
318 | */
319 | void sendBootloaderNACKcrc(uint8_t toAddr)
320 | {
321 | char buffer[6];
322 | sendHeader(toAddr);
323 | uartPuts("BLNcrc");
324 | uartPuts(uint16ToAh(buffer, crc));
325 | uartPuts(",sh ");
326 | uartPuts(uint16ToAh(buffer, shouldCrc));
327 | uartPuts("\r");
328 | }
329 |
330 | /**
331 | * Send Prog CRC
332 | */
333 | void sendProgCRC(uint8_t toAddr, uint16_t crc)
334 | {
335 | char buffer[6];
336 | sendHeader(toAddr);
337 | uartPuts("CRC");
338 | uartPuts(uint16ToAh(buffer, crc));
339 | uartPuts(uint16ToAh(buffer, eeprom_read_word(PROGMEM_CRC_ADDR)));
340 | uartPuts("\r");
341 | }
342 |
343 | void sendBootloaderNACK(uint8_t toAddr)
344 | {
345 | char buffer[6];
346 | sendHeader(toAddr);
347 | uartPuts("BLN");
348 | uartPuts("\r");
349 | }
350 |
351 | /**
352 | * Send Bootloader start downbload ACK or NACK
353 | */
354 | void sendBootloaderStartACK(uint8_t toAddr, uint8_t ack)
355 | {
356 | char buffer[6];
357 | sendHeader(toAddr);
358 | if (ack)
359 | uartPuts("BSA\r");
360 | else
361 | uartPuts("BSN\r");
362 | }
363 |
364 |
365 | uint8_t doTransmitUart(void)
366 | {
367 | // Handle transmit data
368 | #if defined(_TYPE_1001_) || defined(_TYPE_1002_) || defined(_TYPE_1004_)
369 | if ((txpos > 0) && (UCSRA & _BV(UDRE)))
370 | #elif defined (_TYPE_1006_) || defined (_TYPE_1003_)
371 | if ((txpos > 0) && (UCSR0A & _BV(UDRE0)))
372 | #endif
373 | {
374 | #if defined(_TYPE_1001_) || defined(_TYPE_1002_) || defined(_TYPE_1004_)
375 | UDR = txbuffer[txspos];
376 | #elif defined (_TYPE_1006_) || defined (_TYPE_1003_)
377 | UDR0 = txbuffer[txspos];
378 | #endif
379 | txspos++;
380 |
381 | if (txspos >= txpos)
382 | {
383 | txspos = 0;
384 | txpos = 0;
385 | txbuffer[0] = 0;
386 | }
387 | }
388 | return txpos;
389 | }
390 |
391 | /**
392 | * Caclulate program CRC
393 | * This function calculate the CRC over all program space
394 | */
395 | uint16_t calcProgCRC(void)
396 | {
397 | crc = 0;
398 | for (uint16_t i=0; i<(BOOTLOADER_ADR); i++)
399 | {
400 | crc = _crc_xmodem_update(crc, pgm_read_byte ( i ));
401 | }
402 | return crc;
403 | }
404 |
405 |
406 |
407 | /**
408 | * Our main loop
409 | */
410 | int main ( void )
411 | {
412 | #if defined(_TYPE_1001_) || defined(_TYPE_1002_) || defined(_TYPE_1004_)
413 | uint8_t resetSource = MCUCSR & RESET_SOURCE_MASK;
414 | MCUCSR &= ~RESET_SOURCE_MASK;
415 | #elif defined (_TYPE_1006_) || defined (_TYPE_1003_)
416 | uint8_t resetSource = MCUSR & RESET_SOURCE_MASK;
417 | MCUSR &= ~RESET_SOURCE_MASK;
418 | #endif
419 | wdt_disable(); // Important or we risk a mess
420 | cli();
421 |
422 |
423 | initUart ( 38400 );
424 |
425 |
426 | uint8_t status = BOOT_CMD;
427 | uint8_t toAddr = 0x00;
428 | uint8_t fromAddr = myAddress;
429 | uint16_t fwsize = 0; // size of fw to load
430 | uint16_t rxfwsize = 0; // size of received size
431 | char buffer[10];
432 | uint8_t cmd_rx = 0;
433 |
434 | // we just forced into boot loader
435 | // aCK this and report page size !
436 | //sendModuleID(toAddr);
437 | //while (doTransmitUart());
438 | uint16_t iscrc = calcProgCRC();
439 | sendProgCRC(ADDR_BROADCAST_DEF, iscrc);
440 | while(doTransmitUart());
441 |
442 | sendPageSize(ADDR_BROADCAST_DEF);
443 | while (doTransmitUart()); // Empty TX buffer
444 |
445 | while ( 1 )
446 | {
447 | /*
448 | * IF get this far without any reset source set,
449 | * we are directly called by the main app
450 | * So we have to skip the CRC check and directly continue with the bootloader
451 | */
452 | if (resetSource != 0) // not jumped in on purpose (from main app)
453 | {
454 | /*
455 | * We have come here after a reset. We now check the CRC of tzhe program
456 | * If it is ok, we will start the main app. If not, we will continue
457 | * with the boot loader
458 | */
459 | if (iscrc == eeprom_read_word(PROGMEM_CRC_ADDR))
460 | {
461 | static uint16_t delay=0xffff;
462 | delay--;
463 | if (delay == 0)
464 | {
465 | sendHeader(ADDR_BROADCAST_DEF);
466 | uartPuts("MPCRCOk\r");
467 | startMainApp(); // reboot into main prog
468 | }
469 | }
470 | else
471 | {
472 | sendHeader(ADDR_BROADCAST_DEF);
473 | //uartPuts("MPCRCErr\r");
474 | }
475 | }
476 | while (doTransmitUart()); // Empty TX buffer
477 |
478 | // Handle receive data
479 | char c = 0;
480 | #if defined(_TYPE_1001_) || defined(_TYPE_1002_) || defined(_TYPE_1004_)
481 | if (UCSRA & _BV(RXC))
482 | {
483 | c = UDR;
484 | #elif defined (_TYPE_1006_) || defined (_TYPE_1003_)
485 | if (UCSR0A & _BV(RXC0))
486 | {
487 | c = UDR0;
488 | #endif
489 | rxbuffer_boot[rxpos_boot] = c;
490 | rxpos_boot++;
491 | if (c == '\r')
492 | {
493 | resetSource = 0; // Stay here
494 | cmd_rx = 1;
495 | }
496 | if (rxpos_boot > sizeof(rxbuffer_boot))
497 | {
498 | rxpos_boot=0;
499 | }
500 |
501 | }
502 | doTransmitUart();
503 | if (cmd_rx == 1)
504 | {
505 | uint8_t error = 0;
506 | // If the syntax is not correct, we will simply ignore the rest and fall through.
507 | if ((rxbuffer_boot[0] == '@') || (rxpos_boot >= 7)) // "@" + <adr> + B + <cmd> + <optional data>
508 | {
509 | toAddr = ahtoUint8((uint8_t*)&rxbuffer_boot[1]);
510 | fromAddr = ahtoUint8((uint8_t*)&rxbuffer_boot[3]);
511 | if ((toAddr == myAddress) || (toAddr == ADDR_BROADCAST_DEF))
512 | {
513 | // Ok, this is a message for us !
514 | if ((rxbuffer_boot[5] == 'T') && (rxbuffer_boot[6] == '?'))
515 | {
516 | sendModuleID(fromAddr);
517 | }
518 | else if ((rxbuffer_boot[5] == 'R') && (rxbuffer_boot[6] == 'T'))
519 | {
520 | sendRebootACK(fromAddr);
521 | wdt_enable(WDTO_250MS);
522 | }
523 | else if (0) //(rxbuffer_boot[5] == 'D') && (rxbuffer_boot[6] == 'F'))
524 | {
525 | for (uint16_t s=0; s<(0x7fff) ; s+=SPM_PAGESIZE)
526 | {
527 | uartPuts("\r\n");
528 | uartPuts(uint16ToAh(buffer, s));
529 | uartPuts(">");
530 |
531 | while (txpos)
532 | doTransmitUart();
533 |
534 |
535 | for (uint8_t b=0; b<SPM_PAGESIZE ; b++)
536 | {
537 | uartPuts(uint8ToAh(buffer, pgm_read_byte((uint8_t*)(b+s)) ));
538 |
539 | while (txpos)
540 | doTransmitUart();
541 | }
542 | }
543 | }
544 | else if ((rxbuffer_boot[5] == 'B') && (rxbuffer_boot[6] == 'T'))
545 | {
546 | sendPageSize(fromAddr);
547 | //startMainApp();
548 | //bootloader(); // jump back from bootloader to bootloader, does make sense ? :-)
549 | }
550 | else if ((rxbuffer_boot[5] == 'B') && (rxbuffer_boot[6] == 'P'))
551 | {
552 | //sendPageSize(fromAddr);
553 | startMainApp();
554 | //bootloader(); // jump back from bootloader to bootloader, does make sense ? :-)
555 | }
556 | else if ((rxbuffer_boot[5] == 'B') && (rxbuffer_boot[6] == 'L') && (rxpos_boot >= 9))
557 | {
558 | uint8_t bytecnt = ahtoUint8((uint8_t*)&rxbuffer_boot[7]);
559 | uint8_t offset = 9;
560 | if (rxpos_boot >= ((bytecnt*2)+offset+4))
561 | {
562 | uint16_t pos;
563 | // reformat data to binary
564 | // we reuse the rx array, as we are sure no additional data comes in (we are stuck here, right !)
565 | // this is save
566 | crc = 0;
567 | for (uint16_t i = 0 ; i < bytecnt ; i++)
568 | {
569 | pos = (i*2)+offset;
570 | rxbuffer_boot[i] = ahtoUint8((uint8_t*)&rxbuffer_boot[pos]);
571 | crc = _crc_xmodem_update(crc, rxbuffer_boot[i]);
572 | }
573 |
574 | rxfwsize+=bytecnt;
575 |
576 | // get should crc
577 | pos = (bytecnt*2)+offset;
578 | shouldCrc = ahtoUint16((uint8_t*)&rxbuffer_boot[pos]);
579 |
580 | // Fill remainder of page
581 | if (bytecnt < SPM_PAGESIZE)
582 | {
583 | for (uint16_t i = bytecnt ; i < SPM_PAGESIZE ; i++)
584 | rxbuffer_boot[i] = 0xFF; // Will be ignored by CPU !
585 | }
586 |
587 | if (crc == shouldCrc)
588 | {
589 | // now write flash
590 | boot_program_page(page, (uint8_t*)rxbuffer_boot);
591 |
592 | page+=SPM_PAGESIZE;
593 |
594 | if (rxfwsize >= fwsize)
595 | {
596 | uint16_t iscrc = calcProgCRC();
597 | eeprom_write_word((uint16_t*)PROGMEM_CRC_ADDR, iscrc);
598 | sendProgCRC(ADDR_BROADCAST_DEF, iscrc);
599 | }
600 |
601 | sendBootloaderACK(fromAddr);
602 |
603 | }
604 | else
605 | {
606 | sendBootloaderNACKcrc(fromAddr);
607 | }
608 | }
609 | else
610 | {
611 | sendBootloaderNACK(fromAddr);
612 | }
613 | }
614 | else if ((rxbuffer_boot[5] == 'B') && (rxbuffer_boot[6] == 'S') && (rxpos_boot >= 15))
615 | {
616 | uint16_t id = ahtoUint16((uint8_t*)&rxbuffer_boot[7]);
617 | if (id == MODULE_ID)
618 | {
619 | fwsize = ahtoUint16((uint8_t*)&rxbuffer_boot[11]);
620 | if (fwsize > 0)
621 | {
622 | sendBootloaderStartACK(fromAddr, 1);
623 | page = 0;
624 | }
625 | else
626 | {
627 | error = 2;
628 | }
629 | }
630 | else
631 | error = 1;
632 | if (error)
633 | {
634 | sendBootloaderStartACK(fromAddr, 0);
635 | }
636 | }
637 | else
638 | {
639 | //sendUnknownCmd(fromAddr);
640 | }
641 | }
642 | }
643 | rxpos_boot = 0;
644 | cmd_rx = 0;
645 | }
646 | }
647 | }
