1 | --- /home/marcel/Arduino/Projekte/TEST/blink test ISP 2313/test/ohne/main.lss
2 | +++ /home/marcel/Arduino/Projekte/TEST/blink test ISP 2313/test/mit/main.lss
3 | @@ -3,29 +3,29 @@
4 |
5 | Sections:
6 | Idx Name Size VMA LMA File off Algn
7 | - 0 .text 00000064 00000000 00000000 00000074 2**1
8 | + 0 .text 00000066 00000000 00000000 00000074 2**1
9 | CONTENTS, ALLOC, LOAD, READONLY, CODE
10 | - 1 .data 00000000 00800060 00000064 000000d8 2**0
11 | + 1 .data 00000000 00800060 00000066 000000da 2**0
12 | CONTENTS, ALLOC, LOAD, DATA
13 | - 2 .stab 000006b4 00000000 00000000 000000d8 2**2
14 | + 2 .stab 000006b4 00000000 00000000 000000dc 2**2
15 | CONTENTS, READONLY, DEBUGGING
16 | - 3 .stabstr 00000054 00000000 00000000 0000078c 2**0
17 | + 3 .stabstr 00000054 00000000 00000000 00000790 2**0
18 | CONTENTS, READONLY, DEBUGGING
19 | - 4 .comment 00000011 00000000 00000000 000007e0 2**0
20 | + 4 .comment 00000011 00000000 00000000 000007e4 2**0
21 | CONTENTS, READONLY
22 | - 5 .debug_aranges 00000020 00000000 00000000 000007f1 2**0
23 | + 5 .debug_aranges 00000028 00000000 00000000 000007f5 2**0
24 | CONTENTS, READONLY, DEBUGGING
25 | - 6 .debug_info 00000165 00000000 00000000 00000811 2**0
26 | + 6 .debug_info 00000179 00000000 00000000 0000081d 2**0
27 | CONTENTS, READONLY, DEBUGGING
28 | - 7 .debug_abbrev 000000da 00000000 00000000 00000976 2**0
29 | + 7 .debug_abbrev 000000f2 00000000 00000000 00000996 2**0
30 | CONTENTS, READONLY, DEBUGGING
31 | - 8 .debug_line 0000009c 00000000 00000000 00000a50 2**0
32 | + 8 .debug_line 000000a9 00000000 00000000 00000a88 2**0
33 | CONTENTS, READONLY, DEBUGGING
34 | - 9 .debug_frame 00000024 00000000 00000000 00000aec 2**2
35 | + 9 .debug_frame 00000034 00000000 00000000 00000b34 2**2
36 | CONTENTS, READONLY, DEBUGGING
37 | - 10 .debug_str 00000160 00000000 00000000 00000b10 2**0
38 | + 10 .debug_str 0000015f 00000000 00000000 00000b68 2**0
39 | CONTENTS, READONLY, DEBUGGING
40 | - 11 .debug_ranges 00000010 00000000 00000000 00000c70 2**0
41 | + 11 .debug_ranges 00000018 00000000 00000000 00000cc7 2**0
42 | CONTENTS, READONLY, DEBUGGING
43 |
44 | Disassembly of section .text:
45 | @@ -56,55 +56,62 @@
46 | 28: 1f be out 0x3f, r1 ; 63
47 | 2a: cf ed ldi r28, 0xDF ; 223
48 | 2c: cd bf out 0x3d, r28 ; 61
49 | - 2e: 02 d0 rcall .+4 ; 0x34 <main>
50 | - 30: 17 c0 rjmp .+46 ; 0x60 <_exit>
51 | + 2e: 03 d0 rcall .+6 ; 0x36 <main>
52 | + 30: 18 c0 rjmp .+48 ; 0x62 <_exit>
53 |
54 | 00000032 <__bad_interrupt>:
55 | 32: e6 cf rjmp .-52 ; 0x0 <__vectors>
56 |
57 | -00000034 <main>:
58 | +00000034 <f>:
59 | +//#define F_CPU 1000000UL // 1 MHz
60 | +#define F_CPU 1843200UL // CPU Frq.: 1.8432MHz
61 |
62 | -//void f( void ){}
63 | +#include <util/delay.h>
64 | +
65 | +void f( void ){}
66 | + 34: 08 95 ret
67 | +
68 | +00000036 <main>:
69 |
70 | int main(void)
71 | {
72 | DDRD |= _BV(PD6); // Make PD6 Output
73 | - 34: 8e 9a sbi 0x11, 6 ; 17
74 | + 36: 8e 9a sbi 0x11, 6 ; 17
75 | //blink, blink:
76 | while (1){
77 | PORTD &= ~_BV(PD6); //PD6 = low -> LED an
78 | - 36: 96 98 cbi 0x12, 6 ; 18
79 | + 38: 96 98 cbi 0x12, 6 ; 18
80 | #else
81 | //round up by default
82 | __ticks_dc = (uint32_t)(ceil(fabs(__tmp)));
83 | #endif
84 |
85 | __builtin_avr_delay_cycles(__ticks_dc);
86 | - 38: 2f ef ldi r18, 0xFF ; 255
87 | - 3a: 8f e9 ldi r24, 0x9F ; 159
88 | - 3c: 95 e0 ldi r25, 0x05 ; 5
89 | - 3e: 21 50 subi r18, 0x01 ; 1
90 | - 40: 80 40 sbci r24, 0x00 ; 0
91 | - 42: 90 40 sbci r25, 0x00 ; 0
92 | - 44: e1 f7 brne .-8 ; 0x3e <__SP_L__+0x1>
93 | - 46: 00 c0 rjmp .+0 ; 0x48 <__SREG__+0x9>
94 | - 48: 00 00 nop
95 | + 3a: 2f ef ldi r18, 0xFF ; 255
96 | + 3c: 8f e9 ldi r24, 0x9F ; 159
97 | + 3e: 95 e0 ldi r25, 0x05 ; 5
98 | + 40: 21 50 subi r18, 0x01 ; 1
99 | + 42: 80 40 sbci r24, 0x00 ; 0
100 | + 44: 90 40 sbci r25, 0x00 ; 0
101 | + 46: e1 f7 brne .-8 ; 0x40 <__SREG__+0x1>
102 | + 48: 00 c0 rjmp .+0 ; 0x4a <__SREG__+0xb>
103 | + 4a: 00 00 nop
104 | _delay_ms(1000); //1000 ms warten
105 | PORTD |= _BV(PD6); //PD6 = high -> LED aus
106 | - 4a: 96 9a sbi 0x12, 6 ; 18
107 | - 4c: 2f ef ldi r18, 0xFF ; 255
108 | - 4e: 8f e9 ldi r24, 0x9F ; 159
109 | - 50: 95 e0 ldi r25, 0x05 ; 5
110 | - 52: 21 50 subi r18, 0x01 ; 1
111 | - 54: 80 40 sbci r24, 0x00 ; 0
112 | - 56: 90 40 sbci r25, 0x00 ; 0
113 | - 58: e1 f7 brne .-8 ; 0x52 <__SREG__+0x13>
114 | - 5a: 00 c0 rjmp .+0 ; 0x5c <__SREG__+0x1d>
115 | - 5c: 00 00 nop
116 | - 5e: eb cf rjmp .-42 ; 0x36 <main+0x2>
117 | + 4c: 96 9a sbi 0x12, 6 ; 18
118 | + 4e: 2f ef ldi r18, 0xFF ; 255
119 | + 50: 8f e9 ldi r24, 0x9F ; 159
120 | + 52: 95 e0 ldi r25, 0x05 ; 5
121 | + 54: 21 50 subi r18, 0x01 ; 1
122 | + 56: 80 40 sbci r24, 0x00 ; 0
123 | + 58: 90 40 sbci r25, 0x00 ; 0
124 | + 5a: e1 f7 brne .-8 ; 0x54 <__SREG__+0x15>
125 | + 5c: 00 c0 rjmp .+0 ; 0x5e <__SREG__+0x1f>
126 | + 5e: 00 00 nop
127 | + 60: eb cf rjmp .-42 ; 0x38 <main+0x2>
128 |
129 | -00000060 <_exit>:
130 | - 60: f8 94 cli
131 | +00000062 <_exit>:
132 | + 62: f8 94 cli
133 |
134 | -00000062 <__stop_program>:
135 | - 62: ff cf rjmp .-2 ; 0x62 <__stop_program>
136 | +00000064 <__stop_program>:
137 | + 64: ff cf rjmp .-2 ; 0x64 <__stop_program>
