1 | #include <SFE_BMP180.h>
2 |
3 | /*
4 |
5 |
6 |
7 |
8 | * analog sensors on analog ins 0, 1,
9 | * SD card attached to SPI bus as follows:
10 | ** MOSI - pin 11
11 | ** MISO - pin 12
12 | ** CLK - pin 13
13 | ** CS - pin 4 (digital assigned via setup)
14 | ** VCC & Ground
15 | -------------------------------------------------------------------
16 | V2-
17 | Adding RTC support
18 | RTC Connected to VCC and Ground
19 | I2C Connections:
20 | RTC SDA connected to pin Analog 4
21 | RTC SCL connected to pin Analog 5
22 |
23 | Used I2CScanner.ino to find I2C addresses- 0x50 (EEPROM?) and 0x68 found
24 | Used SetRTC.ino to manually set proper date/date on RTC module- This wil set the date/time as soon as serial
25 | is initiated so set ahead by a minute and wait till time matches then open serial window to set.
26 | -----------------------------------------------------------------------
27 | V3-
28 | Added Adafruit 992- MPL115A2 Baro/Temp Sensor 5volt 12C device
29 | SDA connected to pin Analog 4
30 | SCL connected to pin Analog 5
31 | Code below should be optimized to avoid multiple I2C calls
32 |
33 | Added Battery Voltage Monitoring:
34 | Changed A0 to be used for Bus Voltage monitoring (on board LiPo)
35 | Will use voltage divider with 2 10Kohm resistores to monitor the 7.4V supply from battery
36 | http://forum.arduino.cc/index.php/topic,13728.0.html
37 | Testing- Ran solid 15 hours no issues, 47000 lines recorded, Filesize 2.1MB
38 | -----------------------------------------------------------------------
39 | V4
40 | Added output for altitude in meters (Thanks Jon)
41 | http://forum.arduino.cc/index.php?topic=63726.0
42 | Used static value of 15 for Temp as using actual temp causes unreliable values indoors
43 |
44 | ------------------------------------------------------------------------
45 | V5
46 | Added code for LM35 Temp sensor (Will be internal monitoring) on A1 data2 and temp variables
47 | Had to do 2 analog reads to debounce the values with a small delay.
48 | Added Bluetooth- shortened serial write text to fit phone screen
49 | W
50 | ----------------------------------------------------------------------
51 | */
52 | #include <SFE_BMP180>// Support for Sensor BMP180
53 | Adafruit_SFE BMP180//Support for BMP 180#include "Wire.h"
54 | #define DS1307_ADDRESS 0x68//RTC Support
55 | //Eric Note- another address showed up in scan at 0X50 EEPROM?
56 | byte zero = 0x00; //workaround for issue #527 RTC Support
57 |
58 | const float referenceVolts = 5.0; // the default reference on a 5 volt board
59 | const int batteryPin = 0; // +V from battery is connected to analog pin 0
60 | const float sea_press = 1013.25;//added for altitude calc
61 | float alt=0;//added for altitude calc
62 |
63 | #include <SD.h>
64 | File myFile; //SD
65 | const int chipSelect=4; // set chipselect pin to 4 for SD
66 | //int dat1=A0;//set data pin
67 | int dat2=1;//define pin0 connect with LM35
68 | float temp=0;
69 | //int data1=0;
70 | int data2=0;
71 | int i=0;
72 | boolean present=0;// SD Card available & usable
73 | void setup()
74 | {
75 |
76 | Wire.begin();
77 | Serial.begin(9600);
78 | mpl115a2.begin();// Baro Sensor Adafruit 992- MPL115A2
79 | //pinMode(dat1,INPUT);
80 | pinMode(dat2,INPUT);
81 | checkSD();
82 | // Write column headers for Excel CSV
83 | myFile = SD.open("datalog.csv", FILE_WRITE);
84 | if(myFile)
85 | {
86 | //Prints headers to file
87 | myFile.print("Time"); // Prints Date and Time header
88 | myFile.print(",");
89 | myFile.print("line#");// prints line number Header for troubleshooting etc
90 | myFile.print(",");
91 | myFile.print("BusVoltage");
92 | myFile.print(",");
93 | myFile.print("IntTemp");
94 | myFile.print(",");
95 | myFile.print("Pressure");
96 | myFile.print(",");
97 | myFile.print("ExtTemp");
98 | myFile.print(",");
99 | myFile.println("Alt(m)");
100 | myFile.close();
101 |
102 | }
103 | }
104 | void loop()
105 | {
106 | int val = analogRead(batteryPin); // read the value from the A0 battery monitoring pin with voltage divider
107 | float volts = (val / 511.0) * referenceVolts ; // divide val by (1023/2)because the resistors divide the voltage in half
108 |
109 | float pressureKPA = 0, temperatureC = 0; //Adafruit 992- MPL115A2
110 | if(present==1)
111 | {
112 | pressureKPA = mpl115a2.getPressure();//get pressure Adafruit 992- MPL115A2
113 | temperatureC = mpl115a2.getTemperature(); //Adafruit 992- MPL115A2
114 | printDate(); //Runs the print date subroutine below
115 | i++;
116 | //data1=analogRead(dat1);
117 | analogRead(1);// added to take initial read to stabilize the ADC
118 | delay(10);// Delay to stabilize the ADC
119 | temp = analogRead(1) * 5000L / 1024L / 10;// Temperature calculation formula
120 | //data2=analogRead(dat2); //used for Ext Temp sensor TBD
121 | //temp= data2 * 4.9 / 10 ; // Temperature calculation formula
122 | Serial.print(" BusV:");
123 | Serial.print(volts);
124 | Serial.print(" ITemp:");
125 | Serial.print(temp);
126 | Serial.print(" Press:");
127 | Serial.print(pressureKPA, 4);
128 | Serial.print(" ExTemp:");
129 | Serial.print(temperatureC, 1);
130 | alt= ((pow((sea_press / (pressureKPA *10)), 1/5.257) - 1.0) * (15 + 273.15)) / 0.0065;//rough altitude equation in meters can use real temp instead of 15
131 | Serial.print(" Alt:");
132 | Serial.println(alt);
133 | writeSD();
134 | }
135 | delay(1000);
136 | }
137 |
138 | byte decToBcd(byte val){ //Eric- needed for RTC variable stuff
139 | // Convert normal decimal numbers to binary coded decimal
140 | return ( (val/10*16) + (val%10) );
141 | }
142 |
143 | byte bcdToDec(byte val) { //Eric- needed for RTC variable stuff
144 | // Convert binary coded decimal to normal decimal numbers
145 | return ( (val/16*10) + (val%16) );
146 | }
147 |
148 | void checkSD()
149 | {
150 | Serial.print("check SD card");
151 | if (!SD.begin(chipSelect)) {
152 | Serial.println("Card failed");
153 | // don't do anything more:
154 | return;
155 | }
156 | Serial.println("SD card OK");
157 | present=1;
158 | delay(2000);
159 | }
160 |
161 | void writeSD()
162 | {
163 | myFile = SD.open("datalog.csv", FILE_WRITE);
164 | if(myFile)
165 | {
166 | int val = analogRead(batteryPin); // read the value from the A0 battery monitoring pin with voltage divider
167 | float volts = (val / 511.0) * referenceVolts ; // divide val by (1023/2)because the resistors divide the voltage in half
168 | // Reset the register pointer
169 | Wire.beginTransmission(DS1307_ADDRESS);
170 | Wire.write(zero);
171 | Wire.endTransmission();
172 |
173 | Wire.requestFrom(DS1307_ADDRESS, 7);
174 |
175 | int second = bcdToDec(Wire.read());
176 | int minute = bcdToDec(Wire.read());
177 | int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
178 | int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
179 | int monthDay = bcdToDec(Wire.read());
180 | int month = bcdToDec(Wire.read());
181 | int year = bcdToDec(Wire.read());
182 | float pressureKPA = mpl115a2.getPressure();//get pressure Adafruit 992- MPL115A2- these are redundant calls to I2c but I dont want to fix
183 | float temperatureC = mpl115a2.getTemperature();//get temp Adafruit 992- MPL115A2- these are redundant calls to I2c but I dont want to fix
184 |
185 | //Print RTC values to SD
186 | myFile.print(month);
187 | myFile.print("/");
188 | myFile.print(monthDay);
189 | myFile.print("/");
190 | myFile.print(year);
191 | myFile.print(" ");
192 | myFile.print(hour);
193 | myFile.print(":");
194 | myFile.print(minute);
195 | myFile.print(":");
196 | myFile.print(second);
197 | //myFile.print(":");
198 | myFile.print(",");
199 | //End Print RTC values
200 | myFile.print(i);
201 | myFile.print(",");
202 | myFile.print(volts);
203 | myFile.print(",");
204 | myFile.print(temp);
205 | myFile.print(",");
206 | myFile.print(pressureKPA, 4);
207 | myFile.print(",");
208 | myFile.print(temperatureC, 1);
209 | myFile.print(",");
210 | myFile.println(alt);
211 | myFile.close();
212 |
213 | }
214 | }
215 |
216 | void printDate()// Only used to print to serial and not needed for logging purposes
217 | {
218 | Wire.beginTransmission(DS1307_ADDRESS);
219 | Wire.write(zero);
220 | Wire.endTransmission();
221 |
222 | Wire.requestFrom(DS1307_ADDRESS, 7);
223 |
224 | int second = bcdToDec(Wire.read());
225 | int minute = bcdToDec(Wire.read());
226 | int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
227 | int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
228 | int monthDay = bcdToDec(Wire.read());
229 | int month = bcdToDec(Wire.read());
230 | int year = bcdToDec(Wire.read());
231 |
232 | //print the date EG 3/1/11 23:59:59
233 | Serial.print(month);
234 | Serial.print("/");
235 | Serial.print(monthDay);
236 | Serial.print("/");
237 | Serial.print(year);
238 | Serial.print(" ");
239 | Serial.print(hour);
240 | Serial.print(":");
241 | Serial.print(minute);
242 | Serial.print(":");
243 | Serial.print(second);
244 |
245 | }
