1 | #define BUFFER_SIZE 1
2 | uint8_t SPIBufferRX=0;
3 | uint8_t SPIBufferTX=0b11111111;
4 |
5 |
6 | /**
7 | * @brief Init SPI2 module for DMA transfers
8 | * @param none
9 | * @retval none
10 | */
11 | void init_SPI_DMA(void){
12 | GPIO_InitTypeDef GPIO_InitStructure;
13 | NVIC_InitTypeDef NVIC_InitStructure;
14 | SPI_InitTypeDef SPI_InitStructure;
15 | DMA_InitTypeDef DMA_InitStructure;
16 |
17 | // Enable clocks
18 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
19 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
20 | RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
21 |
22 | // GPIO settings
23 | GPIO_StructInit(&GPIO_InitStructure);
24 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
25 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
26 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
27 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
28 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
29 | GPIO_Init(GPIOA, &GPIO_InitStructure);
30 |
31 | GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_5);
32 | GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_5);
33 | GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_5);
34 |
35 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
36 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
37 | GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
38 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
39 | GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
40 | GPIO_Init(GPIOA, &GPIO_InitStructure);
41 |
42 | GPIO_SetBits(GPIOA, GPIO_Pin_4); // Set SS pin
43 |
44 | // Init SPI
45 | SPI_StructInit(&SPI_InitStructure);
46 | SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
47 | SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
48 | SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
49 | SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
50 | SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
51 | SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
52 | SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32;
53 | SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;//MSB
54 | SPI_InitStructure.SPI_CRCPolynomial = 0;
55 | SPI_Init(SPI1, &SPI_InitStructure);
56 |
57 | // DMA Channel 4 - SPI RX
58 | DMA_StructInit(&DMA_InitStructure); //SPI2 Tx DMA is DMA1/Stream4/Channel0
59 | DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(SPI1->DR); //Set the SPI2 Tx
60 | DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&SPIBufferRX; //Set the memory location
61 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //Sending data from memory to the peripheral's Tx register
62 | DMA_InitStructure.DMA_BufferSize = BUFFER_SIZE; //Define the number of bytes to send
63 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //Don't increment the peripheral 'memory'
64 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; //Increment the memory location
65 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //Byte size memory transfers
66 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //Byte size memory transfers
67 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //Normal mode (not circular)
68 | DMA_InitStructure.DMA_Priority = DMA_Priority_High; //Priority is high to avoid saturating the FIFO since we are in direct mode
69 | DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
70 | DMA_Init(DMA1_Channel2, &DMA_InitStructure);
71 | DMA_ITConfig(DMA1_Channel2, DMA_IT_TC, ENABLE);
72 |
73 | // DMA Channel 5 - SPI TX //SPI2 Tx DMA is DMA1/Stream4/Channel0
74 | DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&(SPI1->DR); //Set the SPI2 Tx
75 | DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&SPIBufferTX; //Set the memory location
76 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST; //Sending data from memory to the peripheral's Tx register
77 | DMA_InitStructure.DMA_BufferSize = BUFFER_SIZE; //Define the number of bytes to send
78 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //Don't increment the peripheral 'memory'
79 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; //Increment the memory location
80 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //Byte size memory transfers
81 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte; //Byte size memory transfers
82 | DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //Normal mode (not circular)
83 | DMA_InitStructure.DMA_Priority = DMA_Priority_High; //Priority is high to avoid saturating the FIFO since we are in direct mode
84 | DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
85 | DMA_Init(DMA1_Channel3, &DMA_InitStructure);
86 | DMA_ITConfig(DMA1_Channel3, DMA_IT_TC, ENABLE);
87 |
88 | DMA_ClearITPendingBit(DMA1_IT_TC2);
89 | DMA_ClearITPendingBit(DMA1_IT_TC3);
90 |
91 | NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel3_IRQn;
92 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
93 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
94 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
95 | NVIC_Init(&NVIC_InitStructure);
96 |
97 |
98 | NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel2_IRQn;
99 | NVIC_Init(&NVIC_InitStructure);
100 |
101 | SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);
102 | SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE);
103 | SPI_Cmd(SPI1, ENABLE);
104 | }
105 |
106 | /**
107 | * @brief Start new SPI transfer
108 | * @param none
109 | * @retval none
110 | */
111 | void SPI_DMA_start(void){
112 | // Prevent errors
113 | //while((DMA_GetCmdStatus(DMA1_Stream4) == ENABLE) || (DMA_GetCmdStatus(DMA1_Stream3) == ENABLE)){
114 | // DMA transfer still running
115 | //}
116 |
117 | DMA_SetCurrDataCounter(DMA1_Channel2, BUFFER_SIZE); //nur notwendig bei mehr als 1 transfer
118 | DMA_SetCurrDataCounter(DMA1_Channel3, BUFFER_SIZE);
119 |
120 | // Chip Select Low
121 | GPIO_WriteBit(GPIOA, GPIO_Pin_4, RESET);
122 |
123 | DMA_Cmd(DMA1_Channel2, ENABLE);
124 | DMA_Cmd(DMA1_Channel3, ENABLE);
125 |
126 | }
127 |
128 | /**
129 | * @brief DMA RX complete interrupt
130 | * @param none
131 | * @retval none
132 | */
133 | void DMA1_Channel2_IRQHandler(void){
134 |
135 | if(DMA_GetITStatus( DMA1_IT_TC2)) { // Test on DMA Stream Transfer Complete interrupt
136 | DMA_ClearITPendingBit( DMA1_IT_TC2); // Clear DMA Stream Transfer Complete interrupt pending bit
137 | GPIO_WriteBit(GPIOA, GPIO_Pin_4, SET); // Chip Select Low
138 | //USART_puts(USART1, "DMA fertig\n");
139 | DMA_Cmd(DMA1_Channel2, DISABLE);
140 | DMA_Cmd(DMA1_Channel3, DISABLE);
141 | // ToDo
142 | }
143 | }
144 |
145 | /**
146 | * @brief DMA TX Complete interrupt
147 | * @param none
148 | * @retval none
149 | */
150 |
151 | void DMA1_Channel3_IRQHandler(void){
152 |
153 | if(DMA_GetITStatus( DMA1_IT_TC3)) { // Test on DMA Stream Transfer Complete interrupt
154 | //DMA_ClearITPendingBit(DMA1_Stream4, DMA_IT_TCIF4); // Clear DMA Stream Transfer Complete interrupt pending bit
155 | DMA_ClearITPendingBit(DMA1_IT_TC3);
156 |
157 | }
158 | }
