1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.NUMERIC_STD.ALL;
4 |
5 | -- Uncomment the following library declaration if using
6 | -- arithmetic functions with Signed or Unsigned values
7 | --use IEEE.NUMERIC_STD.ALL;
8 |
9 | -- Uncomment the following library declaration if instantiating
10 | -- any Xilinx leaf cells in this code.
11 | --library UNISIM;
12 | --use UNISIM.VComponents.all;
13 |
14 | entity logic is
15 | Port ( clk : in STD_Logic;
16 | dout : out STD_LOGIC;
17 | schalter : in STD_LOGIC);
18 | end logic;
19 |
20 | architecture Behavioral of logic is
21 |
22 | signal blau : STD_LOGIC_VECTOR(23 downto 0) := x"000055";
23 | signal gruen : STD_LOGIC_VECTOR(23 downto 0) := x"550000";
24 | signal kugel : STD_LOGIC_VECTOR(23 downto 0) := x"FFFFFF";
25 | signal rot : STD_LOGIC_VECTOR(23 downto 0) := x"005500";
26 | signal aus : STD_LOGIC_VECTOR(23 downto 0) := x"000000";
27 | variable clk2ctr_int : integer;
28 | signal clk2:STD_LOGIC;
29 | signal clk2ctr : unsigned (13 downto 0) ;
30 | signal clk32: STD_LOGIC;
31 | signal clkctr : unsigned(2 downto 0) := (others => '0');
32 | signal in_data_phase : std_logic := '0';
33 | signal bit_count : unsigned(10 downto 0) := (others => '0');
34 | signal count : unsigned(11 downto 0) := (others => '0');
35 | signal data : std_logic_vector(24*38-1 downto 0) := (others => '0');
36 |
37 | begin
38 | process(clk)
39 | begin
40 | if rising_edge(clk) then -- clk von 32 Mbits bestimmen
41 | if clkctr = 3 then
42 | clk32 <= '1';
43 | clkctr <= (others=> '0');
44 | else
45 | clk32<='0';
46 | clkctr <= clkctr+1;
47 | end if;
48 | else
49 | end if;
50 |
51 |
52 |
53 | end process;
54 |
55 |
56 | process(clk32)
57 | begin
58 | if rising_edge(clk32) then
59 | if in_data_phase = '1' then
60 | if count < 11 then
61 | dout <= '1';
62 | count <= count+1;
63 | elsif count < 29 then
64 | if data(data'high) = '1' then
65 | dout <= '1';
66 | else
67 | dout <= '0';
68 | end if;
69 | count <= count+1;
70 | elsif(count < 39) then
71 | dout <= '0';
72 | count <= count+1;
73 | else
74 | dout <= '0';
75 | count <= (others => '0');
76 | if bit_count = data'high-1 then
77 | in_data_phase <= '0';
78 | else
79 | bit_count <= bit_count + 1;
80 | data <= data(data'high-1 downto 0) & '0';
81 | bit_count <= bit_count+1;
82 | end if;
83 | end if;
84 | else
85 | -- send the reset signal (50us of low)
86 | dout <= '0';
87 | if count=1599 then
88 | -- if clk2ctr = 1000 then
89 | -- data <= rot & rot& rot &rot ;
90 | -- clk2ctr <= (others => '0');
91 | --else
92 | -- clk2ctr <= clk2ctr +1;
93 | -- data <= blau & blau &blau & blau;
94 | --end if;
95 | -- if schalter = '1' then
96 | clk2ctr_int := TO_INTEGER(unsigned(clk2ctr));
97 | case clk2ctr_int is
98 | when 0 to 442 => data <= kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
99 | when 443 to 485 =>data <= gruen & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
100 | when 486 to 886 =>data <= gruen & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
101 | when 887 to 1328 => data <= gruen & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
102 | when 1329 to 1771 =>data <= gruen & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
103 | when 1772 to 2212 =>data <= gruen & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus;
104 | when 2213 to 2654 =>data <= gruen & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
105 | when 2655 to 3096 =>data <= gruen & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
106 | when 3097 to 3538 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
107 | when 3539 to 3980 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
108 | when 3981 to 4422 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
109 | when 4423 to 4864 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
110 | when 4865 to 5306 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
111 | when 5307 to 5748 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
112 | when 5749 to 6190 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
113 | when 6191 to 6632 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
114 | when 6633 to 7074 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
115 | when 7075 to 7516 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
116 | when 7517 to 7958 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
117 | when 7959 to 8400 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
118 | when 8401 to 8842 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
119 | when 8843 to 9284 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
120 | when 9285 to 9726 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
121 | when 9727 to 10168 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
122 | when 10169 to 10610 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
123 | when 10611 to 11052 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
124 | when 11053 to 11494 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
125 | when 11495 to 11936 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
126 | when 11937 to 12378 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
127 | when 12379 to 12820 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & aus ;
128 | when 12821 to 13262 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & aus ;
129 | when 13263 to 13704 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & aus ;
130 | when 13705 to 14146 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & aus ;
131 | when 14147 to 14588 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & aus ;
132 | when 14589 to 15030 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & aus ;
133 | when 15031 to 15472 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & aus ;
134 | when 15473 to 15914 => data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & aus ;
135 | --when 15915 to 16356 => data <= kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & aus ;
136 | --when 34426 to 35310 =>data <= gruen & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
137 | --when 35311 to 36195 =>data <= gruen & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
138 | --when 36196 to 37080 => data <= gruen & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
139 | --when 37081 to 37965 =>data <= gruen & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
140 | --when 37966 to 38850 =>data <= gruen & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
141 | --when 38851 to 39735 =>data <= gruen & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
142 | --when 39736 to 40620 =>data <= gruen & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
143 | --when 40621 to 41505 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
144 | --when 41506 to 42390 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
145 | --when 42391 to 19482 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
146 | --when 19483 to 21253 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
147 | --when 21254 to 23024 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
148 | --when 23025 to 24795 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
149 | --when 24796 to 26566 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
150 | --when 26567 to 28337 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
151 | --when 28338 to 30108 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
152 | --when 30109 to 31879 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
153 | --when 31880 to 33650 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
154 | --when 33651 to 35421 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
155 | --when 35422 to 37192 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
156 | --when 37193 to 38963 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
157 | --when 38964 to 40734 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
158 | --when 40735 to 42505 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
159 | --when 42506 to 44276 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
160 | --when 44277 to 46047 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
161 | --when 46048 to 47818 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
162 | --when 47819 to 49589 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau & rot & blau ;
163 | --when 49590 to 51360 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau & rot & blau ;
164 | --when 51361 to 53131 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau & rot & blau ;
165 | --when 53132 to 54902 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau & rot & blau ;
166 | --when 54903 to 56673 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau & rot & blau ;
167 | --when 56674 to 58444 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau & rot & blau ;
168 | --when 58445 to 60215 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau & rot & blau ;
169 | --when 60216 to 61986 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & rot & blau ;
170 | --when 61987 to 63757 =>data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & kugel & blau ;
171 | --when 63758 to 65528 => data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel ;
172 | when others => data <= gruen & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & blau & rot & kugel & aus ;
173 | end case;
174 | clk2ctr <= clk2ctr +1;
175 | in_data_phase <= '1';
176 | bit_count <= (others => '0');
177 | count <= (others => '0');
178 | --end if;
179 | else
180 | count <= count + 1;
181 | end if;
182 | end if;
183 | end if;
184 |
185 | end process;
186 |
187 |
188 |
189 |
190 |
191 | end Behavioral;
