1 | ;***** THIS IS A MACHINE GENERATED FILE - DO NOT EDIT ********************
2 | ;***** Created: 2011-08-25 21:00 ******* Source: ATmega8.xml *************
3 | ;*************************************************************************
4 | ;* A P P L I C A T I O N N O T E F O R T H E A V R F A M I L Y
5 | ;*
6 | ;* Number : AVR000
7 | ;* File Name : "m8def.inc"
8 | ;* Title : Register/Bit Definitions for the ATmega8
9 | ;* Date : 2011-08-25
10 | ;* Version : 2.35
11 | ;* Support E-mail : avr@atmel.com
12 | ;* Target MCU : ATmega8
13 | ;*
14 | ;* DESCRIPTION
15 | ;* When including this file in the assembly program file, all I/O register
16 | ;* names and I/O register bit names appearing in the data book can be used.
17 | ;* In addition, the six registers forming the three data pointers X, Y and
18 | ;* Z have been assigned names XL - ZH. Highest RAM address for Internal
19 | ;* SRAM is also defined
20 | ;*
21 | ;* The Register names are represented by their hexadecimal address.
22 | ;*
23 | ;* The Register Bit names are represented by their bit number (0-7).
24 | ;*
25 | ;* Please observe the difference in using the bit names with instructions
26 | ;* such as "sbr"/"cbr" (set/clear bit in register) and "sbrs"/"sbrc"
27 | ;* (skip if bit in register set/cleared). The following example illustrates
28 | ;* this:
29 | ;*
30 | ;* in r16,PORTB ;read PORTB latch
31 | ;* sbr r16,(1<<PB6)+(1<<PB5) ;set PB6 and PB5 (use masks, not bit#)
32 | ;* out PORTB,r16 ;output to PORTB
33 | ;*
34 | ;* in r16,TIFR ;read the Timer Interrupt Flag Register
35 | ;* sbrc r16,TOV0 ;test the overflow flag (use bit#)
36 | ;* rjmp TOV0_is_set ;jump if set
37 | ;* ... ;otherwise do something else
38 | ;*************************************************************************
39 |
40 | #ifndef _M8DEF_INC_
41 | #define _M8DEF_INC_
42 |
43 |
44 | #pragma partinc 0
45 |
46 | ; ***** SPECIFY DEVICE ***************************************************
47 | .device ATmega8
48 | #pragma AVRPART ADMIN PART_NAME ATmega8
49 | .equ SIGNATURE_000 = 0x1e
50 | .equ SIGNATURE_001 = 0x93
51 | .equ SIGNATURE_002 = 0x07
52 |
53 | #pragma AVRPART CORE CORE_VERSION V2E
54 |
55 |
56 | ; ***** I/O REGISTER DEFINITIONS *****************************************
57 | ; NOTE:
58 | ; Definitions marked "MEMORY MAPPED"are extended I/O ports
59 | ; and cannot be used with IN/OUT instructions
60 | .equ SREG = 0x3f
61 | .equ SPL = 0x3d
62 | .equ SPH = 0x3e
63 | .equ GICR = 0x3b
64 | .equ GIFR = 0x3a
65 | .equ TIMSK = 0x39
66 | .equ TIFR = 0x38
67 | .equ SPMCR = 0x37
68 | .equ TWCR = 0x36
69 | .equ MCUCR = 0x35
70 | .equ MCUCSR = 0x34
71 | .equ TCCR0 = 0x33
72 | .equ TCNT0 = 0x32
73 | .equ OSCCAL = 0x31
74 | .equ SFIOR = 0x30
75 | .equ TCCR1A = 0x2f
76 | .equ TCCR1B = 0x2e
77 | .equ TCNT1L = 0x2c
78 | .equ TCNT1H = 0x2d
79 | .equ OCR1AL = 0x2a
80 | .equ OCR1AH = 0x2b
81 | .equ OCR1BL = 0x28
82 | .equ OCR1BH = 0x29
83 | .equ ICR1L = 0x26
84 | .equ ICR1H = 0x27
85 | .equ TCCR2 = 0x25
86 | .equ TCNT2 = 0x24
87 | .equ OCR2 = 0x23
88 | .equ ASSR = 0x22
89 | .equ WDTCR = 0x21
90 | .equ UBRRH = 0x20
91 | .equ UCSRC = 0x20
92 | .equ EEARL = 0x1e
93 | .equ EEARH = 0x1f
94 | .equ EEDR = 0x1d
95 | .equ EECR = 0x1c
96 | .equ PORTB = 0x18
97 | .equ DDRB = 0x17
98 | .equ PINB = 0x16
99 | .equ PORTC = 0x15
100 | .equ DDRC = 0x14
101 | .equ PINC = 0x13
102 | .equ PORTD = 0x12
103 | .equ DDRD = 0x11
104 | .equ PIND = 0x10
105 | .equ SPDR = 0x0f
106 | .equ SPSR = 0x0e
107 | .equ SPCR = 0x0d
108 | .equ UDR = 0x0c
109 | .equ UCSRA = 0x0b
110 | .equ UCSRB = 0x0a
111 | .equ UBRRL = 0x09
112 | .equ ACSR = 0x08
113 | .equ ADMUX = 0x07
114 | .equ ADCSRA = 0x06
115 | .equ ADCL = 0x04
116 | .equ ADCH = 0x05
117 | .equ TWDR = 0x03
118 | .equ TWAR = 0x02
119 | .equ TWSR = 0x01
120 | .equ TWBR = 0x00
121 |
122 |
123 | ; ***** BIT DEFINITIONS **************************************************
124 |
125 | ; ***** ANALOG_COMPARATOR ************
126 | ; SFIOR - Special Function IO Register
127 | .equ ACME = 3 ; Analog Comparator Multiplexer Enable
128 |
129 | ; ACSR - Analog Comparator Control And Status Register
130 | .equ ACIS0 = 0 ; Analog Comparator Interrupt Mode Select bit 0
131 | .equ ACIS1 = 1 ; Analog Comparator Interrupt Mode Select bit 1
132 | .equ ACIC = 2 ; Analog Comparator Input Capture Enable
133 | .equ ACIE = 3 ; Analog Comparator Interrupt Enable
134 | .equ ACI = 4 ; Analog Comparator Interrupt Flag
135 | .equ ACO = 5 ; Analog Compare Output
136 | .equ ACBG = 6 ; Analog Comparator Bandgap Select
137 | .equ ACD = 7 ; Analog Comparator Disable
138 |
139 |
140 | ; ***** SPI **************************
141 | ; SPDR - SPI Data Register
142 | .equ SPDR0 = 0 ; SPI Data Register bit 0
143 | .equ SPDR1 = 1 ; SPI Data Register bit 1
144 | .equ SPDR2 = 2 ; SPI Data Register bit 2
145 | .equ SPDR3 = 3 ; SPI Data Register bit 3
146 | .equ SPDR4 = 4 ; SPI Data Register bit 4
147 | .equ SPDR5 = 5 ; SPI Data Register bit 5
148 | .equ SPDR6 = 6 ; SPI Data Register bit 6
149 | .equ SPDR7 = 7 ; SPI Data Register bit 7
150 |
151 | ; SPSR - SPI Status Register
152 | .equ SPI2X = 0 ; Double SPI Speed Bit
153 | .equ WCOL = 6 ; Write Collision Flag
154 | .equ SPIF = 7 ; SPI Interrupt Flag
155 |
156 | ; SPCR - SPI Control Register
157 | .equ SPR0 = 0 ; SPI Clock Rate Select 0
158 | .equ SPR1 = 1 ; SPI Clock Rate Select 1
159 | .equ CPHA = 2 ; Clock Phase
160 | .equ CPOL = 3 ; Clock polarity
161 | .equ MSTR = 4 ; Master/Slave Select
162 | .equ DORD = 5 ; Data Order
163 | .equ SPE = 6 ; SPI Enable
164 | .equ SPIE = 7 ; SPI Interrupt Enable
165 |
166 |
167 | ; ***** EXTERNAL_INTERRUPT ***********
168 | ; GICR - General Interrupt Control Register
169 | .equ GIMSK = GICR ; For compatibility
170 | .equ IVCE = 0 ; Interrupt Vector Change Enable
171 | .equ IVSEL = 1 ; Interrupt Vector Select
172 | .equ INT0 = 6 ; External Interrupt Request 0 Enable
173 | .equ INT1 = 7 ; External Interrupt Request 1 Enable
174 |
175 | ; GIFR - General Interrupt Flag Register
176 | .equ INTF0 = 6 ; External Interrupt Flag 0
177 | .equ INTF1 = 7 ; External Interrupt Flag 1
178 |
179 | ; MCUCR - MCU Control Register
180 | .equ ISC00 = 0 ; Interrupt Sense Control 0 Bit 0
181 | .equ ISC01 = 1 ; Interrupt Sense Control 0 Bit 1
182 | .equ ISC10 = 2 ; Interrupt Sense Control 1 Bit 0
183 | .equ ISC11 = 3 ; Interrupt Sense Control 1 Bit 1
184 |
185 |
186 | ; ***** TIMER_COUNTER_0 **************
187 | ; TIMSK - Timer/Counter Interrupt Mask Register
188 | .equ TOIE0 = 0 ; Timer/Counter0 Overflow Interrupt Enable
189 |
190 | ; TIFR - Timer/Counter Interrupt Flag register
191 | .equ TOV0 = 0 ; Timer/Counter0 Overflow Flag
192 |
193 | ; TCCR0 - Timer/Counter0 Control Register
194 | .equ CS00 = 0 ; Clock Select0 bit 0
195 | .equ CS01 = 1 ; Clock Select0 bit 1
196 | .equ CS02 = 2 ; Clock Select0 bit 2
197 |
198 | ; TCNT0 - Timer Counter 0
199 | .equ TCNT00 = 0 ; Timer Counter 0 bit 0
200 | .equ TCNT01 = 1 ; Timer Counter 0 bit 1
201 | .equ TCNT02 = 2 ; Timer Counter 0 bit 2
202 | .equ TCNT03 = 3 ; Timer Counter 0 bit 3
203 | .equ TCNT04 = 4 ; Timer Counter 0 bit 4
204 | .equ TCNT05 = 5 ; Timer Counter 0 bit 5
205 | .equ TCNT06 = 6 ; Timer Counter 0 bit 6
206 | .equ TCNT07 = 7 ; Timer Counter 0 bit 7
207 |
208 |
209 | ; ***** TIMER_COUNTER_1 **************
210 | ; TIMSK - Timer/Counter Interrupt Mask Register
211 | .equ TOIE1 = 2 ; Timer/Counter1 Overflow Interrupt Enable
212 | .equ OCIE1B = 3 ; Timer/Counter1 Output CompareB Match Interrupt Enable
213 | .equ OCIE1A = 4 ; Timer/Counter1 Output CompareA Match Interrupt Enable
214 | .equ TICIE1 = 5 ; Timer/Counter1 Input Capture Interrupt Enable
215 |
216 | ; TIFR - Timer/Counter Interrupt Flag register
217 | .equ TOV1 = 2 ; Timer/Counter1 Overflow Flag
218 | .equ OCF1B = 3 ; Output Compare Flag 1B
219 | .equ OCF1A = 4 ; Output Compare Flag 1A
220 | .equ ICF1 = 5 ; Input Capture Flag 1
221 |
222 | ; TCCR1A - Timer/Counter1 Control Register A
223 | .equ WGM10 = 0 ; Waveform Generation Mode
224 | .equ PWM10 = WGM10 ; For compatibility
225 | .equ WGM11 = 1 ; Waveform Generation Mode
226 | .equ PWM11 = WGM11 ; For compatibility
227 | .equ FOC1B = 2 ; Force Output Compare 1B
228 | .equ FOC1A = 3 ; Force Output Compare 1A
229 | .equ COM1B0 = 4 ; Compare Output Mode 1B, bit 0
230 | .equ COM1B1 = 5 ; Compare Output Mode 1B, bit 1
231 | .equ COM1A0 = 6 ; Compare Ouput Mode 1A, bit 0
232 | .equ COM1A1 = 7 ; Compare Output Mode 1A, bit 1
233 |
234 | ; TCCR1B - Timer/Counter1 Control Register B
235 | .equ CS10 = 0 ; Prescaler source of Timer/Counter 1
236 | .equ CS11 = 1 ; Prescaler source of Timer/Counter 1
237 | .equ CS12 = 2 ; Prescaler source of Timer/Counter 1
238 | .equ WGM12 = 3 ; Waveform Generation Mode
239 | .equ CTC10 = WGM12 ; For compatibility
240 | .equ CTC1 = WGM12 ; For compatibility
241 | .equ WGM13 = 4 ; Waveform Generation Mode
242 | .equ CTC11 = WGM13 ; For compatibility
243 | .equ ICES1 = 6 ; Input Capture 1 Edge Select
244 | .equ ICNC1 = 7 ; Input Capture 1 Noise Canceler
245 |
246 |
247 | ; ***** TIMER_COUNTER_2 **************
248 | ; TIMSK - Timer/Counter Interrupt Mask register
249 | .equ TOIE2 = 6 ; Timer/Counter2 Overflow Interrupt Enable
250 | .equ OCIE2 = 7 ; Timer/Counter2 Output Compare Match Interrupt Enable
251 |
252 | ; TIFR - Timer/Counter Interrupt Flag Register
253 | .equ TOV2 = 6 ; Timer/Counter2 Overflow Flag
254 | .equ OCF2 = 7 ; Output Compare Flag 2
255 |
256 | ; TCCR2 - Timer/Counter2 Control Register
257 | .equ CS20 = 0 ; Clock Select bit 0
258 | .equ CS21 = 1 ; Clock Select bit 1
259 | .equ CS22 = 2 ; Clock Select bit 2
260 | .equ WGM21 = 3 ; Waveform Generation Mode
261 | .equ CTC2 = WGM21 ; For compatibility
262 | .equ COM20 = 4 ; Compare Output Mode bit 0
263 | .equ COM21 = 5 ; Compare Output Mode bit 1
264 | .equ WGM20 = 6 ; Waveform Genration Mode
265 | .equ PWM2 = WGM20 ; For compatibility
266 | .equ FOC2 = 7 ; Force Output Compare
267 |
268 | ; TCNT2 - Timer/Counter2
269 | .equ TCNT2_0 = 0 ; Timer/Counter 2 bit 0
270 | .equ TCNT2_1 = 1 ; Timer/Counter 2 bit 1
271 | .equ TCNT2_2 = 2 ; Timer/Counter 2 bit 2
272 | .equ TCNT2_3 = 3 ; Timer/Counter 2 bit 3
273 | .equ TCNT2_4 = 4 ; Timer/Counter 2 bit 4
274 | .equ TCNT2_5 = 5 ; Timer/Counter 2 bit 5
275 | .equ TCNT2_6 = 6 ; Timer/Counter 2 bit 6
276 | .equ TCNT2_7 = 7 ; Timer/Counter 2 bit 7
277 |
278 | ; OCR2 - Timer/Counter2 Output Compare Register
279 | .equ OCR2_0 = 0 ; Timer/Counter2 Output Compare Register Bit 0
280 | .equ OCR2_1 = 1 ; Timer/Counter2 Output Compare Register Bit 1
281 | .equ OCR2_2 = 2 ; Timer/Counter2 Output Compare Register Bit 2
282 | .equ OCR2_3 = 3 ; Timer/Counter2 Output Compare Register Bit 3
283 | .equ OCR2_4 = 4 ; Timer/Counter2 Output Compare Register Bit 4
284 | .equ OCR2_5 = 5 ; Timer/Counter2 Output Compare Register Bit 5
285 | .equ OCR2_6 = 6 ; Timer/Counter2 Output Compare Register Bit 6
286 | .equ OCR2_7 = 7 ; Timer/Counter2 Output Compare Register Bit 7
287 |
288 | ; ASSR - Asynchronous Status Register
289 | .equ TCR2UB = 0 ; Timer/counter Control Register2 Update Busy
290 | .equ OCR2UB = 1 ; Output Compare Register2 Update Busy
291 | .equ TCN2UB = 2 ; Timer/Counter2 Update Busy
292 | .equ AS2 = 3 ; Asynchronous Timer/counter2
293 |
294 | ; SFIOR - Special Function IO Register
295 | .equ PSR2 = 1 ; Prescaler Reset Timer/Counter2
296 |
297 |
298 | ; ***** USART ************************
299 | ; UDR - USART I/O Data Register
300 | .equ UDR0 = 0 ; USART I/O Data Register bit 0
301 | .equ UDR1 = 1 ; USART I/O Data Register bit 1
302 | .equ UDR2 = 2 ; USART I/O Data Register bit 2
303 | .equ UDR3 = 3 ; USART I/O Data Register bit 3
304 | .equ UDR4 = 4 ; USART I/O Data Register bit 4
305 | .equ UDR5 = 5 ; USART I/O Data Register bit 5
306 | .equ UDR6 = 6 ; USART I/O Data Register bit 6
307 | .equ UDR7 = 7 ; USART I/O Data Register bit 7
308 |
309 | ; UCSRA - USART Control and Status Register A
310 | .equ USR = UCSRA ; For compatibility
311 | .equ MPCM = 0 ; Multi-processor Communication Mode
312 | .equ U2X = 1 ; Double the USART transmission speed
313 | .equ UPE = 2 ; Parity Error
314 | .equ PE = UPE ; For compatibility
315 | .equ DOR = 3 ; Data overRun
316 | .equ FE = 4 ; Framing Error
317 | .equ UDRE = 5 ; USART Data Register Empty
318 | .equ TXC = 6 ; USART Transmitt Complete
319 | .equ RXC = 7 ; USART Receive Complete
320 |
321 | ; UCSRB - USART Control and Status Register B
322 | .equ UCR = UCSRB ; For compatibility
323 | .equ TXB8 = 0 ; Transmit Data Bit 8
324 | .equ RXB8 = 1 ; Receive Data Bit 8
325 | .equ UCSZ2 = 2 ; Character Size
326 | .equ CHR9 = UCSZ2 ; For compatibility
327 | .equ TXEN = 3 ; Transmitter Enable
328 | .equ RXEN = 4 ; Receiver Enable
329 | .equ UDRIE = 5 ; USART Data register Empty Interrupt Enable
330 | .equ TXCIE = 6 ; TX Complete Interrupt Enable
331 | .equ RXCIE = 7 ; RX Complete Interrupt Enable
332 |
333 | ; UCSRC - USART Control and Status Register C
334 | .equ UCPOL = 0 ; Clock Polarity
335 | .equ UCSZ0 = 1 ; Character Size
336 | .equ UCSZ1 = 2 ; Character Size
337 | .equ USBS = 3 ; Stop Bit Select
338 | .equ UPM0 = 4 ; Parity Mode Bit 0
339 | .equ UPM1 = 5 ; Parity Mode Bit 1
340 | .equ UMSEL = 6 ; USART Mode Select
341 | .equ URSEL = 7 ; Register Select
342 |
343 | .equ UBRRHI = UBRRH ; For compatibility
344 |
345 | ; ***** TWI **************************
346 | ; TWBR - TWI Bit Rate register
347 | .equ I2BR = TWBR ; For compatibility
348 | .equ TWBR0 = 0 ;
349 | .equ TWBR1 = 1 ;
350 | .equ TWBR2 = 2 ;
351 | .equ TWBR3 = 3 ;
352 | .equ TWBR4 = 4 ;
353 | .equ TWBR5 = 5 ;
354 | .equ TWBR6 = 6 ;
355 | .equ TWBR7 = 7 ;
356 |
357 | ; TWCR - TWI Control Register
358 | .equ I2CR = TWCR ; For compatibility
359 | .equ TWIE = 0 ; TWI Interrupt Enable
360 | .equ I2IE = TWIE ; For compatibility
361 | .equ TWEN = 2 ; TWI Enable Bit
362 | .equ I2EN = TWEN ; For compatibility
363 | .equ ENI2C = TWEN ; For compatibility
364 | .equ TWWC = 3 ; TWI Write Collition Flag
365 | .equ I2WC = TWWC ; For compatibility
366 | .equ TWSTO = 4 ; TWI Stop Condition Bit
367 | .equ I2STO = TWSTO ; For compatibility
368 | .equ TWSTA = 5 ; TWI Start Condition Bit
369 | .equ I2STA = TWSTA ; For compatibility
370 | .equ TWEA = 6 ; TWI Enable Acknowledge Bit
371 | .equ I2EA = TWEA ; For compatibility
372 | .equ TWINT = 7 ; TWI Interrupt Flag
373 | .equ I2INT = TWINT ; For compatibility
374 |
375 | ; TWSR - TWI Status Register
376 | .equ I2SR = TWSR ; For compatibility
377 | .equ TWPS0 = 0 ; TWI Prescaler
378 | .equ TWS0 = TWPS0 ; For compatibility
379 | .equ I2GCE = TWPS0 ; For compatibility
380 | .equ TWPS1 = 1 ; TWI Prescaler
381 | .equ TWS1 = TWPS1 ; For compatibility
382 | .equ TWS3 = 3 ; TWI Status
383 | .equ I2S3 = TWS3 ; For compatibility
384 | .equ TWS4 = 4 ; TWI Status
385 | .equ I2S4 = TWS4 ; For compatibility
386 | .equ TWS5 = 5 ; TWI Status
387 | .equ I2S5 = TWS5 ; For compatibility
388 | .equ TWS6 = 6 ; TWI Status
389 | .equ I2S6 = TWS6 ; For compatibility
390 | .equ TWS7 = 7 ; TWI Status
391 | .equ I2S7 = TWS7 ; For compatibility
392 |
393 | ; TWDR - TWI Data register
394 | .equ I2DR = TWDR ; For compatibility
395 | .equ TWD0 = 0 ; TWI Data Register Bit 0
396 | .equ TWD1 = 1 ; TWI Data Register Bit 1
397 | .equ TWD2 = 2 ; TWI Data Register Bit 2
398 | .equ TWD3 = 3 ; TWI Data Register Bit 3
399 | .equ TWD4 = 4 ; TWI Data Register Bit 4
400 | .equ TWD5 = 5 ; TWI Data Register Bit 5
401 | .equ TWD6 = 6 ; TWI Data Register Bit 6
402 | .equ TWD7 = 7 ; TWI Data Register Bit 7
403 |
404 | ; TWAR - TWI (Slave) Address register
405 | .equ I2AR = TWAR ; For compatibility
406 | .equ TWGCE = 0 ; TWI General Call Recognition Enable Bit
407 | .equ TWA0 = 1 ; TWI (Slave) Address register Bit 0
408 | .equ TWA1 = 2 ; TWI (Slave) Address register Bit 1
409 | .equ TWA2 = 3 ; TWI (Slave) Address register Bit 2
410 | .equ TWA3 = 4 ; TWI (Slave) Address register Bit 3
411 | .equ TWA4 = 5 ; TWI (Slave) Address register Bit 4
412 | .equ TWA5 = 6 ; TWI (Slave) Address register Bit 5
413 | .equ TWA6 = 7 ; TWI (Slave) Address register Bit 6
414 |
415 |
416 | ; ***** WATCHDOG *********************
417 | ; WDTCR - Watchdog Timer Control Register
418 | .equ WDTCSR = WDTCR ; For compatibility
419 | .equ WDP0 = 0 ; Watch Dog Timer Prescaler bit 0
420 | .equ WDP1 = 1 ; Watch Dog Timer Prescaler bit 1
421 | .equ WDP2 = 2 ; Watch Dog Timer Prescaler bit 2
422 | .equ WDE = 3 ; Watch Dog Enable
423 | .equ WDCE = 4 ; Watchdog Change Enable
424 | .equ WDTOE = WDCE ; For compatibility
425 |
426 |
427 | ; ***** PORTB ************************
428 | ; PORTB - Port B Data Register
429 | .equ PORTB0 = 0 ; Port B Data Register bit 0
430 | .equ PB0 = 0 ; For compatibility
431 | .equ PORTB1 = 1 ; Port B Data Register bit 1
432 | .equ PB1 = 1 ; For compatibility
433 | .equ PORTB2 = 2 ; Port B Data Register bit 2
434 | .equ PB2 = 2 ; For compatibility
435 | .equ PORTB3 = 3 ; Port B Data Register bit 3
436 | .equ PB3 = 3 ; For compatibility
437 | .equ PORTB4 = 4 ; Port B Data Register bit 4
438 | .equ PB4 = 4 ; For compatibility
439 | .equ PORTB5 = 5 ; Port B Data Register bit 5
440 | .equ PB5 = 5 ; For compatibility
441 | .equ PORTB6 = 6 ; Port B Data Register bit 6
442 | .equ PB6 = 6 ; For compatibility
443 | .equ PORTB7 = 7 ; Port B Data Register bit 7
444 | .equ PB7 = 7 ; For compatibility
445 |
446 | ; DDRB - Port B Data Direction Register
447 | .equ DDB0 = 0 ; Port B Data Direction Register bit 0
448 | .equ DDB1 = 1 ; Port B Data Direction Register bit 1
449 | .equ DDB2 = 2 ; Port B Data Direction Register bit 2
450 | .equ DDB3 = 3 ; Port B Data Direction Register bit 3
451 | .equ DDB4 = 4 ; Port B Data Direction Register bit 4
452 | .equ DDB5 = 5 ; Port B Data Direction Register bit 5
453 | .equ DDB6 = 6 ; Port B Data Direction Register bit 6
454 | .equ DDB7 = 7 ; Port B Data Direction Register bit 7
455 |
456 | ; PINB - Port B Input Pins
457 | .equ PINB0 = 0 ; Port B Input Pins bit 0
458 | .equ PINB1 = 1 ; Port B Input Pins bit 1
459 | .equ PINB2 = 2 ; Port B Input Pins bit 2
460 | .equ PINB3 = 3 ; Port B Input Pins bit 3
461 | .equ PINB4 = 4 ; Port B Input Pins bit 4
462 | .equ PINB5 = 5 ; Port B Input Pins bit 5
463 | .equ PINB6 = 6 ; Port B Input Pins bit 6
464 | .equ PINB7 = 7 ; Port B Input Pins bit 7
465 |
466 |
467 | ; ***** PORTC ************************
468 | ; PORTC - Port C Data Register
469 | .equ PORTC0 = 0 ; Port C Data Register bit 0
470 | .equ PC0 = 0 ; For compatibility
471 | .equ PORTC1 = 1 ; Port C Data Register bit 1
472 | .equ PC1 = 1 ; For compatibility
473 | .equ PORTC2 = 2 ; Port C Data Register bit 2
474 | .equ PC2 = 2 ; For compatibility
475 | .equ PORTC3 = 3 ; Port C Data Register bit 3
476 | .equ PC3 = 3 ; For compatibility
477 | .equ PORTC4 = 4 ; Port C Data Register bit 4
478 | .equ PC4 = 4 ; For compatibility
479 | .equ PORTC5 = 5 ; Port C Data Register bit 5
480 | .equ PC5 = 5 ; For compatibility
481 | .equ PORTC6 = 6 ; Port C Data Register bit 6
482 | .equ PC6 = 6 ; For compatibility
483 |
484 | ; DDRC - Port C Data Direction Register
485 | .equ DDC0 = 0 ; Port C Data Direction Register bit 0
486 | .equ DDC1 = 1 ; Port C Data Direction Register bit 1
487 | .equ DDC2 = 2 ; Port C Data Direction Register bit 2
488 | .equ DDC3 = 3 ; Port C Data Direction Register bit 3
489 | .equ DDC4 = 4 ; Port C Data Direction Register bit 4
490 | .equ DDC5 = 5 ; Port C Data Direction Register bit 5
491 | .equ DDC6 = 6 ; Port C Data Direction Register bit 6
492 |
493 | ; PINC - Port C Input Pins
494 | .equ PINC0 = 0 ; Port C Input Pins bit 0
495 | .equ PINC1 = 1 ; Port C Input Pins bit 1
496 | .equ PINC2 = 2 ; Port C Input Pins bit 2
497 | .equ PINC3 = 3 ; Port C Input Pins bit 3
498 | .equ PINC4 = 4 ; Port C Input Pins bit 4
499 | .equ PINC5 = 5 ; Port C Input Pins bit 5
500 | .equ PINC6 = 6 ; Port C Input Pins bit 6
501 |
502 |
503 | ; ***** PORTD ************************
504 | ; PORTD - Port D Data Register
505 | .equ PORTD0 = 0 ; Port D Data Register bit 0
506 | .equ PD0 = 0 ; For compatibility
507 | .equ PORTD1 = 1 ; Port D Data Register bit 1
508 | .equ PD1 = 1 ; For compatibility
509 | .equ PORTD2 = 2 ; Port D Data Register bit 2
510 | .equ PD2 = 2 ; For compatibility
511 | .equ PORTD3 = 3 ; Port D Data Register bit 3
512 | .equ PD3 = 3 ; For compatibility
513 | .equ PORTD4 = 4 ; Port D Data Register bit 4
514 | .equ PD4 = 4 ; For compatibility
515 | .equ PORTD5 = 5 ; Port D Data Register bit 5
516 | .equ PD5 = 5 ; For compatibility
517 | .equ PORTD6 = 6 ; Port D Data Register bit 6
518 | .equ PD6 = 6 ; For compatibility
519 | .equ PORTD7 = 7 ; Port D Data Register bit 7
520 | .equ PD7 = 7 ; For compatibility
521 |
522 | ; DDRD - Port D Data Direction Register
523 | .equ DDD0 = 0 ; Port D Data Direction Register bit 0
524 | .equ DDD1 = 1 ; Port D Data Direction Register bit 1
525 | .equ DDD2 = 2 ; Port D Data Direction Register bit 2
526 | .equ DDD3 = 3 ; Port D Data Direction Register bit 3
527 | .equ DDD4 = 4 ; Port D Data Direction Register bit 4
528 | .equ DDD5 = 5 ; Port D Data Direction Register bit 5
529 | .equ DDD6 = 6 ; Port D Data Direction Register bit 6
530 | .equ DDD7 = 7 ; Port D Data Direction Register bit 7
531 |
532 | ; PIND - Port D Input Pins
533 | .equ PIND0 = 0 ; Port D Input Pins bit 0
534 | .equ PIND1 = 1 ; Port D Input Pins bit 1
535 | .equ PIND2 = 2 ; Port D Input Pins bit 2
536 | .equ PIND3 = 3 ; Port D Input Pins bit 3
537 | .equ PIND4 = 4 ; Port D Input Pins bit 4
538 | .equ PIND5 = 5 ; Port D Input Pins bit 5
539 | .equ PIND6 = 6 ; Port D Input Pins bit 6
540 | .equ PIND7 = 7 ; Port D Input Pins bit 7
541 |
542 |
543 | ; ***** EEPROM ***********************
544 | ; EEDR - EEPROM Data Register
545 | .equ EEDR0 = 0 ; EEPROM Data Register bit 0
546 | .equ EEDR1 = 1 ; EEPROM Data Register bit 1
547 | .equ EEDR2 = 2 ; EEPROM Data Register bit 2
548 | .equ EEDR3 = 3 ; EEPROM Data Register bit 3
549 | .equ EEDR4 = 4 ; EEPROM Data Register bit 4
550 | .equ EEDR5 = 5 ; EEPROM Data Register bit 5
551 | .equ EEDR6 = 6 ; EEPROM Data Register bit 6
552 | .equ EEDR7 = 7 ; EEPROM Data Register bit 7
553 |
554 | ; EECR - EEPROM Control Register
555 | .equ EERE = 0 ; EEPROM Read Enable
556 | .equ EEWE = 1 ; EEPROM Write Enable
557 | .equ EEMWE = 2 ; EEPROM Master Write Enable
558 | .equ EEWEE = EEMWE ; For compatibility
559 | .equ EERIE = 3 ; EEPROM Ready Interrupt Enable
560 |
561 |
562 | ; ***** CPU **************************
563 | ; SREG - Status Register
564 | .equ SREG_C = 0 ; Carry Flag
565 | .equ SREG_Z = 1 ; Zero Flag
566 | .equ SREG_N = 2 ; Negative Flag
567 | .equ SREG_V = 3 ; Two's Complement Overflow Flag
568 | .equ SREG_S = 4 ; Sign Bit
569 | .equ SREG_H = 5 ; Half Carry Flag
570 | .equ SREG_T = 6 ; Bit Copy Storage
571 | .equ SREG_I = 7 ; Global Interrupt Enable
572 |
573 | ; MCUCR - MCU Control Register
574 | ;.equ ISC00 = 0 ; Interrupt Sense Control 0 Bit 0
575 | ;.equ ISC01 = 1 ; Interrupt Sense Control 0 Bit 1
576 | ;.equ ISC10 = 2 ; Interrupt Sense Control 1 Bit 0
577 | ;.equ ISC11 = 3 ; Interrupt Sense Control 1 Bit 1
578 | .equ SM0 = 4 ; Sleep Mode Select
579 | .equ SM1 = 5 ; Sleep Mode Select
580 | .equ SM2 = 6 ; Sleep Mode Select
581 | .equ SE = 7 ; Sleep Enable
582 |
583 | ; MCUCSR - MCU Control And Status Register
584 | .equ MCUSR = MCUCSR ; For compatibility
585 | .equ PORF = 0 ; Power-on reset flag
586 | .equ EXTRF = 1 ; External Reset Flag
587 | .equ BORF = 2 ; Brown-out Reset Flag
588 | .equ WDRF = 3 ; Watchdog Reset Flag
589 |
590 | ; OSCCAL - Oscillator Calibration Value
591 | .equ CAL0 = 0 ; Oscillator Calibration Value Bit0
592 | .equ CAL1 = 1 ; Oscillator Calibration Value Bit1
593 | .equ CAL2 = 2 ; Oscillator Calibration Value Bit2
594 | .equ CAL3 = 3 ; Oscillator Calibration Value Bit3
595 | .equ CAL4 = 4 ; Oscillator Calibration Value Bit4
596 | .equ CAL5 = 5 ; Oscillator Calibration Value Bit5
597 | .equ CAL6 = 6 ; Oscillator Calibration Value Bit6
598 | .equ CAL7 = 7 ; Oscillator Calibration Value Bit7
599 |
600 | ; SPMCR - Store Program Memory Control Register
601 | .equ SPMEN = 0 ; Store Program Memory Enable
602 | .equ PGERS = 1 ; Page Erase
603 | .equ PGWRT = 2 ; Page Write
604 | .equ BLBSET = 3 ; Boot Lock Bit Set
605 | .equ RWWSRE = 4 ; Read-While-Write Section Read Enable
606 | .equ RWWSB = 6 ; Read-While-Write Section Busy
607 | .equ SPMIE = 7 ; SPM Interrupt Enable
608 |
609 | ; SFIOR - Special Function IO Register
610 | .equ PSR10 = 0 ; Prescaler Reset Timer/Counter1 and Timer/Counter0
611 | .equ PUD = 2 ; Pull-up Disable
612 | .equ ADHSM = 4 ; ADC High Speed Mode
613 |
614 |
615 | ; ***** AD_CONVERTER *****************
616 | ; ADMUX - The ADC multiplexer Selection Register
617 | .equ MUX0 = 0 ; Analog Channel and Gain Selection Bits
618 | .equ MUX1 = 1 ; Analog Channel and Gain Selection Bits
619 | .equ MUX2 = 2 ; Analog Channel and Gain Selection Bits
620 | .equ MUX3 = 3 ; Analog Channel and Gain Selection Bits
621 | .equ ADLAR = 5 ; Left Adjust Result
622 | .equ REFS0 = 6 ; Reference Selection Bit 0
623 | .equ REFS1 = 7 ; Reference Selection Bit 1
624 |
625 | ; ADCSRA - The ADC Control and Status register
626 | .equ ADCSR = ADCSRA ; For compatibility
627 | .equ ADPS0 = 0 ; ADC Prescaler Select Bits
628 | .equ ADPS1 = 1 ; ADC Prescaler Select Bits
629 | .equ ADPS2 = 2 ; ADC Prescaler Select Bits
630 | .equ ADIE = 3 ; ADC Interrupt Enable
631 | .equ ADIF = 4 ; ADC Interrupt Flag
632 | .equ ADFR = 5 ; ADC Free Running Select
633 | .equ ADSC = 6 ; ADC Start Conversion
634 | .equ ADEN = 7 ; ADC Enable
635 |
636 |
637 |
638 | ; ***** LOCKSBITS ********************************************************
639 | .equ LB1 = 0 ; Lock bit
640 | .equ LB2 = 1 ; Lock bit
641 | .equ BLB01 = 2 ; Boot Lock bit
642 | .equ BLB02 = 3 ; Boot Lock bit
643 | .equ BLB11 = 4 ; Boot lock bit
644 | .equ BLB12 = 5 ; Boot lock bit
645 |
646 |
647 | ; ***** FUSES ************************************************************
648 | ; LOW fuse bits
649 | .equ CKSEL0 = 0 ; Select Clock Source
650 | .equ CKSEL1 = 1 ; Select Clock Source
651 | .equ CKSEL2 = 2 ; Select Clock Source
652 | .equ CKSEL3 = 3 ; Select Clock Source
653 | .equ SUT0 = 4 ; Select start-up time
654 | .equ SUT1 = 5 ; Select start-up time
655 | .equ BODEN = 6 ; Brown out detector enable
656 | .equ BODLEVEL = 7 ; Brown out detector trigger level
657 |
658 | ; HIGH fuse bits
659 | .equ BOOTRST = 0 ; Select Reset Vector
660 | .equ BOOTSZ0 = 1 ; Select Boot Size
661 | .equ BOOTSZ1 = 2 ; Select Boot Size
662 | .equ EESAVE = 3 ; EEPROM memory is preserved through chip erase
663 | .equ CKOPT = 4 ; Oscillator Options
664 | .equ SPIEN = 5 ; Enable Serial programming and Data Downloading
665 | .equ WTDON = 6 ; Enable watchdog
666 | .equ RSTDISBL = 7 ; Disable reset
667 |
668 |
669 |
670 | ; ***** CPU REGISTER DEFINITIONS *****************************************
671 | .def XH = r27
672 | .def XL = r26
673 | .def YH = r29
674 | .def YL = r28
675 | .def ZH = r31
676 | .def ZL = r30
677 |
678 |
679 |
680 | ; ***** DATA MEMORY DECLARATIONS *****************************************
681 | .equ FLASHEND = 0x0fff ; Note: Word address
682 | .equ IOEND = 0x003f
683 | .equ SRAM_START = 0x0060
684 | .equ SRAM_SIZE = 1024
685 | .equ RAMEND = 0x045f
686 | .equ XRAMEND = 0x0000
687 | .equ E2END = 0x01ff
688 | .equ EEPROMEND = 0x01ff
689 | .equ EEADRBITS = 9
690 | #pragma AVRPART MEMORY PROG_FLASH 8192
691 | #pragma AVRPART MEMORY EEPROM 512
692 | #pragma AVRPART MEMORY INT_SRAM SIZE 1024
693 | #pragma AVRPART MEMORY INT_SRAM START_ADDR 0x60
694 |
695 |
696 |
697 | ; ***** BOOTLOADER DECLARATIONS ******************************************
698 | .equ NRWW_START_ADDR = 0xc00
699 | .equ NRWW_STOP_ADDR = 0xfff
700 | .equ RWW_START_ADDR = 0x0
701 | .equ RWW_STOP_ADDR = 0xbff
702 | .equ PAGESIZE = 32
703 | .equ FIRSTBOOTSTART = 0xf80
704 | .equ SECONDBOOTSTART = 0xf00
705 | .equ THIRDBOOTSTART = 0xe00
706 | .equ FOURTHBOOTSTART = 0xc00
707 | .equ SMALLBOOTSTART = FIRSTBOOTSTART
708 | .equ LARGEBOOTSTART = FOURTHBOOTSTART
709 |
710 |
711 |
712 | ; ***** INTERRUPT VECTORS ************************************************
713 | .equ INT0addr = 0x0001 ; External Interrupt Request 0
714 | .equ INT1addr = 0x0002 ; External Interrupt Request 1
715 | .equ OC2addr = 0x0003 ; Timer/Counter2 Compare Match
716 | .equ OVF2addr = 0x0004 ; Timer/Counter2 Overflow
717 | .equ ICP1addr = 0x0005 ; Timer/Counter1 Capture Event
718 | .equ OC1Aaddr = 0x0006 ; Timer/Counter1 Compare Match A
719 | .equ OC1Baddr = 0x0007 ; Timer/Counter1 Compare Match B
720 | .equ OVF1addr = 0x0008 ; Timer/Counter1 Overflow
721 | .equ OVF0addr = 0x0009 ; Timer/Counter0 Overflow
722 | .equ SPIaddr = 0x000a ; Serial Transfer Complete
723 | .equ URXCaddr = 0x000b ; USART, Rx Complete
724 | .equ UDREaddr = 0x000c ; USART Data Register Empty
725 | .equ UTXCaddr = 0x000d ; USART, Tx Complete
726 | .equ ADCCaddr = 0x000e ; ADC Conversion Complete
727 | .equ ERDYaddr = 0x000f ; EEPROM Ready
728 | .equ ACIaddr = 0x0010 ; Analog Comparator
729 | .equ TWIaddr = 0x0011 ; 2-wire Serial Interface
730 | .equ SPMRaddr = 0x0012 ; Store Program Memory Ready
731 |
732 | .equ INT_VECTORS_SIZE = 19 ; size in words
733 |
734 | #pragma AVRPART CORE INSTRUCTIONS_NOT_SUPPORTED break
735 |
736 | #endif /* _M8DEF_INC_ */
737 |
738 | ; ***** END OF FILE ******************************************************
