1 | library IEEE;
2 | use IEEE.STD_LOGIC_1164.ALL;
3 | use IEEE.std_logic_arith.all;
4 |
5 |
6 |
7 |
8 | entity PID_Regler is
9 | generic(
10 | data_width: integer:= 14;
11 | intern_data_width: integer:= 28;
12 | TA: integer:=1
13 | );
14 | port (
15 | w : in std_logic_vector(data_width-1 downto 0); --:= (others => '0');
16 | x : in std_logic_vector(data_width-1 downto 0); --:= (others => '0');
17 | y : out std_logic_vector(data_width-1 downto 0); --:= (others => '0');
18 | TP : in std_logic_vector(intern_data_width-1 downto 0);
19 | TI : in std_logic_vector(intern_data_width-1 downto 0);
20 | TD : in std_logic_vector(intern_data_width-1 downto 0);
21 | clk_i : in std_logic;
22 | rst_i : in std_logic
23 | );
24 | end PID_Regler;
25 |
26 | architecture Behavioral of PID_Regler is
27 |
28 | signal e1 : std_logic_vector(data_width-1 downto 0) := (others => '0');
29 | signal ealt : std_logic_vector(data_width-1 downto 0) := (others => '0');
30 | signal e2 : std_logic_vector(data_width-1 downto 0) := (others => '0');
31 | signal e3 : std_logic_vector(data_width-1 downto 0) := (others => '0');
32 |
33 | begin
34 |
35 | Regler1: process(clk_i, rst_i)
36 | --rst_i wurde hinzugefügt
37 | variable yp: std_logic_vector(intern_data_width-1 downto 0);
38 | variable yi: std_logic_vector(intern_data_width-1 downto 0);
39 | variable yi_alt: std_logic_vector(intern_data_width-1 downto 0);
40 | variable yd: std_logic_vector(intern_data_width-1 downto 0);
41 |
42 | begin
43 | if (rst_i = '1') then
44 | yp := (others => '0');
45 | yi := (others => '0');
46 | yi_alt:=(others => '0');
47 | yd := (others => '0');
48 | y <= (others => '0');
49 | elsif (clk_i='1') then
50 | e1 <= std_logic_vector(signed(w) - signed(x));
51 | yp := (signed(TP)*signed(e1));
52 | yi := yi_alt+(TI*e1*TA); -- yi_alt=yi
53 | yd := (TD*((e1-ealt)/TA)); -- ealt=e
54 | ealt <= e1;
55 | y <= (yp+yi+yd);
56 |
57 | yi_alt := yi;
58 | end if;
59 | end process Regler1;
60 |
61 |
62 |
63 | Regler2: process(clk_i, rst_i)
64 | --rst_i wurde hinzugefügt
65 | variable yp: std_logic_vector(intern_data_width-1 downto 0);
66 | variable yi: std_logic_vector(intern_data_width-1 downto 0);
67 | variable yi_alt: std_logic_vector(intern_data_width-1 downto 0);
68 | variable yd: std_logic_vector(intern_data_width-1 downto 0);
69 |
70 | begin
71 | if (rst_i = '1') then
72 | yp := (others => '0');
73 | yi := (others => '0');
74 | yd := (others => '0');
75 | ealt <= (others => '0');
76 | y <= (others => '0');
77 | elsif (clk_i='1') then
78 | e2 <= std_logic_vector(signed(w) - signed(x));
79 | yp := ((TP)*(e2));
80 | yi := ((yi_alt)+((TI)*(e2)*TA)); -- yi_alt=yi
81 | yd := ((TD)*(((e2)-(ealt))/TA)); -- ealt=e
82 | ealt <= e2;
83 | y <= ((yp)+(yi)+(yd));
84 |
85 | yi_alt := yi;
86 | end if;
87 | end process Regler2;
88 |
89 |
90 | Regler3: process(clk_i, rst_i)
91 | --rst_i wurde hinzugefügt
92 | variable yp: std_logic_vector(intern_data_width-1 downto 0);
93 | variable yi: std_logic_vector(intern_data_width-1 downto 0);
94 | variable yi_alt: std_logic_vector(intern_data_width-1 downto 0);
95 | variable yd: std_logic_vector(intern_data_width-1 downto 0);
96 |
97 | begin
98 | if (rst_i = '1') then
99 | yp := (others => '0');
100 | yi := (others => '0');
101 | yd := (others => '0');
102 | y <= (others => '0');
103 | elsif(clk_i='1') then
104 | e3 <= std_logic_vector(signed(w) - signed(x));
105 | yp := ((TP)*e3);
106 | yi := ((yi_alt)+((TI)*(e3)*TA)); -- yi_alt=yi
107 | yd := ((TD)*(((e3)-(ealt))/TA)); -- ealt=e
108 | ealt <= (e3);
109 | y <= ((yp)+(yi)+(yd));
110 |
111 | yi_alt := yi;
112 | end if;
113 | end process Regler3;
114 | end Behavioral;
115 |
116 | •
