1 | #include <OneWire.h>
2 | #include <DallasTemperature.h>
3 |
4 | OneWire ds(2);
5 |
6 | // Device Adressen der einzelnen Temperatursensoren angeben
7 | DeviceAddress sensor1 = { 0x10, 0x38, 0x27, 0x57, 0x2, 0x8, 0x0, 0x79 };
8 | DeviceAddress sensor2 = { 0x10, 0x16, 0x2E, 0x57, 0x2, 0x8, 0x0, 0x2F };
9 | //DeviceAddress sensor3 = { 0x10, 0x11, 0x40, 0xC0, 0x1, 0x8, 0x0, 0x9A };
10 | //DeviceAddress sensor4 = { 0x10, 0x77, 0x38, 0x57, 0x2, 0x8, 0x0, 0x3B };
11 |
12 | char sensor1Name[] = "Sensor1: ";
13 | char sensor2Name[] = "Sensor2: ";
14 | //char sensor3Name[] = "Sensor3: ";
15 | //char sensor4Name[] = "Sensor4: ";
16 |
17 | int BlinkRate=0; // Anzahl Blinken für Tests
18 | String Input=""; // Input von Serieller Schnittstelle
19 | String Befehl="NOP"; // Befehl aus Input
20 | int Parameter=0; // Parameter aus Input
21 | int Wert=0; // Rückgabewert Analog
22 |
23 | char buffer[20] = ""; // Speicherbereich für Datenkonvertierung
24 |
25 |
26 | void setup()
27 | {
28 | Serial.begin(9600);
29 | }
30 |
31 |
32 | void loop(void)
33 | {
34 | if (Serial.available()) Einlesen();
35 | //Serial.println("Testausgabe");
36 | //delay(2000);
37 | }
38 |
39 | void Einlesen()
40 | {
41 | while (Serial.available())
42 | {
43 | char ch = Serial.read();
44 | //Serial.print("Echo: ");
45 | //Serial.println(ch);
46 | Input=Input+ch;
47 | //Serial.println(Input);
48 | delay(10);
49 | }
50 | Befehl = Input.substring(0, 4);
51 | //Serial.println("Befehl: " + Befehl);
52 | Parameter = (Input.substring(4, 6)).toInt();
53 | //Serial.print("Parameter: ");
54 | //Serial.println(Parameter,DEC);
55 | ausfuehren();
56 | //Serial.println(Befehl + Parameter + " = " + Wert);
57 |
58 | Input="";
59 | }
60 |
61 | void ausfuehren()
62 | {
63 |
64 | if (Befehl=="OW01")
65 | {
66 | float temp1 = getTemperature(sensor1);
67 | Serial.println(temp1);
68 | }
69 | if (Befehl=="OW02")
70 | {
71 | float temp2 = getTemperature(sensor2);
72 | Serial.println(temp2);
73 | }
74 | else
75 | {
76 | Serial.println("ERROR");
77 | }
78 | }
79 |
80 | void writeTimeToScratchpad(byte* address)
81 | {
82 | //reset the bus
83 | ds.reset();
84 | //select our sensor
85 | ds.select(address);
86 | //CONVERT T function call (44h) which puts the temperature into the scratchpad
87 | ds.write(0x44,1);
88 | //sleep a second for the write to take place
89 | delay(1000);
90 | }
91 |
92 | void readTimeFromScratchpad(byte* address, byte* data)
93 | {
94 | //reset the bus
95 | ds.reset();
96 | //select our sensor
97 | ds.select(address);
98 | //read the scratchpad (BEh)
99 | ds.write(0xBE);
100 | for (byte i=0;i<9;i++){
101 | data[i] = ds.read();
102 | }
103 | }
104 |
105 | float getTemperature(byte* address)
106 | {
107 | int tr;
108 | byte data[12];
109 |
110 | writeTimeToScratchpad(address);
111 |
112 | readTimeFromScratchpad(address,data);
113 |
114 | //put in temp all the 8 bits of LSB (least significant byte)
115 | tr = data[0];
116 |
117 | //check for negative temperature
118 | if (data[1] > 0x80)
119 | {
120 | tr = !tr + 1; //two's complement adjustment
121 | tr = tr * -1; //flip value negative.
122 | }
123 |
124 | //COUNT PER Celsius degree (10h)
125 | int cpc = data[7];
126 | //COUNT REMAIN (0Ch)
127 | int cr = data[6];
128 |
129 | //drop bit 0
130 | tr = tr >> 1;
131 |
132 | return tr - (float)0.25 + (cpc - cr)/(float)cpc;
133 | }
