1 | //*****************************************************************************
2 | // +--+
3 | // | ++----+
4 | // +-++ |
5 | // | |
6 | // +-+--+ |
7 | // | +--+--+
8 | // +----+ Copyright (c) 2010-11 Code Red Technologies Ltd.
9 | //
10 | // LED flashing Timer16 application for LPCXPresso1114 board
11 | //
12 | // Software License Agreement
13 | //
14 | // The software is owned by Code Red Technologies and/or its suppliers, and is
15 | // protected under applicable copyright laws. All rights are reserved. Any
16 | // use in violation of the foregoing restrictions may subject the user to criminal
17 | // sanctions under applicable laws, as well as to civil liability for the breach
18 | // of the terms and conditions of this license.
19 | //
20 | // THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED
21 | // OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
22 | // MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
23 | // USE OF THIS SOFTWARE FOR COMMERCIAL DEVELOPMENT AND/OR EDUCATION IS SUBJECT
24 | // TO A CURRENT END USER LICENSE AGREEMENT (COMMERCIAL OR EDUCATIONAL) WITH
25 | // CODE RED TECHNOLOGIES LTD.
26 | //
27 | //*****************************************************************************
28 |
29 |
30 | #include "LPC11xx.h" /* LPC11xx definitions */
31 | #include "timer16.h"
32 | #include "clkconfig.h"
33 | #include "gpio.h"
34 |
35 | #include <cr_section_macros.h>
36 | #include <NXP/crp.h>
37 |
38 | // Variable to store CRP value in. Will be placed automatically
39 | // by the linker when "Enable Code Read Protect" selected.
40 | // See crp.h header for more information
41 | __CRP const unsigned int CRP_WORD = CRP_NO_CRP ;
42 |
43 | // LPCXpresso processor card LED
44 | #define LED_PORT 0 // Port for led
45 | #define LED_BIT 7 // Bit on port for led
46 | #define LED_ON 1 // Level to set port to turn on led
47 | #define LED_OFF 0 // Level to set port to turn off led
48 |
49 | extern volatile uint32_t timer16_0_counter;
50 |
51 | int main (void)
52 | {
53 | GPIOInit();
54 |
55 | // Initialise Timer16_0 to tick at rate of 1/2000th of second.
56 | // Note that as this is a 16 bit timer, the maximum count we can
57 | // load into timer is 0xFFFF, or 65535. Default clock speed
58 | // set up by CMSIS SystemInit function - SystemCoreClock - is
59 | // 48MHz or 48000000 Hz. Dividing this by 2000 is 24000 which is
60 | // within appropriate timer16 maximum. This could be extended
61 | // if timer routine extended to make use of Prescale Counter register
62 | // Note by default LPC_SYSCON->SYSAHBCLKDIV is 1.
63 | init_timer16(0, (SystemCoreClock/LPC_SYSCON->SYSAHBCLKDIV)/2000 );
64 |
65 | // Initialise counter that counts Timer16_0 ticks
66 | timer16_0_counter = 0;
67 |
68 | //Enable Timer16_0
69 | enable_timer16(0);
70 |
71 | // Set port for LED to output
72 | GPIOSetDir( LED_PORT, LED_BIT, 1 );
73 | GPIOSetDir( 0, 10, 1 ); // Set PORT0 direction Bit10 to output
74 |
75 | while (1) /* Loop forever */
76 | {
77 |
78 | // LED is on for 1st half-second
79 | if ( (timer16_0_counter > 0) && (timer16_0_counter <= 1000) )
80 | {
81 | GPIOSetValue( LED_PORT, LED_BIT, LED_OFF );
82 | GPIOSetValue(0,10,1); // PORT0 Bit10 High
83 | }
84 |
85 | // LED is off for 2nd half-second
86 | if ( (timer16_0_counter > 1000) && (timer16_0_counter <= 2000) )
87 | {
88 | GPIOSetValue( LED_PORT, LED_BIT, LED_ON );
89 | GPIOSetValue(0,10,0); // PORT0 Bit10 Low
90 | }
91 |
92 | // Reset counter
93 | else if ( timer16_0_counter > 2000 )
94 | {
95 | timer16_0_counter = 0;
96 | }
97 | }
98 | }
