1 | #include "RFM12B.h"
2 | #include "avr/io.h"
3 | #include "string.h"
4 |
5 | #define F_CPU 8000000UL
6 | #include <util/delay.h>
7 |
8 | void SPIInit() {
9 |
10 | SS_DDR |= (1 << cs_pin);
11 | //DI
12 | DDRB &= ~(1 << 5);
13 | //DO
14 | DDRB = (1 << 6);
15 | //SCK
16 | DDRB |= (1 << 7);
17 | //Interrupt Pin has Pullup
18 | DDRD &= ~(1 << 2);
19 | PORTD |= (1 << 2);
20 | }
21 |
22 |
23 | uint8_t Byte(uint8_t out){
24 |
25 | uint8_t returnvalue = 0;
26 | int8_t i;
27 | for (i = 7;i>=0;i--){
28 |
29 | //Bit low or high?
30 | if(out & (1<<i))
31 | PORTB |= (1<<6);
32 | else
33 | PORTB &= ~(1<<6);
34 |
35 | //Clock High
36 | PORTB |= (1 << 7);
37 | _delay_us(1);
38 |
39 | //Clock Low
40 | PORTB &= ~(1 << 7);
41 |
42 | //Read input
43 | if ( PINB & (1<<PINB5) ) {
44 | returnvalue |= (1<<i);
45 | }
46 | _delay_us(1);
47 | }
48 | return returnvalue;
49 | }
50 |
51 |
52 | uint16_t XFERSlow(uint16_t cmd) {
53 |
54 | SS_PORT &= ~(1 << cs_pin);
55 | uint16_t reply = Byte(cmd >> 8) << 8;
56 | reply |= Byte(cmd);
57 | SS_PORT |= (1 << cs_pin);
58 | return reply;
59 | }
60 |
61 | void XFER(uint16_t cmd) {
62 | SS_PORT &= ~(1 << cs_pin);
63 | Byte(cmd >> 8) << 8;
64 | Byte(cmd);
65 | SS_PORT |= (1 << cs_pin);
66 | }
67 |
68 | void Initialize(uint8_t ID, uint8_t networkid)
69 | {
70 |
71 |
72 | Data = rf12_data;
73 | DataLen = &rf12_buf[3];
74 |
75 | uint8_t txPower = 0;
76 | uint8_t airKbps = 0x08;
77 | uint8_t lowVoltageThreshold = RF12_2v75;
78 |
79 |
80 | cs_pin = SS_BIT;
81 | nodeID = ID;
82 | networkID = networkid;
83 | SPIInit();
84 | XFER(0x0000); // intitial SPI transfer added to avoid power-up problem
85 | XFER(RF_SLEEP_MODE); // DC (disable clk pin), enable lbd
86 |
87 | // wait until RFM12B is out of power-up reset, this takes several *seconds*
88 | XFER(RF_TXREG_WRITE); // in case we're still in OOK mode
89 | //Für den Tiny geändert: while (!(PIND & (1 << 3) ))
90 | while (!(PIND & (1 << 2) )) // digitalRead(18) == 0)
91 | XFER(0x0000);
92 |
93 | XFER(0x80C7 | (RF12_868MHZ << 4)); // EL (ena TX), EF (ena RX FIFO), 12.0pF
94 | XFER(0xA640); // Frequency is exactly 434/868/915MHz (whatever freqBand is)
95 | XFER(0xC600 + airKbps); //Air transmission baud rate: 0x08= ~38.31Kbps
96 | XFER(0x94A2); // VDI,FAST,134kHz,0dBm,-91dBm
97 | XFER(0xC2AC); // AL,!ml,DIG,DQD4
98 | if (networkID != 0) {
99 | XFER(0xCA83); // FIFO8,2-SYNC,!ff,DR
100 | XFER(0xCE00 | networkID); // SYNC=2DXX;
101 | } else {
102 | XFER(0xCA8B); // FIFO8,1-SYNC,!ff,DR
103 | XFER(0xCE2D); // SYNC=2D;
104 | }
105 |
106 |
107 | XFER(0xC483); // @PWR,NO RSTRIC,!st,!fi,OE,EN
108 | XFER(0x9850 | (txPower > 7 ? 7 : txPower)); // !mp,90kHz,MAX OUT //last byte=power level: 0=highest, 7=lowest
109 | XFER(0xCC77); // OB1,OB0, LPX,!ddy,DDIT,BW0
110 | XFER(0xE000); // NOT USE
111 | XFER(0xC800); // NOT USE
112 | XFER(0xC043); // Clock output (1.66MHz), Low Voltage threshold (2.55V)
113 |
114 | rxstate = TXIDLE;
115 |
116 | //Für den Tiny geändert
117 | //Interupt enable
118 | //EICRA |= (1 << ISC31);
119 | //EICRA &= ~(1 << ISC30);
120 | //EIMSK |= (1 << INT3);
121 | MCUCR |= (1<<ISC01);
122 | MCUCR &= ~(1<<ISC00);
123 | GIMSK |= (1<<INT0);
124 |
125 | sei();
126 |
127 | }
128 |
129 |
130 | // access to the RFM12B internal registers with interrupts disabled
131 | uint16_t Control(uint16_t cmd) {
132 | //Für den Tiny geändert
133 | //EIMSK &= ~(1 << INT0);
134 | GIMSK &= ~(1<<INT0);
135 |
136 | uint16_t r = XFERSlow(cmd);
137 |
138 | //Für den Tiny geändert
139 | //EIMSK |= (1 << INT0);
140 | GIMSK |= (1<<INT0);
141 | return r;
142 | }
143 |
144 |
145 |
146 | void InterruptHandler() {
147 | XFER(0x0000);
148 |
149 | if (rxstate == TXRECV) {
150 | uint8_t in = XFERSlow(RF_RX_FIFO_READ);
151 |
152 | if (rxfill == 0 && networkID != 0)
153 | rf12_buf[rxfill++] = networkID;
154 |
155 | rf12_buf[rxfill++] = in;
156 | rf12_crc = _crc16_update(rf12_crc, in);
157 |
158 | if (rxfill >= rf12_len + 6 || rxfill >= RF_MAX)
159 | XFER(RF_IDLE_MODE);
160 | } else {
161 | uint8_t out;
162 |
163 | if (rxstate < 0) {
164 | uint8_t pos = 4 + rf12_len + rxstate++;
165 | out = rf12_buf[pos];
166 | rf12_crc = _crc16_update(rf12_crc, out);
167 | } else
168 | switch (rxstate++) {
169 | case TXSYN1: out = 0x2D; break;
170 | case TXSYN2: out = networkID; rxstate = -(3 + rf12_len); break;
171 | case TXCRC1: out = rf12_crc; break;
172 | case TXCRC2: out = rf12_crc >> 8; break;
173 | case TXDONE: XFER(RF_IDLE_MODE);
174 | default: out = 0xAA;
175 | }
176 |
177 | XFER(RF_TXREG_WRITE + out);
178 | }
179 | }
180 |
181 | //Für den Tiny geändert:
182 | //ISR(INT3_vect) {
183 | ISR(INT0_vect) {
184 |
185 | InterruptHandler();
186 | }
187 |
188 |
189 | void ReceiveStart() {
190 | rxfill = rf12_len = 0;
191 | rf12_crc = ~0;
192 | if (networkID != 0)
193 | rf12_crc = _crc16_update(~0, networkID);
194 | rxstate = TXRECV;
195 | XFER(RF_RECEIVER_ON);
196 | }
197 |
198 | char ReceiveComplete() {
199 | if (rxstate == TXRECV && (rxfill >= rf12_len + 6 || rxfill >= RF_MAX)) {
200 | rxstate = TXIDLE;
201 | if (rf12_len > RF12_MAXDATA)
202 | rf12_crc = 1;
203 | if (RF12_DESTID == 0 || RF12_DESTID == nodeID) {
204 | if (!rf12_crc)
205 | rf12_seq = -1;
206 | return 1;
207 | }
208 | }
209 | if (rxstate == TXIDLE)
210 | ReceiveStart();
211 | return 0;
212 | }
213 |
214 | char CanSend() {
215 |
216 | if (rxstate == TXRECV && rxfill == 0 && (Byte(0x00) & (RF_RSSI_BIT >> 8)) == 0) {
217 | XFER(RF_IDLE_MODE);
218 | rxstate = TXIDLE;
219 | return 1;
220 | }
221 | return 0;
222 | }
223 |
224 | void SendStart(uint8_t toNodeID, char requestACK, char sendACK) {
225 | rf12_hdr1 = toNodeID | (sendACK ? RF12_HDR_ACKCTLMASK : 0);
226 | rf12_hdr2 = nodeID | (requestACK ? RF12_HDR_ACKCTLMASK : 0);
227 | rf12_crc = ~0;
228 | rf12_crc = _crc16_update(rf12_crc, networkID);
229 | rxstate = TXPRE1;
230 | XFER(RF_XMITTER_ON);
231 | }
232 |
233 | void SendStart2(uint8_t toNodeID, const void* sendBuf, uint8_t sendLen, char requestACK, char sendACK, uint8_t waitMode) {
234 | rf12_len = sendLen;
235 | memcpy((void*) rf12_data, sendBuf, sendLen);
236 |
237 |
238 |
239 | SendStart(toNodeID, requestACK, sendACK);
240 |
241 | SendWait(waitMode);
242 | }
243 |
244 |
245 | void SendACK2(const void* sendBuf, uint8_t sendLen, uint8_t waitMode) {
246 | while (!CanSend()) ReceiveComplete();
247 | SendStart2(RF12_SOURCEID, sendBuf, sendLen, 0, 1, waitMode);
248 | }
249 |
250 |
251 |
252 | void SendACK() {
253 | const void* sendBuf = "";
254 | uint8_t sendLen = 0;
255 | uint8_t waitMode = SLEEP_MODE_IDLE;
256 | while (!CanSend()) ReceiveComplete();
257 | SendStart2(RF12_SOURCEID, sendBuf, sendLen, 0, 1, waitMode);
258 | }
259 |
260 |
261 |
262 | void Send(uint8_t toNodeID, const void* sendBuf, uint8_t sendLen, char requestACK)
263 | {
264 | uint8_t waitMode = SLEEP_MODE_STANDBY;
265 | while (!CanSend()) ReceiveComplete();
266 | SendStart2(toNodeID, sendBuf, sendLen, requestACK, 0, waitMode);
267 | }
268 |
269 | void SendWait(uint8_t waitMode) {
270 | while (rxstate != TXIDLE);
271 |
272 | }
273 |
274 | void OnOff(uint8_t value) {
275 | XFER(value ? RF_XMITTER_ON : RF_IDLE_MODE);
276 | }
277 |
278 | void Sleep2(char n) {
279 | if (n < 0)
280 | Control(RF_IDLE_MODE);
281 | else {
282 | Control(RF_WAKEUP_TIMER | 0x0500 | n);
283 | Control(RF_SLEEP_MODE);
284 | if (n > 0)
285 | Control(RF_WAKEUP_MODE);
286 | }
287 | rxstate = TXIDLE;
288 | }
289 | void Sleep() { Sleep2(0); }
290 | void Wakeup() { Sleep2(-1); }
291 |
292 | char LowBattery() {
293 | return (Control(0x0000) & RF_LBD_BIT) != 0;
294 | }
295 |
296 | uint8_t GetSender() {
297 | return RF12_SOURCEID;
298 | }
299 |
300 | uint8_t * GetData() { return rf12_data; }
301 |
302 |
303 | uint8_t GetDataLen() { return *DataLen; }
304 | char ACKRequested() { return RF12_WANTS_ACK; }
305 |
306 | char ACKReceived(uint8_t fromNodeID) {
307 | if (ReceiveComplete())
308 | return CRCPass() &&
309 | RF12_DESTID == nodeID &&
310 | (RF12_SOURCEID == fromNodeID || fromNodeID == 0) &&
311 | (rf12_hdr1 & RF12_HDR_ACKCTLMASK) &&
312 | !(rf12_hdr2 & RF12_HDR_ACKCTLMASK);
313 | return 0;
314 | }
315 |
316 | char CRCPass() {
317 | return rf12_crc == 0;
318 | }
