1 | % ./configure --with-libiberty=/usr/lib/x86_64-linux-gnu
2 | checking for a BSD-compatible install... /usr/bin/install -c
3 | checking whether build environment is sane... yes
4 | checking for a thread-safe mkdir -p... /bin/mkdir -p
5 | checking for gawk... gawk
6 | checking whether make sets $(MAKE)... yes
7 | checking whether to enable maintainer-specific portions of Makefiles... no
8 | checking whether build system is MSYS/MingW... no
9 | checking build system type... x86_64-unknown-linux-gnu
10 | checking host system type... x86_64-unknown-linux-gnu
11 | checking for style of include used by make... GNU
12 | checking for gcc... gcc
13 | checking whether the C compiler works... yes
14 | checking for C compiler default output file name... a.out
15 | checking for suffix of executables...
16 | checking whether we are cross compiling... no
17 | checking for suffix of object files... o
18 | checking whether we are using the GNU C compiler... yes
19 | checking whether gcc accepts -g... yes
20 | checking for gcc option to accept ISO C89... none needed
21 | checking dependency style of gcc... gcc3
22 | checking for a sed that does not truncate output... /bin/sed
23 | checking for grep that handles long lines and -e... /bin/grep
24 | checking for egrep... /bin/grep -E
25 | checking for fgrep... /bin/grep -F
26 | checking for ld used by gcc... /usr/bin/ld
27 | checking if the linker (/usr/bin/ld) is GNU ld... yes
28 | checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
29 | checking the name lister (/usr/bin/nm -B) interface... BSD nm
30 | checking whether ln -s works... yes
31 | checking the maximum length of command line arguments... 1572864
32 | checking whether the shell understands some XSI constructs... yes
33 | checking whether the shell understands "+="... yes
34 | checking for /usr/bin/ld option to reload object files... -r
35 | checking for objdump... objdump
36 | checking how to recognize dependent libraries... pass_all
37 | checking for ar... ar
38 | checking for strip... strip
39 | checking for ranlib... ranlib
40 | checking command to parse /usr/bin/nm -B output from gcc object... ok
41 | checking how to run the C preprocessor... gcc -E
42 | checking for ANSI C header files... yes
43 | checking for sys/types.h... yes
44 | checking for sys/stat.h... yes
45 | checking for stdlib.h... yes
46 | checking for string.h... yes
47 | checking for memory.h... yes
48 | checking for strings.h... yes
49 | checking for inttypes.h... yes
50 | checking for stdint.h... yes
51 | checking for unistd.h... yes
52 | checking for dlfcn.h... yes
53 | checking for objdir... .libs
54 | checking if gcc supports -fno-rtti -fno-exceptions... no
55 | checking for gcc option to produce PIC... -fPIC -DPIC
56 | checking if gcc PIC flag -fPIC -DPIC works... yes
57 | checking if gcc static flag -static works... yes
58 | checking if gcc supports -c -o file.o... yes
59 | checking if gcc supports -c -o file.o... (cached) yes
60 | checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
61 | checking whether -lc should be explicitly linked in... no
62 | checking dynamic linker characteristics... GNU/Linux ld.so
63 | checking how to hardcode library paths into programs... immediate
64 | checking whether stripping libraries is possible... yes
65 | checking if libtool supports shared libraries... yes
66 | checking whether to build shared libraries... yes
67 | checking whether to build static libraries... yes
68 | checking for g++... g++
69 | checking whether we are using the GNU C++ compiler... yes
70 | checking whether g++ accepts -g... yes
71 | checking dependency style of g++... gcc3
72 | checking whether we are using the GNU C++ compiler... (cached) yes
73 | checking whether g++ accepts -g... (cached) yes
74 | checking dependency style of g++... (cached) gcc3
75 | checking how to run the C++ preprocessor... g++ -E
76 | checking for ld used by g++... /usr/bin/ld -m elf_x86_64
77 | checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
78 | checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
79 | checking for g++ option to produce PIC... -fPIC -DPIC
80 | checking if g++ PIC flag -fPIC -DPIC works... yes
81 | checking if g++ static flag -static works... yes
82 | checking if g++ supports -c -o file.o... yes
83 | checking if g++ supports -c -o file.o... (cached) yes
84 | checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
85 | checking dynamic linker characteristics... GNU/Linux ld.so
86 | checking how to hardcode library paths into programs... immediate
87 | checking for swig... no
88 | configure: WARNING: cannot find 'swig' program. You should look at http://www.swig.org
89 | checking Tcl desired... yes
90 | tclConfig.sh directory = /usr/lib
91 | checking for /usr/lib/tclConfig.sh... no
92 | configure: WARNING: tclConfig.sh not found .. guessing
93 | checking tcl.h usability... no
94 | checking tcl.h presence... no
95 | checking for tcl.h... no
96 | checking for tcl.h... (cached) no
97 | checking for wish... /usr/bin/wish
98 | checking for tclsh... /usr/bin/tclsh
99 | can't find package Itcl
100 | configure: WARNING: Itcl package not installed, tcl examples with gui will not work
101 | checking for --enable-python... no
102 | checking for python... /usr/bin/python
103 | checking for python version... 2.7
104 | checking for python platform... linux2
105 | checking for python script directory... ${prefix}/lib/python2.7/dist-packages
106 | checking for python extension module directory... ${exec_prefix}/lib/python2.7/dist-packages
107 | checking for time... yes
108 | checking for avr-as... avr-as
109 | checking for avr-ld... avr-ld
110 | checking for avr-gcc... avr-gcc
111 | checking for avr-g++... avr-g++
112 | checking for avr-nm... avr-nm
113 | checking for nm... nm
114 | with_bfd = check
115 | with_libiberty = /usr/lib/x86_64-linux-gnu
116 | checking bfd search- /usr/x86_64-unknown-linux-gnu/avr in "include" and "lib"... no
117 | checking bfd search- /usr/avr in "include" and "lib"... no
118 | checking bfd search- /usr in "" and ""... no
119 | checking bfd search- /usr in "bfd" and "bfd"... no
120 | checking bfd search- /usr in "include" and "lib64"... no
121 | checking bfd search- /usr in "include" and "lib"... yes
122 | checking libiberty search- /usr/lib/x86_64-linux-gnu/x86_64-unknown-linux-gnu/avr in "lib"... no
123 | checking libiberty search- /usr/lib/x86_64-linux-gnu/avr in "lib"... no
124 | checking libiberty search- /usr/lib/x86_64-linux-gnu in ""... yes
125 | …
126 |
127 | Summary:
128 | build system = GNU/Linux
129 | AVR_GCC=avr-gcc
130 | AVR_LIBBFD_INC=/usr/include
131 | AVR_LIBBFD_LIB=/usr/lib/libbfd.so
132 | AVR_LIBIBERTY_LIB=/usr/lib/x86_64-linux-gnu//libiberty.a
133 | PYTHON=/usr/bin/python
134 | build verilog modul avr.vpi = no
