1 | void ADC_Setup(void)
2 | {
3 | ADC_InitTypeDef ADC_InitStructure;
4 | ADC_CommonInitTypeDef ADC_CommonInitStructure;
5 | DMA_InitTypeDef DMA_InitStructure;
6 | GPIO_InitTypeDef GPIO_initStruct;
7 |
8 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
9 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
10 | RCC_AHB1PeriphClockCmd((RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
11 | RCC_AHB1Periph_GPIOC), ENABLE);
12 |
13 | // DMA2 Stream0 channel0 configuration
14 | DMA_Cmd(DMA2_Stream0, DISABLE);
15 | while (DMA2_Stream0->CR & DMA_SxCR_EN);
16 |
17 | DMA_InitStructure.DMA_Channel = DMA_Channel_0; //DMA channel 0..7
18 | DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR; //ADC1 Address
19 | DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ADC_Buffer; //uint16_t ADC_Buffer
20 | DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; // Data from Peripheral to memory
21 | DMA_InitStructure.DMA_BufferSize = NBR_OF_CHANNELS; //Number of Data
22 | DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //increment peripheral pointer
23 | DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //increment address pointer
24 | DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //size of data .. 16bit
25 | DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //size of data
26 | DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //start from beginning when end is reached
27 | DMA_InitStructure.DMA_Priority = DMA_Priority_High; //high - only adc exists
28 | DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable; //FIFO or direct
29 | DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full; //FIFO specific
30 | DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; //specifies the amount of data to be transferred in a single non interruptable transaction
31 | DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; //specifies the amount of data to be transferred in a single non interruptable transaction
32 | DMA_Init(DMA2_Stream0, &DMA_InitStructure);
33 |
34 | DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, ENABLE);
35 |
36 | NVIC_InitTypeDef NVIC_InitStructure;
37 | NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
38 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
39 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
40 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
41 | NVIC_Init(&NVIC_InitStructure);
42 |
43 | DMA_ClearFlag(DMA2_Stream0, DMA_FLAG_FEIF2|DMA_FLAG_DMEIF2|DMA_FLAG_TEIF2|DMA_FLAG_HTIF2|DMA_FLAG_TCIF2);
44 | DMA_Cmd(DMA2_Stream0, ENABLE);
45 |
46 |
47 | // Configure ADC1 Pins
48 | GPIO_initStruct.GPIO_Mode = GPIO_Mode_AN;
49 | GPIO_initStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
50 |
51 | GPIO_initStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_6 | GPIO_Pin_7;
52 | GPIO_Init(GPIOA, &GPIO_initStruct);
53 |
54 | GPIO_initStruct.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5;
55 | GPIO_Init(GPIOC, &GPIO_initStruct);
56 |
57 | // ADC1 Init
58 | ADC_DeInit();
59 | ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent; //single, dual, triple
60 | ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div6; //max 14MHz aus APB2? (Diller)
61 | ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; //
62 | ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles; //Delay between to ADC-cycles
63 | ADC_CommonInit(&ADC_CommonInitStructure);
64 |
65 | ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
66 | ADC_InitStructure.ADC_ScanConvMode = ENABLE; //Enable: Multiplexing
67 | ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //Start next Conv. immediately
68 | ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
69 | ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; //this case: Software trigger
70 | ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
71 | ADC_InitStructure.ADC_NbrOfConversion = NBR_OF_CHANNELS; //number of channels in regular group
72 | ADC_Init(ADC1, &ADC_InitStructure);
73 |
74 | // ADC1 regular channel config
75 | ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_480Cycles);
76 | ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_480Cycles);
77 | ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_480Cycles);
78 | ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_480Cycles);
79 | ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 5, ADC_SampleTime_480Cycles);
80 |
81 | ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 6, ADC_SampleTime_480Cycles);
82 |
83 | ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 7, ADC_SampleTime_480Cycles);
84 | ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 8, ADC_SampleTime_480Cycles);
85 | ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 9, ADC_SampleTime_480Cycles);
86 | ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 10, ADC_SampleTime_480Cycles);
87 | ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_480Cycles);
88 | ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_480Cycles);
89 |
90 | // Enable DMA request after last transfer (Single-ADC mode)
91 | ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
92 |
93 | // Enable ADC1 DMA
94 | ADC_DMACmd(ADC1, ENABLE);
95 |
96 | // Enable ADC1
97 | ADC_Cmd(ADC1, ENABLE);
98 |
99 | ADC_SoftwareStartConv(ADC1);
100 | }
