Hallo, hat es jemand geschafft einen CC2530 von TI, der in den Philips living color Produkten verbaut ist, ins Hue-Netz zu bringen? Habe gerade ein kleines Board mit Z-Stack-Lightning 1.0.2 ausgestattet. Leider finde ich das Board mit der Hue bridge nicht. Die UART-Nachrichten in der Bridge sehen so aus, wenn man einen touchlink auslöst. Das Board blinkt dreimal, genauso wie es eine originale Lampe tut. [Log,Info,A_Bridge_Link,Found device 0: L=00:12:4B:00:06:37:A0:9F, rssi=-27] [Zdp,ReceivedDeviceAnnounce,S=0x0829.0,L=00:12:4B:00:06:37:A0:9F,142] [Zdp,ReceivedIeeeAddrRsp,3,S=0x0829.0,0,L=00:12:4B:00:06:37:A0:9F,S=0x08 29.0] [Link,Touchlink,success,S=0x0829,0xDFB2] Bei einer Original Philipslampe sieht es so aus: [Log,Info,A_Bridge_Link,Found device 0: L=00:17:88:01:01:22:89:8E, rssi=-48] [Zdp,ReceivedDeviceAnnounce,S=0x0009.0,L=00:17:88:01:01:22:89:8E,14] [Zdp,ReceivedIeeeAddrRsp,22,S=0x0009.0,0,L=00:17:88:01:01:22:89:8E,S=0x0 009.0] [Link,Touchlink,success,S=0x0009,0xDFB2] [Zdp,IeeeAddrReq,0,23] [Zdp,ReceivedIeeeAddrRsp,23,S=0x0009.0,0,L=00:17:88:01:01:22:89:8E,S=0x0 009.0] Wenn ich dann normal suche kommen diese Nachrichten. [Zdp,SendNodeDescReq,0,4] [Zdp,ReceivedNodeDescRsp,4,S=0x0829.0,0,2089,1,False,False,0,0,8,142,0,8 0,160,0,160,0] [Zgp,CommissioningEnter,0,0] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,5] [Zdp,SendActiveEndPointReq,0,6] [Zdp,ReceivedActiveEndPointRsp,6,S=0x0829.0,0,2089,3,12,11,13] [Zdp,SendSimpleDescReq,0,7] [Zdp,ReceivedSimpleDescRsp,7,S=0x0829.0,0,2089,8,12,260,512,2,0,0,0] [Zdp,SendSimpleDescReq,0,8] [Zdp,ReceivedSimpleDescRsp,8,S=0x0829.0,0,2089,22,11,260,258,2,0,7,0,3,4 ,5,6,8,768,0] [Zdp,SendSimpleDescReq,0,9] [Zdp,ReceivedSimpleDescRsp,9,S=0x0829.0,0,2089,12,13,49246,57694,2,0,1,4 096,1,4096] [Routing,SendMtoRR,0,0] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,10] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,11] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,12] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,13] [Routing,SendMtoRR,0,0] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,14] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,15] [Zdp,JoinPermitted,True] [Zdp,SendMgmtPermitJoiningReq,0,16] [Zdp,ReceivedMgmtLqiRsp,17,L=00:17:88:FF:F1:DD:19:8A.0,0,2,0,2,A5:12:43: 51:8C:22:92:FE,L=00:17:88:01:00:22:13:6E,S=0x0001.0,2,0,1,0,2,0,2,1,A5:1 2:43:51:8C:22:92:FE,L=00:12:4B:00:06:37:A0:9F,S=0x0829.0,1,2,3,0,2,0,255 ,152] [Zdp,JoinPermitted,False] [Zdp,SendMgmtLqiReq,0,17] [Zdp,SendNodeDescReq,0,17] [Zdp,SendMgmtLqiReq,0,18] [Zdp,ReceivedMgmtLqiRsp,18,S=0x0829.0,132,0,0,0] [Zdp,SendMgmtLqiReq,0,19] [Zdp,ReceivedMgmtLqiRsp,19,S=0x0829.0,132,0,0,0] [Routing,SendMtoRR,0,0] [Zdp,SendMgmtLqiReq,0,20] [Zdp,ReceivedMgmtLqiRsp,20,S=0x0829.0,132,0,0,0] [Zdp,SendNodeDescReq,0,21] [Zdp,SendNodeDescReq,0,22] Er findete also was, aber leider wird das Board nicht eingehängt. Hat da jemand einen Tip? Besten Dank Andi
Versuche mal wenn du den touchlink startest ....was du vermutlich mit der Rest api machst in der hue app nach einer neuen Lampe ... So hab ich die Bloom aus einem zweiten Starter Kit an meine bridge bekommen
@Fu: Genau das habe ich gemacht. Die Kommunikation in der bridge siehst du oben. Es dreht sich übrigens nicht darum, ein Philipsprodukt ins Netz zu bekommen sondern einen Empfänger, der mit der gleichen Hardware und (fast) gleichen Software ausgestattet ist wie die Philipslampen.
Hast du die Firmware drauf, bei der Philips an der DRM-Schraube gedreht hat?
yesitsme schrieb: > Hast du die Firmware drauf, bei der Philips an der DRM-Schraube gedreht > hat? http://www.heise.de/newsticker/meldung/Philips-Hue-bleibt-offen-fuer-ZigBee-Light-Link-Produkte-3044848.html
Da hat philips doch schon zurück gerudert.... Ich hatte das gleich Problem wie Fu. Das auch das anlernen mit einer Lampe von Philips so nicht ging und diese nur mit der Kombination aus API + APP angelernt werden konnte. Ich hab gesehen das man die Bridges nun für ziemlich schmales Geld auf ebay bekommt. Wäre da nicht eine eigene Firmware was? Wäre es denkbar mit einem Pi (oder ähnlichem) und einem CC2530 eine eigene Lösung für die Bridge umzuseten und einfach die Lampen daran anzulernen? Bliebe bei mir nur noch das Problem mit dem Living Whites...
@yesitsme: Das Thema kenne ich. Auf meiner Bridge ist die "alte" 1.11 drauf. Daher sollte das Problem bzgl. Ausschluss von Fremdfabrikaten kein Thema sein. @Martin P....... Die Frage war eigentlich: "hat es jemand geschafft einen CC2530 von TI, der in den Philips living color Produkten verbaut ist, ins Hue-Netz zu bringen?" Wenn du die Bridge selbst programmieren willst, musst du einen STM32 und einen CC2530 programmieren. Hast Erfahrung mit der Z-Stacksoftware? Wäre auch eine Lösung, aber deutlich komplizierter. Ist aber offtopic! Gruß Andi
