1 | '----------------------------------------------------------------------------
2 | 'WAVEPLAYER PLAYWAVEFILE
3 | '----------------------------------------------------------------------------
4 | Sub PlayWaveFile(WP_FILENAME as string)
5 |
6 | open WP_FILENAME For Binary As #SD_FF
7 |
8 | WP_lx = _XTAL / WP_SampleRate ' CPU Speed / SampleRate of wave file
9 | WP_lx = WP_lx - 1
10 | Compare1a = WP_lx
11 |
12 | WP_lx = 2 : seek #10 , WP_lx
13 |
14 | ''' start loading buffers
15 | get #SD_FF , WP_BUF_A(1) , , WP_BUFSIZE ' preload buffer A
16 | WP_A_BUF_STATUS = WP_BUFFULL ' mark buffer A as full
17 | get #SD_FF , WP_BUF_B(1) , , WP_BUFSIZE ' preload buffer B
18 | WP_B_Buf_Status = WP_BUFFULL ' mark buffer B as full
19 | WP_ActiveBuffer = WP_BUFA ' start with buf 0
20 | WP_BUFPos = 0 ' Reset the buffer possition
21 |
22 | '======[ start playing file!!! ]============================
23 | 'Start Timer1
24 | 'Start Timer2
25 | 'Enable Compare1a
26 | 'DDRD.6 = 1 : DDRD.7 = 1
27 | 'PORTD.6 = 1 : PORTD.7 = 1
28 |
29 | ''' Watch the two buffers and fill them up when ether is empty
30 | while Eof(#SD_FF) = 0
31 | if WP_A_BUF_STATUS = WP_BUFEMPTY then
32 | get #SD_FF , WP_BUF_A(1) , , WP_BUFSIZE
33 | WP_A_BUF_STATUS = WP_BUFFULL
34 | FILENEXT2 = FILENEXT2 + 250
35 | elseif WP_B_Buf_Status = WP_BUFEMPTY then
36 | get #SD_FF , WP_BUF_B(1) , , WP_BUFSIZE
37 | WP_B_Buf_Status = WP_BUFFULL
38 | FILENEXT2 = FILENEXT2 + 250
39 | else
40 | ' Both buffers are full here so this would be a good place to
41 | ' do some other stuff if needed. DON'T TAKE TOO LONG THOUGH! ;)
42 | 'if P_STATUS = 0 then
43 | ' Start Timer1
44 | ' Start Timer2
45 | ' Enable Compare1a
46 | ' P_STATUS = 1
47 | ' PORTD.6 = 0
48 | 'end if
49 | P_STATUS = 1
50 | if FILENEXT2 >= FILENEXT1 then : LBLL = 1 : SIGNAL_OUT = 1 : end if
51 | end if
52 | wend
53 | 'DDRD.6 = 0 : DDRD.7 = 0
54 | 'PORTD.6 = 0 : PORTD.7 = 0
55 | P_STATUS = 0
56 | PWM2A = 128
57 | PWM2B = 128
58 | 'Disable Compare1a
59 | 'Stop Timer1
60 | 'Stop Timer2
61 | close #SD_FF
62 |
63 | End Sub
64 |
65 |
66 | '----------------------------------------------------------------------------
67 | 'WAVEPLAYER WP_PLAY_ISR
68 | '----------------------------------------------------------------------------
69 | WP_Play_isr:
70 | if P_STATUS = 1 then
71 | if WP_ActiveBuffer = WP_BUFA then ' buffer A
72 | incr WP_BUFPos ' incrment to next byte
73 | Pwm2a = WP_BUF_A(WP_BUFPos) ' load sample into pwm2a
74 | Pwm2b = WP_BUF_A(WP_BUFPos) ' load same sample if mono
75 | if WP_BUFPos = WP_BUFSIZE then ' hit end of buffer A
76 | WP_BUFPos = 0 ' reset buffer pos to 0
77 | WP_ActiveBuffer = WP_BUFB ' Set active buffer to B
78 | WP_A_BUF_STATUS = WP_BUFEMPTY ' set buffer status empty
79 | end if
80 | else ' buffer B
81 | incr WP_BUFPos ' incrment to next byte
82 | Pwm2a = WP_BUF_B(WP_BUFPos) ' load sample into pwm2a
83 | Pwm2b = WP_BUF_B(WP_BUFPos) ' load same sample if mono
84 | if WP_BUFPos = WP_BUFSIZE then ' hit end of buffer A
85 | WP_BUFPos = 0 ' reset buffer pos to 0
86 | WP_ActiveBuffer = WP_BUFA ' Set active buffer to B
87 | WP_B_Buf_Status = WP_BUFEMPTY ' set buffer status empty
88 | end if
89 | end if
90 | end if
91 | Return
