1 | #include <stdint.h>
2 |
3 | #define IP_adress PORTF
4 | #define ON 1
5 | #define OFF 0
6 | #define TLI4970 1
7 | #define LTC6804 0
8 | #define IDmaster 255
9 |
10 | // LCD module connections
11 | sbit LCD_RS at LATD4_bit;
12 | sbit LCD_EN at LATD6_bit;
13 | sbit LCD_D4 at LATD0_bit;
14 | sbit LCD_D5 at LATD1_bit;
15 | sbit LCD_D6 at LATD2_bit;
16 | sbit LCD_D7 at LATD3_bit;
17 |
18 | sbit LCD_RS_Direction at TRISD4_bit;
19 | sbit LCD_EN_Direction at TRISD6_bit;
20 | sbit LCD_D4_Direction at TRISD0_bit;
21 | sbit LCD_D5_Direction at TRISD1_bit;
22 | sbit LCD_D6_Direction at TRISD2_bit;
23 | sbit LCD_D7_Direction at TRISD3_bit;
24 | // End LCD module connections
25 |
26 | // ECAN module connections
27 | // End ECAN module connections
28 |
29 |
30 | /*******************************************************************************
31 | Variables
32 | *******************************************************************************/
33 | unsigned int IDmodule=0, IDmodule2 = 9;
34 | short int lcd_line[4][20];
35 |
36 | //----------------- CAN --------------------------------------------------
37 | unsigned unsigned short Can_Init_Flags, Can_Send_Flags, Can_Rcv_Flags; // can flags
38 | unsigned unsigned short Rx_Data_Len, dt, cell_count[2]; // received data length in bytes
39 | unsigned short Rx_Data[8], Tx_Data[8], RxTx_Data[8]; // can rx/tx data 8-bytes buffer
40 | unsigned short Msg_Rcvd = 0;
41 | unsigned int Rx_ID, Tx_ID, i, j, h, k, adc_rd;
42 | int pin_mux[13] = {0x0E, 0x0C, 0x0A, 0x08, 0x06, 0x04, 0x02, 0x00, 0x1C, 0x1E, 0x18, 0x16, 0x1A};
43 | unsigned int temp_values[2][13]; //Line1 cell voltage & curren, line2 temperature
44 |
45 | const unsigned short SJW = 1;
46 | const unsigned short BRP = 1;
47 | const unsigned short Propagation = 1;
48 | const unsigned short Phase1 = 4;
49 | const unsigned short Phase2 = 3;
50 |
51 |
52 | void init() {
53 | ANCON0 = 0x01; // RA0 as analog input
54 | ANCON1 = 0x00; // No analog inputs
55 |
56 | TRISA = 0x01; // set PORTA as output except RA0
57 | LATA = 0x00; // clear PORTA
58 |
59 | TRISB = 0x00; // set PORTB as output
60 | LATB = 0x00; // clear PORTA
61 |
62 | TRISC = 0x08; // RC3(SCK) & RC4(SDI) as input, others as output
63 | PORTC = 0x00; // clear PORTC
64 |
65 | TRISD = 0x00; // set PORTD as output
66 | TRISE = 16; // RE4(CAN RX) as input, others as output (CAN TX)
67 | WPUB = 0x00; // Disable all PORTB pull-up resistors
68 | TRISF = 0xFF; // set PORTF as input
69 |
70 | Delay_ms(1000);
71 | IDmodule = (IP_adress & 0xff);
72 | Lcd_Cmd(_LCD_CLEAR); // Clear display
73 | Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
74 | sprintf(lcd_line[0], "ID Module = %u v01", IDmodule); //The pec_error variable is simply set negative if any PEC errors
75 | Lcd_Out(1,1, lcd_line[0]);
76 | Delay_ms(4000);
77 | }
78 | //------------------------------------------------------------------------------
79 | // CAN Configuration
80 | //------------------------------------------------------------------------------
81 | void configureCAN(void)
82 | {
83 | Can_Init_Flags = 0; //
84 | Can_Send_Flags = 0; // clear flags
85 | Can_Rcv_Flags = 0; //
86 |
87 | Can_Send_Flags = _CAN_TX_PRIORITY_0 & // form value to be used
88 | _CAN_TX_STD_FRAME & // with CANWrite
89 | _CAN_TX_NO_RTR_FRAME;
90 |
91 | Can_Init_Flags = _CAN_CONFIG_SAMPLE_THRICE & // form value to be used
92 | _CAN_CONFIG_PHSEG2_PRG_ON & // with CANInit
93 | _CAN_CONFIG_STD_MSG &
94 | _CAN_CONFIG_DBL_BUFFER_ON &
95 | _CAN_CONFIG_VALID_STD_MSG &
96 | _CAN_CONFIG_LINE_FILTER_ON;
97 |
98 | CANInitialize(SJW, BRP, Phase1, Phase2, Propagation, Can_Init_Flags); // initialize external CAN module
99 |
100 | CANSetOperationMode(_CAN_MODE_CONFIG,0xFF); // set CONFIGURATION mode (blocking call)
101 |
102 | CANSetMask(_CAN_MASK_B1,0x0180,_CAN_CONFIG_STD_MSG); // set all mask1 bits to ones
103 | CANSetMask(_CAN_MASK_B2,0xFFFF,_CAN_CONFIG_STD_MSG); // set all bits to 1
104 |
105 | CANSetFilter(_CAN_FILTER_B1_F1, 0x0080,_CAN_CONFIG_STD_MSG); // receive messages with bit 9 = 0 and 8 = 1
106 | CANSetFilter(_CAN_FILTER_B1_F2, 0x0180,_CAN_CONFIG_STD_MSG); // receive messages with bit 9 = 1 and 8 = 1
107 |
108 | // CANSetFilter(_CAN_FILTER_B2_F1, 0x0000,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 0
109 | // CANSetFilter(_CAN_FILTER_B2_F2, 0x0001,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 1
110 | CANSetFilter(_CAN_FILTER_B2_F3, IDmodule2,_CAN_CONFIG_STD_MSG); // receive messages with identifier = 2
111 | CANSetFilter(_CAN_FILTER_B2_F4, IDmodule,_CAN_CONFIG_STD_MSG); // receive messages with identifier = IDmodule
112 |
113 | CANSetOperationMode(_CAN_MODE_NORMAL,0xFF); // set NORMAL mode
114 | }
115 |
116 |
117 | void main()
118 | {
119 | init(); // Perform main initialization
120 | ADC_Init(); // Initialize ADC module with default settings
121 | configureCAN(); // Configure CAN module
122 | Lcd_Init();
123 |
124 | while(1)
125 | {
126 | PORTC = 0x1;
127 | Delay_ms(500);
128 | PORTC = 0x0;
129 | Delay_ms (500);
130 |
131 |
132 | for(k=0;k<4;k++)
133 | {
134 | PORTB = pin_mux[k]; // set MUX/I0
135 | Delay_ms(1);
136 | adc_rd = ADC_Read(0); // get ADC value from 0st channel
137 | temp_values[1][k] = adc_rd;
138 | sprintf(lcd_line[k], "Voltage = %u V", temp_values[1][k]); // Trim the string from leading spaces
139 | Lcd_Out(k+1,1, lcd_line[k]);
140 | PORTC = 0x2;
141 | Delay_ms(500);
142 | PORTC = 0x1;
143 | }
144 | }
145 | }
