1 | entity Main is
2 | Port (
3 | SYS_clk : in STD_LOGIC;
4 | Reset : in STD_LOGIC;
5 | -- UART_Control
6 | UART_SEND_data : out STD_LOGIC_VECTOR (63 downto 0); -- zu sendende Daten
7 | UART_SEND_data_en : out STD_LOGIC; -- 1 -> Send_Data sollen gesendet werden
8 | UART_SEND_ready : in std_logic; -- 1 -> bereit zum senden
9 | -- QSPI-BUFF
10 | BUFF_RD_sampled_data : out STD_LOGIC;
11 | BUFF_SAMPLED_data_out : in STD_LOGIC_VECTOR(63 downto 0);
12 | BUFF_FIFO_empty : in STD_LOGIC;
13 | -- DDR_2_RAM
14 | DDR_R_w : out STD_LOGIC;
15 | DDR_R_w_en : out STD_LOGIC;
16 | DDR_Address : out STD_LOGIC_VECTOR(23 downto 0);
17 | DDR_DDR2_rdy : in STD_LOGIC;
18 | DDR_DATA_out : in STD_LOGIC_VECTOR(63 downto 0);
19 | DDR_DATA_in : out STD_LOGIC_VECTOR(63 downto 0);
20 | DDR_empty : out STD_LOGIC;
21 |
22 | deb_ADDR_rd : out STD_LOGIC_VECTOR(23 downto 0);
23 | deb_ADDR_wr : out STD_LOGIC_VECTOR(23 downto 0);
24 | deb_ueberlauf: out STD_LOGIC;
25 | deb_WR_err : out STD_LOGIC;
26 | deb_RD_err : out STD_LOGIC;
27 | deb_state : out STD_LOGIC_VECTOR(2 downto 0)
28 | );
29 | end Main;
30 |
31 | architecture Behavioral of Main is
32 |
33 | signal ADDR_rd : STD_LOGIC_VECTOR(23 downto 0);
34 | signal ADDR_wr : STD_LOGIC_VECTOR(23 downto 0);
35 | signal ueberlauf: STD_LOGIC;
36 | signal WR_err : STD_LOGIC;
37 | signal RD_err : STD_LOGIC;
38 | type statetype is (get_data, write_data_ddr, write_data_ddr_wait, read_data, read_data_wait, transmit_data, idle);
39 | signal state : statetype;
40 |
41 | begin
42 | P1: Process(SYS_clk)
43 | begin
44 |
45 |
46 | if rising_edge(SYS_clk) then
47 |
48 | deb_ADDR_rd <= ADDR_rd; --: STD_LOGIC_VECTOR(23 downto 0);
49 | deb_ADDR_wr <= ADDR_wr; --: STD_LOGIC_VECTOR(23 downto 0);
50 | deb_ueberlauf <= ueberlauf; --: STD_LOGIC;
51 | deb_WR_err <= WR_err; --: STD_LOGIC;
52 | deb_RD_err <= RD_err; --: STD_LOGIC;
53 |
54 | if Reset = '1' then -- Reset Aktiv
55 | UART_SEND_data_en <= '0';
56 | BUFF_RD_sampled_data <= '0';
57 | DDR_R_w <= '0';
58 | DDR_R_w_en <= '0';
59 | WR_err <= '0';
60 | RD_err <= '0';
61 | DDR_Address <= x"000000";
62 | DDR_DATA_in <= x"0000000000000000";
63 | UART_SEND_data <= x"0000000000000000";
64 | ADDR_rd <= x"000000";
65 | ADDR_wr <= x"000001";
66 | ueberlauf <= '0';
67 | DDR_empty <= '1';
68 | state <= idle;
69 | else -- Reset inaktiv
70 | if state = idle then -- Wenn IDLE
71 | deb_state <="000";
72 | UART_SEND_data_en <= '0';
73 | if BUFF_FIFO_empty = '0' then -- Wenn fifo != empty --> Lesen
74 | BUFF_RD_sampled_data <= '1';
75 | state <= get_data;
76 | end if;
77 | elsif state = get_data then -- Wenn daten von FIFO gelesen
78 | deb_state <="001";
79 | BUFF_RD_sampled_data <= '0';
80 | DDR_DATA_in <= BUFF_SAMPLED_data_out;-- Daten puffern
81 | state <= write_data_ddr;
82 | elsif state = write_data_ddr then -- Daten in DDR schreiben
83 | deb_state <="010";
84 | if DDR_DDR2_rdy = '1' then -- Wenn DDR bereit --> Schreiben
85 | DDR_Address <= ADDR_wr;
86 | if ADDR_wr > ADDR_rd and ueberlauf = '0' then
87 | DDR_R_w <= '0';
88 | DDR_R_w_en <= '1';
89 | if ADDR_wr < x"ffffff" then
90 | --Wenn Maximal Addresse erreicht --> an addresse 0 beginnen, falls bereits ausgelesen
91 | ADDR_wr <= ADDR_wr + 1;
92 | state <= write_data_ddr_wait;
93 | else
94 | state <= write_data_ddr_wait;
95 | ADDR_wr <= x"000000";
96 | ueberlauf <= '1'; -- Setzen überlauf hat stattgefunden
97 | end if;
98 | elsif ADDR_wr < ADDR_rd and ueberlauf = '1' then
99 | DDR_R_w <= '0';
100 | DDR_R_w_en <= '1';
101 | state <= write_data_ddr_wait;
102 | ADDR_wr <= ADDR_wr + 1;
103 | else
104 | DDR_R_w <= '0';
105 | DDR_R_w_en <= '0';
106 | WR_err <= '1';
107 | end if;
108 | end if;
109 | elsif state = write_data_ddr_wait then
110 | deb_state <="011";
111 | DDR_R_w_en <= '0';
112 | state <= read_data;
113 | elsif state = read_data then --Daten geschrieben
114 | deb_state <="100";
115 | if UART_SEND_ready = '1' then -- Wenn FIFO bereit Daten zu senden
116 | if DDR_DDR2_rdy = '1' then -- Daten Lesen
117 | DDR_Address <= ADDR_rd;
118 | if ADDR_wr >= ADDR_rd and ueberlauf = '0' then
119 | DDR_R_w <= '1';
120 | DDR_R_w_en <= '1';
121 | ADDR_rd <= ADDR_rd + 1;
122 | state <= read_data_wait;
123 | DDR_empty <= '0';
124 | elsif ADDR_wr < ADDR_rd and ueberlauf = '1' then
125 | DDR_R_w <= '1';
126 | DDR_R_w_en <= '1';
127 | state <= read_data_wait;
128 | if ADDR_rd < x"ffffff" then
129 | ADDR_rd <= ADDR_rd + 1;
130 | else
131 | ueberlauf <= '0';
132 | ADDR_rd <= x"000000";
133 | end if;
134 | DDR_empty <= '0';
135 | else
136 | DDR_R_w <= '0';
137 | DDR_R_w_en <= '0';
138 | DDR_empty <= '1';
139 | state <= idle;
140 | end if;
141 | end if;
142 | else
143 | DDR_R_w <= '0';
144 | DDR_R_w_en <= '0';
145 | state <= idle;
146 | end if;
147 | elsif state = read_data_wait then
148 | deb_state <="101";
149 | DDR_R_w_en <= '0';
150 | DDR_R_w <= '0';
151 | state <= transmit_data;
152 | elsif state = transmit_data then
153 | deb_state <="110";
154 | DDR_R_w <= '0';
155 | DDR_R_w_en <= '0';
156 | if DDR_DDR2_rdy = '1' then
157 | UART_SEND_data <= DDR_DATA_out;
158 | UART_SEND_data_en <= '1';
159 | state <= idle;
160 | end if;
161 | end if;
162 | end if;
163 | end if;
164 | end Process;
165 | end Behavioral;
