Forum: Mikrocontroller und Digitale Elektronik Noch ein STM32F303 USART3 geht nicht
von Markus G. (the_grue)
Servus,
Im Forum gibt's ja schon ein paar "Mein USART geht nicht"-Posts - leider
hat mir keiner geholfen. In denen, die ich gefunden habe lag's z.B. am
fehlenden RCC_APB2Periph_AFIO oder falsch eingestellten alternate
functions GPIO_Mode_AF_PP. Beides kennt meine Version der st-lib nicht.
Ich finde meinen Fehler einfach nicht. Eigendlich sollte PB10 wackeln,
tut er aber nicht:
  INTERRUPTS_OFF();
  //Define all of the periphals we use.
  uint32_t apb1Peripherals = ( RCC_APB1Periph_PWR  |
                               RCC_APB1Periph_USART3
  uint32_t apb2Peripherals = ( 0 );
  uint32_t ahbPeripherals = ( RCC_AHBPeriph_GPIOA |
                              RCC_AHBPeriph_GPIOB |
                              RCC_AHBPeriph_GPIOC);
  //Enable clocks to all of our peripherals.
  RCC_APB1PeriphClockCmd(apb1Peripherals, ENABLE);
  RCC_APB2PeriphClockCmd(apb2Peripherals, ENABLE);
  RCC_AHBPeriphClockCmd(ahbPeripherals, ENABLE );
  //Allow access to BKP Domain
  PWR_BackupAccessCmd(ENABLE);
  //De-initialize our peripherals here so each module only has to
  //worry about initializing them as needed.  DeInit works by toggling
  //PeriphResetCmd enable/disable.
23
  EXTI_DeInit();
24
25
  GPIO_DeInit(GPIOA);
26
  GPIO_DeInit(GPIOB);
27
  GPIO_DeInit(GPIOC);
28
  GPIO_DeInit(GPIOD);
29
30
  USART_DeInit(USART3);
31
32
  //Configure USART TX GPIO as alternate function push-pull
33
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
34
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10;
35
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
36
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
37
  GPIO_Init(GPIOB, &GPIO_InitStructure);
38
  GPIO_PinAFConfig(GPIOB, GPIO_Pin_10, GPIO_AF_7);
39
40
  //Configure USART RX GPIO as input floating
41
42
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
43
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
44
45
  GPIO_PinAFConfig(GPIOB, GPIO_Pin_11, GPIO_AF_7);
46
47
  //Configure USART (but without enabling it)
48
  USART_InitStructure.USART_BaudRate = 9600;
49
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
50
  USART_InitStructure.USART_Parity = USART_Parity_No;
51
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
52
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
53
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
54
  USART_Init(USART3, &USART_InitStructure);
55
56
  USART_Cmd(USART3, ENABLE);
57
58
  INTERRUPTS_ON();  // Safe to enable interrupts at this point
59
60
  while( true )
61
62
      while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET);
63
      USART_SendData(USART3, 0xAA);
64
65
      USART_SendData(USART3, 0x55);
66
Könnt Ihr mir bitte von der Leitung helfen auf der ich stehe?
von Der (überall) Ausländer (Gast)
Zeile 42, in Zeile 42 schauen, da ist die Lösung
Egal ob das Scherz oder Hilfe ist, beides verstehe ich nicht :(
Zeile 42 wäre:
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;       // 42
Da wird RxD auf PB11 konfiguriert - es kommt aber bei TxD nix raus...
(Die Anspielung auf THGTTG verstünde ich wohl, wäre nur nicht
hilfreich.)
nicht 10 und 11 bei AF7?
Ich muss sagen, das ich mit den F3 nix mache, sondern nur mit den F4. Da
sieht meine Senderoutine so aus:
#define USART USART3
void uart_put(char data){
 while (USART_GetFlagStatus(USART, USART_FLAG_TC) == RESET) {};
 USART_SendData(USART, (uint8_t) data);
Ist
 über jeden Verdacht erhaben? Also ist die AF7 Schiene auch wirklich die
richtige für USART3 und ist GPIO_Pin_11 auch wirklich die Source? Bei
mir heissen die Dinger z.B. 'GPIO_PinSource2'?
Ich poste (nur zum Vegleichen) einfach meine USART Init:
// aus setup.h
/* USART Definitions */
#define USART_TX_PIN       GPIO_Pin_2
#define USART_RX_PIN      GPIO_Pin_3
#define USART_TX_SOURCE      GPIO_PinSource2
#define USART_RX_SOURCE      GPIO_PinSource3
#define USART          USART2
#define USART_PORT        GPIOA
// aus main.c
void USARTInit(uint32_t baudrate) {
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
// Clock Enable of usart pins
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2, ENABLE);
RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2, DISABLE);
GPIO_PinAFConfig(USART_PORT, USART_RX_SOURCE, GPIO_AF_USART2);
GPIO_PinAFConfig(USART_PORT, USART_TX_SOURCE, GPIO_AF_USART2);
GPIO_InitStructure.GPIO_Pin = USART_TX_PIN;
23
24
25
26
27
GPIO_Init(USART_PORT, &GPIO_InitStructure);
28
GPIO_InitStructure.GPIO_Pin =  USART_RX_PIN;
29
30
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
31
GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
32
33
/* Configure USART)
34
35
36
USART_DeInit(USART);
37
USART_StructInit(&USART_InitStructure);
38
USART_InitStructure.USART_BaudRate = baudrate;
39
40
41
42
USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
43
44
USART_Init(USART,&USART_InitStructure);
45
/* Enable USART */
46
USART_Cmd(USART, ENABLE);
47
48
Den Formalkrams mache ich nur, damit ich das schnell mal auf andere Pins
umbiegen kann.
Matthias S. schrieb:
> Bei
Bei mir jetzt auch, seitdem geht's :)
Vielen Dank!
Markus
von fibonacci de gogolores (Gast)
Unglaublich !!!
