1 |
2 |
3 | #include <SPI.h>
4 | #include <SD.h>
5 |
6 | #include <Wire.h>
7 | #include <Adafruit_Sensor.h>
8 | #include <Adafruit_ADXL345_U.h>
9 |
10 | #include <Adafruit_GPS.h>
11 | #include <SoftwareSerial.h>
12 |
13 | Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
14 |
15 | // If you're using a GPS module:
16 | // Connect the GPS Power pin to 5V
17 | // Connect the GPS Ground pin to ground
18 | // If using software serial (sketch example default):
19 | // Connect the GPS TX (transmit) pin to Digital 3
20 | // Connect the GPS RX (receive) pin to Digital 2
21 | // If using hardware serial (e.g. Arduino Mega):
22 | // Connect the GPS TX (transmit) pin to Arduino RX1, RX2 or RX3
23 | // Connect the GPS RX (receive) pin to matching TX1, TX2 or TX3
24 |
25 | // If you're using the Adafruit GPS shield, change
26 | // SoftwareSerial mySerial(3, 2); -> SoftwareSerial mySerial(8, 7);
27 | // and make sure the switch is set to SoftSerial
28 |
29 | // If using software serial, keep this line enabled
30 | // (you can change the pin numbers to match your wiring):
31 | SoftwareSerial mySerial(8, 7);
32 |
33 | // If using hardware serial (e.g. Arduino Mega), comment out the
34 | // above SoftwareSerial line, and enable this line instead
35 | // (you can change the Serial number to match your wiring):
36 |
37 | //HardwareSerial mySerial = Serial1;
38 |
39 | const int chipSelect = 10;
40 | File dataFile;
41 |
42 | Adafruit_GPS GPS(&mySerial);
43 |
44 |
45 | // Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
46 | // Set to 'true' if you want to debug and listen to the raw GPS sentences.
47 | #define GPSECHO true
48 |
49 | // this keeps track of whether we're using the interrupt
50 | // off by default!
51 | boolean usingInterrupt = false;
52 | void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
53 |
54 | void setup()
55 | {
56 |
57 | // connect at 115200 so we can read the GPS fast enough and echo without dropping chars
58 | // also spit it out
59 | Serial.begin(115200);
60 |
61 |
62 |
63 |
64 |
65 | // SD CARD
66 |
67 | // Open serial communications and wait for port to open:
68 | //Serial.begin(9600);
69 | while (!Serial) {
70 | ; // wait for serial port to connect. Needed for Leonardo only
71 | }
72 | // SD CARD
73 | Serial.print("Initializing SD card...");
74 | // make sure that the default chip select pin is set to
75 | // output, even if you don't use it:
76 | pinMode(SS, OUTPUT);
77 |
78 | // see if the card is present and can be initialized:
79 | if (!SD.begin(chipSelect)) {
80 | Serial.println("Card failed, or not present");
81 | // don't do anything more:
82 | while (1) ;
83 | }
84 | Serial.println("card initialized.");
85 |
86 | // Open up the file we're going to log to!
87 | dataFile = SD.open("datalog.txt", FILE_WRITE);
88 | if (! dataFile) {
89 | Serial.println("error opening datalog.txt");
90 | // Wait forever since we cant write data
91 | while (1) ;
92 | }
93 |
94 |
95 |
96 |
97 | // BESCHLEUNIGUNGSSENSOR
98 |
99 | /* Initialise the sensor */
100 | if (!accel.begin())
101 | {
102 | /* There was a problem detecting the ADXL345 ... check your connections */
103 | Serial.println("Ooops, no ADXL345 detected ... Check your wiring!");
104 | while (1);
105 | }
106 |
107 |
108 |
109 |
110 | // GPS
111 | // 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
112 | GPS.begin(9600);
113 |
114 | // uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
115 | GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
116 | // uncomment this line to turn on only the "minimum recommended" data
117 | // GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
118 | // For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
119 | // the parser doesn't care about other sentences at this time
120 |
121 | // Set the update rate
122 | GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
123 | // For the parsing code to work nicely and have time to sort thru the data, and
124 | // print it out we don't suggest using anything higher than 1 Hz
125 |
126 | // Request updates on antenna status, comment out to keep quiet
127 | GPS.sendCommand(PGCMD_ANTENNA);
128 |
129 | // the nice thing about this code is you can have a timer0 interrupt go off
130 | // every 1 millisecond, and read data from the GPS for you. that makes the
131 | // loop code a heck of a lot easier!
132 | useInterrupt(true);
133 |
134 | delay(1000);
135 | // Ask for firmware version
136 | mySerial.println(PMTK_Q_RELEASE);
137 | }
138 |
139 |
140 | // Interrupt is called once a millisecond, looks for any new GPS data, and stores it
141 | SIGNAL(TIMER0_COMPA_vect) {
142 | char c = GPS.read();
143 | // if you want to debug, this is a good time to do it!
144 | #ifdef UDR0
145 | if (GPSECHO)
146 | if (c) UDR0 = c;
147 | // writing direct to UDR0 is much much faster than Serial.print
148 | // but only one character can be written at a time.
149 | #endif
150 | }
151 |
152 | void useInterrupt(boolean v) {
153 | if (v) {
154 | // Timer0 is already used for millis() - we'll just interrupt somewhere
155 | // in the middle and call the "Compare A" function above
156 | OCR0A = 0xAF;
157 | TIMSK0 |= _BV(OCIE0A);
158 | usingInterrupt = true;
159 | } else {
160 | // do not call the interrupt function COMPA anymore
161 | TIMSK0 &= ~_BV(OCIE0A);
162 | usingInterrupt = false;
163 | }
164 | }
165 |
166 | uint32_t timer = millis();
167 | void loop() // run over and over again
168 | {
169 |
170 | /* Get a new sensor event */
171 | sensors_event_t event;
172 | accel.getEvent(&event);
173 |
174 |
175 | // SD CARD - ABSPEICHERN
176 |
177 | // make a string for assembling the data to log:
178 |
179 | String dataString = "";
180 | int x =(event.acceleration.x);
181 | int y =(event.acceleration.y);
182 | int z =(event.acceleration.z);
183 |
184 | // dataString += String(x, y, z); funktioniert nicht!
185 |
186 |
187 |
188 |
189 | dataFile.println(dataString);
190 |
191 | // print to the serial port too:
192 | Serial.println(dataString);
193 |
194 | // The following line will 'save' the file to the SD card after every
195 | // line of data - this will use more power and slow down how much data
196 | // you can read but it's safer!
197 | // If you want to speed up the system, remove the call to flush() and it
198 | // will save the file only every 512 bytes - every time a sector on the
199 | // SD card is filled with data.
200 | dataFile.flush();
201 |
202 |
203 |
204 | // BESCHLEUNIGUNGSSENSOR
205 |
206 | // if a sentence is received, we can check the checksum, parse it...
207 | if (GPS.newNMEAreceived()) {
208 |
209 | // if (GPS.fix) {
210 |
211 | /* Display the results (acceleration is measured in m/s^2)
212 | */
213 | Serial.print(event.acceleration.x); Serial.print("; ");
214 | Serial.print(event.acceleration.y); Serial.print("; ");
215 | Serial.print(event.acceleration.z); Serial.print("; "); Serial.println(" ");
216 | delay(1000);
217 |
218 |
219 |
220 | }
221 | }
