Forum: Compiler & IDEs STM32 disabling interrupts global in GCC how
von mehmet karakaya (Gast)
hello dear forum,
I m doing a project with STM32F103 uC
I have a critical code where I want this code not be interrupted by any
interupt - and after this critical code is executed I want enable
interupts again
however I want that STM32 doesnot "oversee" any interrupt which is
occured during this "disabled" time
It should execute any pending ISR whenever I enable global interrupt
again
i.e this ISR should not be left unexecuted
how can I do this in GCC ?
thank you
von Nop (Gast)
I'd go for this one (should already be defined in the CMSIS header
files):
/*disable all interrupts*/
static inline __attribute__((always_inline)) void __DISABLE_IRQ(void)
{__asm volatile("CPSID i");}
/*enable all interrupts*/
static inline __attribute__((always_inline)) void __ENABLE_IRQ(void)
{__asm volatile("CPSIE i");}
See also the ARM documentation in CPSIE:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dai0321a/BIHBFEIB.html
von Nop (Gast)
Note that "CPSID i" is called "disable interrupts", and the SysTick is
an exception, not an interrupt. However, "CPSID i" turns also off the
SysTick exception.
You can also use "CPSID f" instead of "CPSID i", to include fault
handlers:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0497a/BABHBAAB.html
von (prx) A. K. (prx)
Interrupts are sticky, so disabling core interrupts just delays
execution of a handler. It does not get lost unless interrupts are
disabled long enough, to let a second interrupt of the same kind happen
meanwhile.
von Peter D. (peda)
Every interrupt source has it's pending flag. And whenever this flag was
set by an event, the CPU execute the interrupt, after enabled. If you
enable the interrupt after 10 years, the interrupt was still executed at
this time.
von W.S. (Gast)
> interupt
At first (very first!) try to avoid such kind of code. There is always a
option to solve a problem in a different way.
Then consider to use the Keil compiler, because the Keil is capable to
use SVC's (supervisor calls) - but the GCC is not capable to do so. If
you insist to use the GCC, then you need to write a wrapper for SVC's in
assembler.
The purpose of the SVC is, that the SVC can be done in Software and the
called code runs not in user mode, but instead in supervisor mode. This
may be priorized properly, so you have exactly what you want - without
using such "disable_int" and so on.
W.S.
von Dr. Sommer (Gast)
W.S. schrieb:
> If you insist to use the GCC, then you need to write a wrapper for
> SVC's in assembler.
It's surprising to see you recommending to avoid Assembly code ?
von Nop (Gast)
Which makes sense if you are using an RTOS. But if there is an RTOS
anyway, it should provide easy means for code parts that must not be
interrupted. However, when going bare metal, I think there is no user
mode because all code runs as privileged.
There are a number of occasions where disabling interrupts makes sense.
When fumbling around with the core clock, for example. Or when writing
to the flash. Ok, it is ill-advised for synchronising data between
application and interrupts, that has a design smell.
In general, GCC has some advantages over Keil. No code size limit, and
GCC exists cross-platform so that you can develop, debug and test the
code e.g. on a host PC. When developing free software, Keil is out of
the game anyway because it would be self-defeating to require a non-free
tool to build free software.
von W.S. (Gast)
This is rather not the case. But I think, we do not need to have
arguments. Simply spoken the SVC rises the privilege to the programmed
level and when all other interrupt levels are tuned accordingly, then
our TO mehmet karakaya has the final solution. But he seems to be
absent...
W.S.
