1 | /**
2 | * StreamHTTPClient.ino
3 | *
4 | * Created on: 24.05.2015
5 | *
6 | */
7 |
8 | #include <Arduino.h>
9 |
10 | #include <ESP8266WiFi.h>
11 | #include <ESP8266WiFiMulti.h>
12 |
13 | #include <ESP8266HTTPClient.h>
14 |
15 | #define USE_SERIAL Serial
16 |
17 | ESP8266WiFiMulti WiFiMulti;
18 | uint8_t test;
19 | void setup() {
20 | pinMode(LED_BUILTIN, OUTPUT);
21 | USE_SERIAL.begin(115200);
22 | // USE_SERIAL.setDebugOutput(true);
23 |
24 | USE_SERIAL.println();
25 | USE_SERIAL.println();
26 | USE_SERIAL.println();
27 |
28 | for(uint8_t t = 4; t > 0; t--) {
29 | USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
30 | USE_SERIAL.flush();
31 | delay(1000);
32 | }
33 |
34 | WiFiMulti.addAP("***", "*****");
35 |
36 | }
37 |
38 | void loop() {
39 | // wait for WiFi connection
40 | if((WiFiMulti.run() == WL_CONNECTED)) {
41 |
42 | HTTPClient http;
43 |
44 | USE_SERIAL.print("[HTTP] begin...\n");
45 |
46 | // configure server and url
47 | http.begin("http://192.168.0.17/warp/anfrage.php/?id=151413");
48 | //http.begin("192.168.1.12", 80, "/test.html");
49 |
50 | USE_SERIAL.print("[HTTP] GET...\n");
51 | // start connection and send HTTP header
52 | int httpCode = http.GET();
53 | if(httpCode > 0) {
54 | // HTTP header has been send and Server response header has been handled
55 | USE_SERIAL.printf("[HTTP] GET... code: %d\n", httpCode);
56 |
57 | // file found at server
58 | if(httpCode == HTTP_CODE_OK) {
59 |
60 | // get lenght of document (is -1 when Server sends no Content-Length header)
61 | int len = http.getSize();
62 |
63 | // create buffer for read
64 | uint8_t buff[128] = { 0 };
65 |
66 | // get tcp stream
67 | WiFiClient * stream = http.getStreamPtr();
68 |
69 | // read all data from server
70 | while(http.connected() && (len > 0 || len == -1)) {
71 | // get available data size
72 | size_t size = stream->available();
73 |
74 | if(size) {
75 | // read up to 128 byte
76 | int c = stream->readBytes(buff, ((size > sizeof(buff)) ? sizeof(buff) : size));
77 |
78 | // write it to Serial
79 | USE_SERIAL.write(buff, c);
80 | test = buff;
81 |
82 |
83 | if(len > 0) {
84 | len -= c;
85 | }
86 | }
87 | delay(1);
88 | }
89 | if(test) == "1") {
90 | USE_SERIAL.write("ja");
91 | delay(1000); // Wait for a second
92 | digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
93 | delay(2000);
94 | digitalWrite(LED_BUILTIN, LOW);
95 | delay(1000); // Wait for a second
96 | digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
97 | delay(2000);
98 | digitalWrite(LED_BUILTIN, LOW);
99 | delay(1000); // Wait for a second
100 | digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
101 | delay(2000);
102 | digitalWrite(LED_BUILTIN, LOW);
103 | delay(1000); // Wait for a second
104 | digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
105 | delay(2000);
106 | digitalWrite(LED_BUILTIN, LOW);
107 | delay(1000); // Wait for a second
108 | digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
109 | delay(2000);
110 | digitalWrite(LED_BUILTIN, LOW);
111 | } else {
112 | digitalWrite(LED_BUILTIN, HIGH);
113 | USE_SERIAL.write("nein");
114 | }
115 | USE_SERIAL.println();
116 | USE_SERIAL.print("[HTTP] connection closed or file end.\n");
117 |
118 | }
119 | } else {
120 | USE_SERIAL.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
121 | }
122 |
123 | http.end();
124 | }
125 |
126 | delay(10000);
127 | }
