1 | #include "msp430g2553.h" // device specific header
2 | #include "TI_USCI_I2C_master.h"
3 |
4 | signed char byteCtr;
5 | unsigned char *TI_receive_field;
6 | unsigned char *TI_transmit_field;
7 |
8 | void TI_USCI_I2C_receiveinit(unsigned char slave_address, unsigned char prescale)
9 | {
10 | P1SEL |= SDA_PIN + SCL_PIN; // Assign I2C pins to USCI_B0 P3???
11 | UCB0CTL1 = UCSWRST; // Enable SW reset
12 | UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
13 | UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
14 | UCB0BR0 = prescale; // set prescaler
15 | UCB0BR1 = 0;
16 | UCB0I2CSA = slave_address; // set slave address
17 | UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
18 | UCB0I2CIE = UCNACKIE;
19 | IE2 = UCB0RXIE; // Enable RX interrupt
20 | }
21 |
22 | void TI_USCI_I2C_transmitinit(unsigned char slave_address, unsigned char prescale)
23 | {
24 | P1SEL |= SDA_PIN + SCL_PIN; // Assign I2C pins to USCI_B0 P3???
25 | UCB0CTL1 = UCSWRST; // Enable SW reset
26 | UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode
27 | UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
28 | UCB0BR0 = prescale; // set prescaler
29 | UCB0BR1 = 0;
30 | UCB0I2CSA = slave_address; // Set slave address
31 | UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation
32 | UCB0I2CIE = UCNACKIE;
33 | IE2 = UCB0TXIE; // Enable TX ready interrupt
34 | }
35 |
36 | void TI_USCI_I2C_receive(unsigned char byteCount, unsigned char *field)
37 | {
38 | TI_receive_field = field;
39 | if ( byteCount == 1 )
40 | {
41 | byteCtr = 0 ;
42 | __disable_interrupt();
43 | UCB0CTL1 |= UCTXSTT; // I2C start condition
44 | while (UCB0CTL1 & UCTXSTT); // Start condition sent?
45 | UCB0CTL1 |= UCTXSTP; // I2C stop condition
46 | __enable_interrupt();
47 | }
48 | else if ( byteCount > 1 )
49 | {
50 | byteCtr = byteCount - 2 ;
51 | UCB0CTL1 |= UCTXSTT; // I2C start condition
52 | }
53 | else
54 | while (1); // illegal parameter
55 | }
56 |
57 | void TI_USCI_I2C_transmit(unsigned char byteCount, unsigned char *field)
58 | {
59 | TI_transmit_field = field;
60 | byteCtr = byteCount;
61 | UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition
62 | }
63 |
64 | unsigned char TI_USCI_I2C_slave_present(unsigned char slave_address)
65 | {
66 | unsigned char ie2_bak, slaveadr_bak, ucb0i2cie, returnValue;
67 | ucb0i2cie = UCB0I2CIE; // restore old UCB0I2CIE
68 | ie2_bak = IE2; // store IE2 register
69 | slaveadr_bak = UCB0I2CSA; // store old slave address
70 | UCB0I2CIE &= ~ UCNACKIE; // no NACK interrupt
71 | UCB0I2CSA = slave_address; // set slave address
72 | IE2 &= ~(UCB0TXIE + UCB0RXIE); // no RX or TX interrupts
73 | __disable_interrupt();
74 | UCB0CTL1 |= UCTR + UCTXSTT + UCTXSTP; // I2C TX, start condition
75 | while (UCB0CTL1 & UCTXSTP); // wait for STOP condition
76 |
77 | returnValue = !(UCB0STAT & UCNACKIFG);
78 | __enable_interrupt();
79 | IE2 = ie2_bak; // restore IE2
80 | UCB0I2CSA = slaveadr_bak; // restore old slave address
81 | UCB0I2CIE = ucb0i2cie; // restore old UCB0CTL1
82 | return returnValue; // return whether or not
83 | // a NACK occured
84 | }
85 |
86 | unsigned char TI_USCI_I2C_notready()
87 | {
88 | return (UCB0STAT & UCBBUSY);
89 | }
90 |
91 |
92 | #pragma vector = USCIAB0RX_VECTOR
93 | __interrupt void USCIAB0RX_ISR(void)
94 | {
95 | if (UCB0STAT & UCNACKIFG)
96 | { // send STOP if slave sends NACK
97 | UCB0CTL1 |= UCTXSTP;
98 | UCB0STAT &= ~UCNACKIFG;
99 | }
100 | }
101 |
102 |
103 | #pragma vector = USCIAB0TX_VECTOR
104 | __interrupt void USCIAB0TX_ISR(void)
105 | {
106 | if (IFG2 & UCB0RXIFG)
107 | {
108 | if ( byteCtr == 0 )
109 | {
110 | UCB0CTL1 |= UCTXSTP; // I2C stop condition
111 | *TI_receive_field = UCB0RXBUF;
112 | TI_receive_field++;
113 | }
114 | else
115 | {
116 | *TI_receive_field = UCB0RXBUF;
117 | TI_receive_field++;
118 | byteCtr--;
119 | }
120 | }
121 | else
122 | {
123 | if (byteCtr == 0)
124 | {
125 | UCB0CTL1 |= UCTXSTP; // I2C stop condition
126 | IFG2 &= ~UCB0TXIFG; // Clear USCI_B0 TX int flag
127 | }
128 | else
129 | {
130 | UCB0TXBUF = *TI_transmit_field;
131 | TI_transmit_field++;
132 | byteCtr--;
133 | }
134 | }
135 | }
