Hallo, ich habe ein Projekt bei dem ich den ADC und die VGA Schnittstelle des Nexys 4 Board nutzen will. Den Code konnte ich synthesieren, leider kommt bei der Implementation ein Fehler. Was mach ich falsch...?? Gruß MD Die Fehlermeldungen in Vivado unter Messages: [Place 30-372] Bank.35 has terminals with incompatible standards: Incompatible Pair of IO Standards: LVCMOS33 and LVCMOS18 The following terminals correspond to these IO Standards: SioStd: LVCMOS33 VCCO = 3.3 Termination: 0 TermDir: In Bank: 35 Placed GClock : Term: clk SioStd: LVCMOS18 VCCO = 1.8 Termination: 0 TermDir: In Bank: 35 Placed : Term: xadc_vauxn15 Term: xadc_vauxp15 Incompatible Pair of IO Standards: LVCMOS33 and LVCMOS18 The following terminals correspond to these IO Standards: SioStd: LVCMOS33 VCCO = 3.3 Termination: 0 TermDir: Out Bank: 35 Drv: 12 Placed : Term: vgaBlue[0] Term: vgaBlue[1] Term: vgaBlue[2] Term: vgaBlue[3] Term: vgaGreen[0] Term: vgaGreen[1] Term: vgaGreen[2] Term: vgaGreen[3] Term: vgaRed[0] Term: vgaRed[1] Term: vgaRed[2] Term: vgaRed[3] SioStd: LVCMOS18 VCCO = 1.8 Termination: 0 TermDir: In Bank: 35 Placed : Term: xadc_vauxn15 Term: and xadc_vauxp15 [Place 30-374] IO placer failed to find a solution Below is the partial placement that can be analyzed to see if any constraint modifications will make the IO placement problem easier to solve. +----------------------------------------------------------------------- ------------------------------------------------------------------------ --------------------------+ | IO Placement : Bank Stats | +----+-------+-------+-------------------------------------------------- ----------------------+------------------------------------------+------ --+--------+--------+-----+ | Id | Pins | Terms | Standards | IDelayCtrls | VREF | VCCO | VR | DCI | +----+-------+-------+-------------------------------------------------- ----------------------+------------------------------------------+------ --+--------+--------+-----+ | 0 | 0 | 0 | | | | | | | | 14 | 50 | 0 | | | | | | | | 15 | 50 | 2 | LVCMOS33(2) | | | +3.30 | YES | | | 16 | 10 | 0 | | | | | | | | 34 | 50 | 0 | | | | | | | | 35 | 50 | 15 | LVCMOS18(2) LVCMOS33(13) | | | +3.30 | YES | | +----+-------+-------+-------------------------------------------------- ----------------------+------------------------------------------+------ --+--------+--------+-----+ | | 210 | 17 | | | | | | | +----+-------+-------+-------------------------------------------------- ----------------------+------------------------------------------+------ --+--------+--------+-----+ IO Placement: +--------+----------------------+-----------------+--------------------- -+----------------------+----------------------+ | BankId | Terminal | Standard | Site | Pin | Attributes | +--------+----------------------+-----------------+--------------------- -+----------------------+----------------------+ | 15 | Hsync | LVCMOS33 | IOB_X0Y142 | B11 | | | | Vsync | LVCMOS33 | IOB_X0Y143 | B12 | | +--------+----------------------+-----------------+--------------------- -+----------------------+----------------------+ | 35 | clk | LVCMOS33 | IOB_X1Y126 | E3 | | | | vgaBlue[0] | LVCMOS33 | IOB_X1Y146 | B7 | | | | vgaBlue[1] | LVCMOS33 | IOB_X1Y141 | C7 | | | | vgaBlue[2] | LVCMOS33 | IOB_X1Y137 | D7 | * | | | vgaBlue[3] | LVCMOS33 | IOB_X1Y142 | D8 | | | | vgaGreen[0] | LVCMOS33 | IOB_X1Y148 | C6 | | | | vgaGreen[1] | LVCMOS33 | IOB_X1Y143 | A5 | | | | vgaGreen[2] | LVCMOS33 | IOB_X1Y145 | B6 | | | | vgaGreen[3] | LVCMOS33 | IOB_X1Y144 | A6 | | | | vgaRed[0] | LVCMOS33 | IOB_X1Y133 | A3 | | | | vgaRed[1] | LVCMOS33 | IOB_X1Y135 | B4 | | | | vgaRed[2] | LVCMOS33 | IOB_X1Y147 | C5 | | | | vgaRed[3] | LVCMOS33 | IOB_X1Y134 | A4 | | | | xadc_vauxn15 | LVCMOS18 | IOB_X1Y129 | B2 | | | | xadc_vauxp15 | LVCMOS18 | IOB_X1Y130 | B3 | | +--------+----------------------+-----------------+--------------------- -+----------------------+----------------------+ [Place 30-99] Placer failed with error: 'IO Clock Placer failed' Please review all ERROR, CRITICAL WARNING, and WARNING messages during placement to understand the cause for failure. [Common 17-69] Command failed: Placer could not place all instances
Er beshcwert sich, das Du auf der selben IO-Bank mit verschiedenen Spannungen arbeiten willst. Laut Schaltplan [1, Seite 10] liegen an der Bank 3,3V an. Du solltest bei den xadc-Pins auch die 3,3V als Constraint angeben. Duke [1] https://reference.digilentinc.com/_media/reference/programmable-logic/nexys-4/nexys4_sch.pdf
Hallo, vermutlich kennen wir uns :-) Schön, dass Du das Beispiel ausprobieren möchtest, hast Du die .xdc einfach so übernommen oder noch irgendwie bearbeitet? Edit: Im angehängten .zip ist noch die unveränderte .xdc Ja wie ist das eigentlich, in meinem XADC Beispiel musste ich die XADC-Ports gar nicht in der .xdc angeben. Die tauchen da einfach nicht auf. Ich weiß nicht wie man die da erklärt aber Du könntest die anderen Ports der gleichen Bank auf 1,8V setzen. So hatte ich das im Beispiel "nexys4_xadc_minimal.zip" mit dem UART_RXD_OUT gemacht. Hier http://nas.gus.tl/fpga/ sind übrigens die Beispiele. Das lief im Rahmen eines Uni-Workshops.
Hallo Gustl, ich hab dein VGA Beispiel als Basis verwendet, den AD-Wandler verwende ich ohne AXI Interface. Als Beispiel habe ich deinen AD-Wandler mit UART verwendet. Ich schaue mal in den Constrains ob ich den AD-Wandler auf 3.3V legen kann. Gruß MD
Sehr gut! Nur aus Interesse: Bist Du von der Uni Regensburg? Wenn ja, wir werden dort jetzt im Wintersemester wieder etwas mit FPGA machen. Geplant ist bisher, dass die Teilnehmer Projekte vorschlagen, wir uns dann eines heraussuchen, in kleine Blöcke zerteilen und die nach und nach als "Hausaufgabe" stellen. Das wird dann einmal die Woche während der Veranstaltung (und im Uni-Forum) besprochen. Vermutlich wird es sowas wie das was Du jetzt vor hast, also Daten irgendwie erfassen, verarbeiten, anzeigen oder irgendwie ausgeben. Und das mit dem Nexys4 Board. Ich fände z. B. ein einfaches Videospiel gesteuert mit dem verbauten Beschleunigungssensor ganz nett.
Hi gustl, ich bin von BIO/ VKL...wir haben einen Versuch im Fliegen bei dem wir ein Monitormuster in Abhängigkeit des AD Wertes verändern...die AD Werte sollen auch abgespeichert werden. Ich habe den Fehler gefunden, lag in den Constrains. Ciao ciao MD
Gustl B. schrieb: > Geplant ist bisher, dass > die Teilnehmer Projekte vorschlagen, wir uns dann eines heraussuchen, in > kleine Blöcke zerteilen und die nach und nach als "Hausaufgabe" stellen. Macht am Besten was mit Messtechnik, Sensorik und löst elektronische Problem. Nicht viel geklicke mit viel output, wo am Ende der Lerneffekt minimal und der Gebrauchswert Null ist, wie bei Vielem, was da gebrutzelt wird. Vor allem bitte nicht den 5000sten Musikerzeuger :-)
Ich werde mich nach den Wünschen der Teilnehmer richten. Signalverarbeitung und Regelung hat halt als Voraussetzung, dass man das mal gelernt hat. So nebenbei an einem Termin kann ich das nicht abfrühstücken. Aber welche motivierende Projektvorschläge gibt es denn die man mit Anfängern in einem Semester schaffen kann? Mir geht es drum, dass die Hardwaredenkweise gelernt wird und weniger darum fertige IP Blöcke zusammenzuklicken. Das funktioniert nämlich auch nur wenn man versteht was da passiert. Man könnte einen Microblaze verbauen und dann alles im SDK mit C machen, aber das ist nicht Sinn der Sache. Das Problem an Messtechnik und Sensorik ist, dass das erstmal nur die Datenerfassung ist. Was macht man dann damit? Man könnte Signalverläufe auf VGA anzeigen wie beim Oszi oder ein einfaches Videospiele damit steuern. Oder eben Audioausgabe. Wieso eigentlich nicht? Z. B. den Beschleunigungssensor als Eingabe für ein Effektgerät verwenden.
Ich nehme gerade an einem Kurs teil, der ungefähr wie folgt strukturiert ist: - Lab 1: State Machine (Mealy und Moore, Sequenzerkenner für beides implementieren), nur Simulation - Lab 2: PS/2 Keyboard Controller (auf dem Nexys4 ist ein PIC drauf, der USB-HID auf PS/2 umsetzt) und Siebensegmentanzeigen - Lab 3: ALU (Plus, Minus, Modulo-3, jeweils mit/ohne Vorzeichen) - Lab 4: VGA und "Taschen"rechner (Tastatur - ALU - Bildschirm) Der nächste Schritt wäre dann Speicher, dass man mehrere Rechenoperationen in einem Stack abspeichern kann, bevor man sie in umgekehrter Reihenfolge ausführt. Wenn dann noch Zeit ist, kann man die ALU z.B. Pipelined machen etc. Um Datenerfassung und -verarbeitung geht es in unserem Kurs allerdings explizit nicht. Die Zeit reicht nicht für beides.
S. R. schrieb: > Die Zeit reicht nicht für beides. Genau. Der Kurs bei Dir geht vermutlich mehr um Rechnerarchitektur. Das kann ich hier auch nicht als Voraussetzung verlangen und auch nicht nebenbei noch vermitteln. Schreibt ihr das alles selber in VHDL oder verwendet ihr viele fertige Blöcke?
Der Kurs ist eine Einfühung in VLSI-Design, hat also nichts mit Rechnerarchitektur zu tun (dafür gibt es im Studiengang ein Extra-Fach, aber da ich dort nicht studiere, weiß ich darüber nichts weiter). Explizit ging es um Register, Kombinatorik und Zustandsautomaten, aus denen dann Funktionalität zusammengebaut wurde. Bis Lab 3 haben wir alles selbst in VHDL geschrieben, aber mit vorgegebener Struktur (leere Blöcke). Fertige IP wird nur für Speicher (von Xilinx) und für VGA (vom Kursleiter, nicht zwingend) benutzt.
Ah ok. ALU klang jetzt eher danach zu lernen wie eine CPU funktioniert und generell Rechner aufgebaut sind. Aber auch das ist sehr lehrreich wenn man Digitalschaltung lernen möchte. S. R. schrieb: > Bis Lab 3 haben wir alles selbst in VHDL geschrieben, aber mit > vorgegebener Struktur (leere Blöcke). Fertige IP wird nur für Speicher > (von Xilinx) und für VGA (vom Kursleiter, nicht zwingend) benutzt. So möchte ich das auch halten, also IP Blöcke nur um zu zeigen wie man auch mit sowas umgeht, ist ja heute fast alles AXI ...
Nein, unsere "ALU" ist rein kombinatorisch mit nem Multiplexer hinten dran. Aber mit einer ALU als Konzept kann man den Unterschied zwischen Control Path und Data Path gut verdeutlichen. Für Modulo-3 wurde übrigens absichtlich kein Algorithmus vorgegeben (bis auf die Vorgabe, dass es einer mit shifts sein muss), sondern das selbstständige Suchen und Implementieren gehörte dazu. Gleiches gilt für das optionale Lab 5, wo man eine Wurzelfunktion in die ALU implementieren muss.
S. R. schrieb: > Wurzelfunktion in die ALU implementieren [...] > unsere "ALU" ist rein kombinatorisch 'Wurzelfunktion' und 'rein kombinatorisch' klingt für mich nach einem riesigem Gattergrab. Wie sind denn die Bitbreiten eurer ALU? 4 Bit? Duke
Duke Scarring schrieb: > 'Wurzelfunktion' und 'rein kombinatorisch' klingt für mich nach einem > riesigem Gattergrab. Wie sind denn die Bitbreiten eurer ALU? 4 Bit? Das war missverständlich. Die bisherige ALU hat ist 8 Bit breit, rein kombinatorisch und kann keine Wurzeln. In einer späteren Aufgabe sollen wir eine Wurzelfunktion hinzufügen, haben aber eine Ressourcenbegrenzung und werden die ALU getaktet aufbauen - sonst geht's nicht.
Gustl B. schrieb: > Das Problem an Messtechnik und Sensorik ist, dass das erstmal nur die > Datenerfassung ist. Was macht man dann damit? Man könnte Signalverläufe > auf VGA anzeigen wie beim Oszi oder ein einfaches Videospiele damit > steuern. Oder eben Audioausgabe. Wieso eigentlich nicht? Z. B. den > Beschleunigungssensor als Eingabe für ein Effektgerät verwenden. Du musst Dich fragen, was die Kinderlein lernen sollen: - Projektabwicklung? -> Requirements machen lassen, PH, schreiben lassen - Signalverarbeitung -> Mathe formulieren, getakteten Algo hinscheiben - VHDL-Programmierung -> Einfaches Problem mit dynamischer VHDL-Struktur - FPGA-Probleme -> Elektronik, Spannungen, Bänke, LVDS - C-Programmierung? -> PICOblace drauf, SOC, viel Klicken, Busse - Inbetriebnahme -> Testplan, Selbst-Test-Integration, eigentich müssten die ALLEs lernen. Bei den Mischprojekten kommt aber das, was wirklich interessant und wichtig ist, nämlich der erste und der letzte total zu kurz. Heraus kommen aus den Hochschulen im Moment viele FPGA-Dünnbrettbohrer, die mit MATLAB und EDK große Signalverarbeitungsprojekte anwerfen, die gewaltig aussehen, aber niemals nicht funktionieren, weil sie falsch geplant, nicht konzeptioneirt sind und niemals in Betrieb zu kriegen sind. Das ist vielfach zu oberflächlich!
Tja, da hast Du Recht. Aber wir haben nur ein Semester und zwei Stunden je Woche. Ich würde das auch echt gerne in mehr Zeit machen aber das ist eine Uni, keine FH. Wir haben sowieso großes Glück, dass wir das an der Physik Fakultät machen dürfen. Informatik gibt es bei uns nicht. Ich möchte soweit kommen, dass die Teilnehmer die Grundlagen verstanden haben und selber kleine Projekte bauen können. Für alles Weitere müssen Interessierte dann selber Zeit investieren.
Dann musst du dich halt auf irgendwas spezialisieren, und unter den gegebenen Bedingungen ist eine Kombination aus "Kombinatorik", "Register" und "fertige IP einbinden" durchaus sinnvoll. Für "sinnvolle IP selbst entwickeln" reicht die Zeit nicht. Das ist dann zwar oberflächlich, aber wenigstens nützlich. Die Alternative wäre ein Kurzvortrag zu jedem Thema, welches vom Niveau nicht über das durchschnittliche Blog hinausgeht und in der Klausur auf "auswendig lernen und aufschreiben" hinausläuft.
Also Klausur gibt es nicht, soll nur die Teilnehmer motivierten und ein paar Grundlagen vermitteln. Also den Einstieg ins Thema etwas begleiten. Wir sehen halt dass bei uns in der Physik für einige Aufgaben FPGAs verwendet werden, es aber keine Veranstaltung dazu gab. Die die das verwendet haben haben sich das also selbst beigebracht wie ich ja auch. Und damit das etwas weniger steinig wird gibt es jetzt einen Kurs.
Gustl B. schrieb: > Die die das > verwendet haben haben sich das also selbst beigebracht wie ich ja auch. Was wird denn da gemacht und mit welchem Ziel? Wäre es nicht sinnvoller, erst die Grundlagen zu erörtern und dann die Anwendung zu starten? Ich hatte auch zu dem Thema wieder eine Diskussion mit meinem Neu-Boss, der in die Firma eingestiegen ist und früher Vorlesungen in Friedberg gehalten hat: Auch er bemängelt, daß heute viel zu viel Masse gemacht wird und die Studenten aufgeblasene Projekte durchziehen, die nach viel aussehen und wenig bringen, weil sehr oberflächlich durchgezogen. Am Ende kommen Studenten heraus, die alle sehr viel können, aber nichts richtiges. Ich fände es besser, wenn man weniger machen würde und das dann vertiefter.
Weltbester FPGA-Pongo schrieb im Beitrag #4777302: > Was wird denn da gemacht und mit welchem Ziel? Wäre es nicht sinnvoller, > erst die Grundlagen zu erörtern und dann die Anwendung zu starten? Das wäre bestimmt sinnvoller, aber darauf haben wir keinen Einfluss. Hier in der Physik gibt es eben Arbeiten teilweise mit Abschluss (Master/Diplom) oder auch einfach so muss etwas gebaut werden und da fällt die Wahl eben auch manchmal auf einen FPGA. Das sind aber Physiker, die haben nichts zu dem Thema gelernt. Und weil da aber dann der FPGA verwendet werden soll oder es eben nicht anders geht, bringen sich die das dann auch bei. Die Ziele sind sehr unterschiedlich, also von Bilderkennung und Messwerterfassung bis zur Verwendung eines einzelnen MMCM von Xilinx weil man den zur Laufzeit rekonfigureiren kann und davon auch mehrere im FPGA hat. Jetzt in dem Kurs versuchen wir die Grundlagen beizubringen was aber auch schwer ist in einem Semester und nur 1,5 Stunden je Woche. Ganz trocken soll das ja auch nicht sein.
Das gibt es nicht. Es gibt aber ein Nexys Video (mit XC7A200T).
