Forum: FPGA, VHDL & Co. Anfänger: Wieder mal 7-Segment
von vhtl (Gast)
Ich bin VHDL-Anfänger und schaffe es einfach nicht, eine vierstellige
7-Segment-Anzeige anzusteuern (Beispiel reduziert):
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Hello is
  port ( SEG7 : out STD_LOGIC_VECTOR (1 to 8) := (others => '1');
         ANODE : out STD_LOGIC_VECTOR (0 to 3) := (others => '0');
         CLK : in STD_LOGIC);
end Hello;
architecture V1 of Hello is
  signal counter : STD_LOGIC_VECTOR (15 downto 0) := "1010010110010110";
  signal seg7id : STD_LOGIC_VECTOR(1 downto 0) := (others => '0');
begin
  display: process(CLK)
    variable digit : STD_LOGIC_VECTOR(3 downto 0);
  begin
    if rising_edge(CLK) then
      case seg7id is
        when "00" => ANODE <= "1110";
23
                     digit := counter(3 downto 0);
24
                     seg7id <= "01";
25
        when "01" => ANODE <= "1101";
26
                     digit := counter(7 downto 4);
27
                     seg7id <= "10";
28
        when "10" => ANODE <= "1011";
29
                     digit := counter(11 downto 8);
30
                     seg7id <= "11";
31
        when "11" => ANODE <= "0111";
32
                     seg7id <= "00";
33
                     digit := counter(15 downto 12);
34
        when others => ANODE <= "1111";
35
                       seg7id <= "00";
36
      end case;
37
38
      case digit is
39
        when "0000" => SEG7 <= "00000011";
40
        when "0001" => SEG7 <= "10011111";
41
        when "0010" => SEG7 <= "00100101";
42
        when "0011" => SEG7 <= "00001101";
43
        when "0100" => SEG7 <= "10011001";
44
        when "0101" => SEG7 <= "01001001";
45
        when "0110" => SEG7 <= "01000001";
46
        when "0111" => SEG7 <= "00011111";
47
        when "1000" => SEG7 <= "00000001";
48
        when "1001" => SEG7 <= "00001001";
49
        when "1010" => SEG7 <= "00010011";
50
        when "1011" => SEG7 <= "11100001";
51
        when "1100" => SEG7 <= "11100101";
52
        when "1101" => SEG7 <= "10000101";
53
        when "1110" => SEG7 <= "11000001";
54
        when "1111" => SEG7 <= "11100001";
55
        when others => SEG7 <= "11111101";
56
      end case;
57
58
    end if;
59
  end process;
60
61
end V1;
Leider sehe ich auf der Anzeige nur 8888, wobei die richtigen Segmente
etwas kräftiger erscheinen.
Ich hatte auch versucht, den display-Prozeß zu teilen und digit zum
Signal zu machen, aber der Fehler blieb.
Kann mir jemand zeigen, was ich falsch mache? Oder ist der Takt zu hoch?
von Sigi (Gast)
Dein Hauptproblem ist, dass Du zum einen
den Anodenvektor zu schnell umschaltest und
zum 2. den Anodenvektor daziwschen nicht
eine Zeitlang auf "1111" setzt. Mach es
wie folgt:
"1111"  x us
"1110"  y us
"1111"  x us
"1101"  y us
etc.
x und y musst Du experimentell ermitteln:
- zu kleines x bewirkt Nachleuchten
- zu kleines y hat schwaches Leuchten zur Folge.
IdR brauchst Du also 2 Zählvariablen und eine
FSM.
von vhtl (Gast)
Herzlichen Dank, das war's!
signal sid : STD_LOGIC_VECTOR(7 downto 0) := (others => '0');
      case sid(7 downto 5) is
        when "000" => ANODE <= "1110";
        when "010" => ANODE <= "1101";
        when "100" => ANODE <= "1011";
        when "110" => ANODE <= "0111";
      end case;
      sid <= sid + 1;
Hardware ist echt schnell! :-)
von Sigi (Gast)
Du setzt den ANODE-Vektor zwischenzeitlich
nicht auf "1111". Siehst Du bei Dir ein
"seltsames" Nachleuchten?
von vhtl (Gast)
Doch, über
bei "--1-----".
von Mike (Gast)
Ich schätze mal dein ursprünglicher Code schaltet zu früh/zu spät auf
die nächste Stelle um. Man müsste ihn mal simulieren.
Dann solltest du dir nicht angewöhnen mit std_logic_unsigned zu rechnen
(ist veraltet). Besser wäre es wenn du numeric_std verwendest.
Siehe hier:
http://www.mikrocontroller.net/articles/Rechnen_in_VHDL#Schlecht:_Direktes_Rechnen_mit_std_logic_vector
> Siehe hier:...
Und hier die relevanten Umformungen:
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
