1  | #include "stm32f4xx.h"
2  | #include "stm32f4_discovery.h"
3  |
4  |
5  | void init_SPI1(void){
6  |
7  |   GPIO_InitTypeDef GPIO_InitStruct;
8  |   SPI_InitTypeDef SPI_InitStruct;
9  |
10  |   // enable clock for used IO pins
11  |   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
12  |
13  |   /* configure pins used by SPI1
14  |    * PA5 = SCK
15  |    * PA6 = MISO
16  |    * PA7 = MOSI
17  |    */
18  |   GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_6 | GPIO_Pin_5;
19  |   GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
20  |   GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
21  |   GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
22  |   GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
23  |   GPIO_Init(GPIOA, &GPIO_InitStruct);
24  |
25  |   // connect SPI1 pins to SPI alternate function
26  |   GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_SPI1);
27  |   GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_SPI1);
28  |   GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_SPI1);
29  |
30  |   // enable clock for used IO pins
31  |   RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
32  |
33  |   /* Configure the chip select pin
34  |      in this case we will use PE7 */
35  |   GPIO_InitStruct.GPIO_Pin = GPIO_Pin_7;
36  |   GPIO_InitStruct.GPIO_Mode = GPIO_Mode_OUT;
37  |   GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
38  |   GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
39  |   GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_UP;
40  |   GPIO_Init(GPIOE, &GPIO_InitStruct);
41  |
42  |   GPIOE->BSRRL |= GPIO_Pin_7; // set PE7 high
43  |
44  |   // enable peripheral clock
45  |   RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
46  |
47  |   /* configure SPI1 in Mode 0
48  |    * CPOL = 0 --> clock is low when idle
49  |    * CPHA = 0 --> data is sampled at the first edge
50  |    */
51  |   SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex; // set to full duplex mode, seperate MOSI and MISO lines
52  |   SPI_InitStruct.SPI_Mode = SPI_Mode_Master;     // transmit in master mode, NSS pin has to be always high
53  |   SPI_InitStruct.SPI_DataSize = SPI_DataSize_16b; // one packet of data is 8 bits wide
54  |   SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low;        // clock is low when idle
55  |   SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge;      // data sampled at first edge
56  |   SPI_InitStruct.SPI_NSS = SPI_NSS_Soft | SPI_NSSInternalSoft_Set; // set the NSS management to internal and pull internal NSS high
57  |   SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4; // SPI frequency is APB2 frequency / 4
58  |   SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;// data is transmitted MSB first
59  |   SPI_Init(SPI1, &SPI_InitStruct);
60  |
61  |   SPI_Cmd(SPI1, ENABLE); // enable SPI1
62  | }
63  |
64  | /* This funtion is used to transmit and receive data
65  |  * with SPI1
66  |  *       data --> data to be transmitted
67  |  *       returns received value
68  |  */
69  | uint16_t SPI1_send(uint16_t data){
70  |
71  |   SPI1->DR = data; // write data to be transmitted to the SPI data register
72  |   while( !(SPI1->SR & SPI_I2S_FLAG_TXE) ); // wait until transmit complete
73  |   while( !(SPI1->SR & SPI_I2S_FLAG_RXNE) ); // wait until receive complete
74  |   while( SPI1->SR & SPI_I2S_FLAG_BSY ); // wait until SPI is not busy anymore
75  |   return SPI1->DR; // return received data from SPI data register
76  | }
77  |
78  | int main(void)
79  | {
80  |   /* Initialize system */
81  |   SystemInit();
82  |
83  |   init_SPI1();
84  |
85  |   uint16_t data=0;
86  |
87  |   while(1) {
88  |     //activate slave with LOW, disable with HIGH
89  |     GPIOE->BSRRH |= GPIO_Pin_7; // set PE7 (CS) low
90  |     data = SPI1_send(0x3FFF); // 0x3FFF -> Transmit Angle Read command
91  |     GPIOE->BSRRL |= GPIO_Pin_7; // set PE7 (CS) high
92  |
93  |     for(int i=0;i<8000000;i++);
94  |   }
95  | }
