1 | #include <Keyboard.h>
2 | int dataPin = 9;
3 | int clockPin = 7;
4 | int latchPin = 8;
5 |
6 | unsigned long last_press = 0;
7 | unsigned long last_key_press = 0;
8 |
9 | char* letters[] ={"dcbahgfe" };
10 |
11 | int num_chars = 43;
12 | int num_registers = 1;
13 | byte button_states[] = {0x00,0x00,0x00,0x00}; //01001000
14 | int cursor_index = 0;
15 | int char_index = 0;
16 | char cur_char = 'X';
17 |
18 | void setup() {
19 | Serial.begin(9600);
20 | pinMode(latchPin, OUTPUT);
21 | pinMode(clockPin, OUTPUT);
22 | pinMode(dataPin, INPUT);
23 | Keyboard.begin();
24 |
25 | }
26 |
27 | void loop() {
28 | if (millis() - last_key_press > 350) read_keyboard();
29 | delay(1);
30 | }
31 |
32 |
33 | void read_keyboard(){
34 | //set it to 0 to transmit data serially
35 | digitalWrite(latchPin,LOW);
36 | //while the shift register is in serial mode
37 | //collect each shift register into a byte
38 | //the register attached to the chip comes in first
39 | for (int i = 0; i < num_registers; i++){
40 | button_states[i] = shiftIn(dataPin, clockPin);
41 | }
42 | boolean something_in = false;
43 | for (int i = 0; i < num_registers; i++){
44 | something_in = translate_buttons_2_keys(button_states[i], letters[i]);
45 | if (something_in) last_key_press = millis();
46 | }
47 | digitalWrite(latchPin,HIGH);
48 | }
49 |
50 | boolean translate_buttons_2_keys(byte buttons, char* keys){
51 | for(int i = 0 ; i < 8; i++){
52 | if ( (1 << i) & buttons ){
53 | cur_char = keys[i];
54 | Keyboard.print(keys[i]);
55 | char_index++;
56 | return true;
57 | }
58 | }
59 | return false;
60 | }
61 | byte shiftIn(int myDataPin, int myClockPin) {
62 | int i;
63 | int temp = 0;
64 | int pinState;
65 | byte myDataIn = 0;
66 |
67 | pinMode(myClockPin, OUTPUT);
68 | pinMode(myDataPin, INPUT);
69 |
70 | for (i=7; i>=0; i--)
71 | {
72 | digitalWrite(myClockPin, 0);
73 | delayMicroseconds(20);
74 | temp = digitalRead(myDataPin);
75 | if (temp) {
76 | pinState = 1;
77 | myDataIn = myDataIn | (1 << i);
78 | }
79 | else {
80 | pinState = 0;
81 | }
82 | digitalWrite(myClockPin, 1);
83 | }
84 | return myDataIn;
85 | }
